I looked around a lot and it took me a lot of work to get this working, so I’m posting it here for others.
I’m using QT Designer for HMI application design. I couldn’t find a version of QT Designer that uses QT5, and my layout designed in QT Designer 6 didn’t work with the pre-built-in QT5 on the Orin Nano. I had to build from source for QT6 on ARM.
I ended up building twice (many hours each time) since I inadvertently missed a necessary plugin the first time. I was not able to install PyQt6 unfortunately, even after much trial and error. I finally got it working with PySide6. Here are the steps:
To build and install the Qt 6.6.1 from the source located at /home/{user}/Downloads/qt-everywhere-src-6.6.1.tar.xz, including the xcb platform plugin, follow these steps:
Extract the Source Code:
First, you need to extract the downloaded tarball. Open a terminal and run:tar -xvf /home/{user}/Downloads/qt-everywhere-src-6.6.1.tar.xz -C /home/{user}/Downloads/This will extract the contents into a directory, likely named
qt-everywhere-src-6.6.1, in your Downloads folder. -
Install Required Dependencies:
Ensure you have all the required dependencies for building Qt, especially those needed for the xcb plugin:sudo apt-get install build-essential libfontconfig1-dev libdbus-1-dev libfreetype6-dev libicu-dev libinput-dev libxkbcommon-dev libsqlite3-dev libssl-dev libpng-dev libjpeg-dev libglib2.0-dev libpulse-dev libasound2-dev libcups2-dev libegl1-mesa-dev libxcb1-dev libx11-xcb-dev libglu1-mesa-dev libxrender-dev libxi-dev '^libxcb.*-dev' -
Configure the Build:
Navigate to the extracted Qt source directory and run the configuration script. Ensure you include the-xcboption to include the xcb plugin:cd /home/{user}/Downloads/qt-everywhere-src-6.6.1 ./configure -platform linux-g++ -xcb -opensource -confirm-licenseAdjust the configuration options according to your needs. The
-opensource -confirm-licenseoptions are for open source development and to confirm acceptance of Qt’s license. -
Build and Install:
Compile and install Qt:make sudo make installThis will take a significant amount of time depending on your hardware capabilities.
These steps should help you compile and install Qt 6.6.1 from source with the necessary xcb support.
