I’m trying to get TensorFlow running with GPU acceleration on a Jetson Orin Nano Super, using JetPack 6.0.1 (Release R36.4.7). I’ve manually verified and linked all required CUDA libraries (libcublas, libcufft, libcurand, etc.) under /usr/local/cuda-12.6/lib64, and set LD_LIBRARY_PATH accordingly.
Despite this, TensorFlow still outputs: Cannot dlopen some GPU libraries. Skipping registering GPU devices...
Has anyone successfully installed a compatible TensorFlow wheel or container for JetPack 6.0.1 on ARM64? Any working builds or setup scripts would be greatly appreciated.
To get TensorFlow running with GPU acceleration on a Jetson Orin Nano Super using JetPack 6.0.1 Release R36.4.7, you’ll need to ensure that you have the correct CUDA libraries installed and linked. Here’s a step-by-step guide to help you install a compatible TensorFlow wheel or container for JetPack 6.0.1 on ARM64:
Prerequisites:
- Ensure that you have the latest version of JetPack 6.0.1 installed on your Jetson Orin Nano Super.
- Verify that you have the necessary CUDA libraries installed, including libcublas, libcufft, and libcurand.
- Make sure that the CUDA libraries are properly linked under
/usr/local/cuda/lib64.
Installing TensorFlow:
Option 1: Install TensorFlow using pip
- Install the TensorFlow wheel using pip:
pip3 install tensorflow
- However, this method may not provide the optimal performance, as the pre-built wheel may not be optimized for the Jetson Orin Nano’s GPU architecture.
Option 2: Build TensorFlow from source
- Clone the TensorFlow repository:
git clone https://github.com/tensorflow/tensorflow.git
- Navigate to the TensorFlow directory:
cd tensorflow
- Configure the build:
./configure
- Build TensorFlow:
bazel build --config=opt //tensorflow/tools/pip_package:build_pip_package
- Install the built TensorFlow package:
pip3 install /tmp/tensorflow_pkg/tensorflow-*.whl
Option 3: Use a pre-built TensorFlow container
- Pull the TensorFlow container from NVIDIA’s NGC registry:
docker pull nvcr.io/nvidia/tensorflow:20.03-tf1-py3
- Run the container:
docker run --runtime=nvidia --rm -it nvcr.io/nvidia/tensorflow:20.03-tf1-py3
Comparison of Options:
- Option 1 (pip install): This method is the easiest, but it may not provide the best performance, as the pre-built wheel may not be optimized for the Jetson Orin Nano’s GPU architecture.
- Option 2 (build from source): This method provides the best performance, as you can optimize the build for the Jetson Orin Nano’s GPU architecture. However, it requires more effort and expertise.
- Option 3 (pre-built container): This method provides a good balance between ease of use and performance. The pre-built container is optimized for the Jetson Orin Nano’s GPU architecture, and it’s easy to use.
Working Builds or Setup Scripts:
- NVIDIA provides pre-built TensorFlow containers for JetPack 6.0.1 on ARM64, which can be found on their NGC registry.
- You can also use the TensorFlow build scripts provided by NVIDIA to build TensorFlow from source.
Conclusion:
To get TensorFlow running with GPU acceleration on a Jetson Orin Nano Super using JetPack 6.0.1 Release R36.4.7, you can use one of the three options mentioned above. Option 2 (build from source) provides the best performance, but it requires more effort and expertise. Option 3 (pre-built container) provides a good balance between ease of use and performance.
Do you use JetPack 6.2.1+r36.4.7 or JetPack 6.0.1?
We don’t have a prebuilt TensorFlow package for the JetPack 6.2 environment.
You will need to build it from the source.
Is there a reliable guide somewhere? I’m using JetPack 6.2.1, but so far I haven’t found any instructions that really help. Even a Docker container could not be installed because it requires driver version 560.x, but only 540.4.0 is installed on the Jetson.
We have a package that was built for JetPack 6.1:
https://developer.download.nvidia.com/compute/redist/jp/v61/tensorflow/
Would you might to give it a try?
