Install torchaudio and torchvison from wheel
Hi everyone,
I am trying to setting up environment on Nvidia Jetson Xavier NX(developer kit), I have successfully make cuda, pytorch working since torch.cuda.is_available() is True. The problem occurs when I am trying to import torchaudio which I have already successfully installed and I think it is with the correct version 0.12.0 for torch 1.12.0
I have flashed my sd card for Nvidia Jetson Xavier NX, and it seems like I am able to collect the results from collect_env file.
Collecting environment information…
PyTorch version: 1.12.0a0+2c916ef.nv22.3
Is debug build: False
CUDA used to build PyTorch: 11.4
ROCM used to build PyTorch: N/A
OS: Ubuntu 20.04.5 LTS (aarch64)
GCC version: (Ubuntu 9.4.0-1ubuntu1~20.04.1) 9.4.0
Clang version: Could not collect
CMake version: version 3.16.3
Libc version: glibc-2.31
Python version: 3.8.10 (default, Jun 22 2022, 20:18:18) [GCC 9.4.0] (64-bit runtime)
Python platform: Linux-5.10.104-tegra-aarch64-with-glibc2.29
Is CUDA available: True
CUDA runtime version: 11.4.239
GPU models and configuration: Could not collect
Nvidia driver version: Could not collect
cuDNN version: Probably one of the following:
/usr/lib/aarch64-linux-gnu/libcudnn.so.8.4.1
/usr/lib/aarch64-linux-gnu/libcudnn_adv_infer.so.8.4.1
/usr/lib/aarch64-linux-gnu/libcudnn_adv_train.so.8.4.1
/usr/lib/aarch64-linux-gnu/libcudnn_cnn_infer.so.8.4.1
/usr/lib/aarch64-linux-gnu/libcudnn_cnn_train.so.8.4.1
/usr/lib/aarch64-linux-gnu/libcudnn_ops_infer.so.8.4.1
/usr/lib/aarch64-linux-gnu/libcudnn_ops_train.so.8.4.1
HIP runtime version: N/A
MIOpen runtime version: N/A
Is XNNPACK available: False
Versions of relevant libraries:
[pip3] numpy==1.17.4
[pip3] torch==1.12.0a0+2c916ef.nv22.3
[pip3] torchaudio==0.12.0
[pip3] torchvision==0.13.0
[conda] Could not collect
To make reproducing this problem easier, you can flash jetpack 5.0.2 rev1 by using Nvidia SDK manager.
download wheels
for pytorch 1.12.0: https://developer.download.nvidia.com/compute/redist/jp/v50/pytorch/torch-1.12.0a0+2c916ef.nv22.3-cp38-cp38-linux_aarch64.whl
for torchaudio 0.12.0: https://download.pytorch.org/whl/torchaudio-0.12.0-cp38-cp38-manylinux2014_aarch64.whl
for torchvision 0.13.0: https://download.pytorch.org/whl/torchvision-0.13.0-cp38-cp38-manylinux2014_aarch64.whl
After I type python3
import torch
True
import torchaudio
File “”, line 1, in
File “/home/yilinw/astrtd/lib/python3.8/site-packages/torchaudio/init.py”, line 1, in
from torchaudio import ( # noqa: F401
File “/home/yilinw/astrtd/lib/python3.8/site-packages/torchaudio/_extension.py”, line 103, in
_init_extension()
File “/home/yilinw/astrtd/lib/python3.8/site-packages/torchaudio/_extension.py”, line 88, in _init_extension
_load_lib(“libtorchaudio”)
File “/home/yilinw/astrtd/lib/python3.8/site-packages/torchaudio/_extension.py”, line 51, in _load_lib
torch.ops.load_library(path)
File “/home/yilinw/astrtd/lib/python3.8/site-packages/torch/_ops.py”, line 244, in load_library
ctypes.CDLL(path)
File “/usr/lib/python3.8/ctypes/init.py”, line 373, in init
self._handle = _dlopen(self._name, mode)
OSError: /home/yilinw/astrtd/lib/python3.8/site-packages/torchaudio/lib/libtorchaudio.so: undefined symbol: _ZNK5torch8autograd4Node4nameEv
import torchvision
/home/yilinw/astrtd/lib/python3.8/site-packages/torchvision/io/image.py:13: UserWarning: Failed to load image Python extension:
warn(f"Failed to load image Python extension: {e}")
Please let me know if there is any suggestion. Thank you very much.
Sincerely,
Yilin Wang
Could you please give our nv22.09 PyTorch package a try?
We got some similar issues before but upgrading to the latest nv22.09 seems to solve the issue.
Thank you for your immediate response.
Are you suggesting https://developer.download.nvidia.cn/compute/redist/jp/v502/pytorch/1.13.0a0+d0d6b1f2.nv22.09 ?
Since it is torch 1.13, I am not able to fine torchaudio 0.13.0 and torchvision 0.14.0, should I still give it a try?
Sincerely,
Yilin Wang
I reinstall the pytorch with wheel downloaded from
https://developer.download.nvidia.com/compute/redist/jp/v502/pytorch/torch-1.13.0a0+d0d6b1f2.nv22.09-cp38-cp38-linux_aarch64.whl
(astrtd) yilinw@ubuntu:~/Downloads$ pip3 list | grep torch
torch 1.13.0a0+d0d6b1f2.nv22.9
torchaudio 0.12.1
torchvision 0.13.0
(astrtd) yilinw@ubuntu:~/Downloads$ python3
Python 3.8.10 (default, Jun 22 2022, 20:18:18)
[GCC 9.4.0] on linux
Type “help”, “copyright”, “credits” or “license” for more information.
import torch
import torchvision
import torchaudio
File “”, line 1, in
_init_extension()
File “/home/yilinw/astrtd/lib/python3.8/site-packages/torch/_ops.py”, line 293, in load_library
ctypes.CDLL(path)
Problem remains the same.
I’m trying to use torch 1.12 on Jetson Xavier NX with JetPack 5.0.2 and obtain de same error with torchvision 0.13 when I import it.
I’ve tried with torch 1.13, but there is not torchvision compatible version available (or I haven’t found it).
Hi @rroldan @yilinw, can you try using the l4t-pytorch container and let me know if you encounter the same issue? Those have PyTorch + torchvision + torchaudio pre-installed in them.
I was tired of working on those packages by myself, so I have already pulled the l4t-pytorch container, and the container works perfectly.
The problem of installing torchaudio, torchvision by myself still remains the same.
Based on the sharing below, do you mind giving TorchVision v0.15.0 a try?
Thank you for the suggestion, but I would like get more help in terms of installing torchaudio. Thank you.
Sincerely,
Yilin Wang
Hi. Finally, I could install it natively building from source. This method installs torchvision 0.15.0a0+6e203b4 and it works perfectly with torch 1.12.0a0+2c916ef.nv22.3 on a virtualenv or Conda environment with Python 3.8.
You can try our l4t-ml container which has both TorchVision and TorchAudio installed.
