With the new EntropyCalibrator2, I believe you'll have to generate a new calibration table (for the same reason the code initially failed).
You can do that by providing paths to your own images for calibration as mentioned here: https://github.com/NVIDIA-AI-IOT/deepstream_reference_apps/tree/master/yolo#note (bullet point #1)
However, that link no longer works because Yolo support has been rolled directly into Deepstream. Looking back at a previous branch shows that bullet point #1 says:
“If you want to generate your own calibration table, use the calibration_images.txt file to list of images to be used for calibration and delete the default calibration table.”
But this is not helpful as it doesn’t indicate where/how the calibration_image.txt should be passed, and even so, this documentation (and trt-yolo-app) is outdated.
Basically, my question is: what is the current, up to date, supported method to generate a calibration file for yolo using Deepstream SDK 4 and are there any resources that detail the process and data required to do so?
trt-yolo-app was compatible for DS3.0 and no longer supported on the github repo. We have plans to add support for a calibration app for yolo models which is compatible with DS 4.0 in the future.
If you are interested you can modify the sources from the old trt-yolo-app to be compatible with DS4.0 and use it since the code is available on github(on previous releases).
The issue I’m having is that the DS 4.0 SDK comes with a prebuilt yolov3 calibration table for the pretrained model, which from what you’re saying is that DS 4.0 does not have a native or “out of the box” ability to generate said table. In that case the inclusion of the table is misleading without some explanation about the why and how. I’ve spent quite a lot of time pouring through documentation and even some of the DS 4.0 code to find where a parameters to pass a list of images to generate a calibration table would be.
Even with the DS 3.0 trt-yolo-app it isn’t obvious how to go about generating that table. The documentation just says:
But where should that txt file be placed? How is it referenced? Which parameter is configured to point to it?
These are the questions I was trying to ask in my original post. The documentation for this process is non-existent and it’s difficult and time consuming to decipher without Nvidia’s help.
@CJR.
Thanks for the reply. But I found in the new release, the trt-yolo-app is not exists.
How could I create my own calibration file for yolov3 in DeepStream5?
Like the bundled file “yolov3-calibration.table.trt7.0”. How could I generate my own version? Thanks!
