I tried to install tty acm module (driver) on Xavier with no success (as it is not automatically installed; see the log of /dev/tty device below). I have found a method to install it on Jetsonhack website, but it works only for tx1 and tx2. Could you please help me in installing this module?
[Created at usb.122]
Unique ID: Q3sC.1KovF6zT2I7
Parent ID: k4bc.+N3vcF8QTi8
SysFS ID: /devices/3610000.xhci/usb1/1-2/1-2:1.4
SysFS BusID: 1-2:1.4
Hardware Class: modem
Model: “DJI”
Hotplug: USB
Vendor: usb 0x2ca3 “DJI”
Device: usb 0x001f “DJI”
Revision: “ff.ff”
Serial ID: “0123456789ABCDEF”
Device File: /dev/ttyACM0
Speed: 480 Mbps
Module Alias: “usb:v2CA3p001FdFFFFdc00dsc00dp00ic02isc02ip01in04”
Driver Info #0:
Driver Status: cdc_acm is not active
Driver Activation Cmd: “modprobe cdc_acm”
Config Status: cfg=new, avail=yes, need=no, active=unknown
Attached to: #29 (Hub)
