Jetson • DeepStream Version
6.2 • JetPack Version (valid for Jetson only)
5.1 rev 1 • TensorRT Version
8.5.2.2-1+cuda11.4 • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
Hi, I have been trying to deploy yolov5 on the Jetson Orin platform, I am currently using an AGX dev kit emulating a Orin Nano 8gb. I followed this tutorial here https://github.com/ultralytics/yolov5/issues/9627 and was able to get fp32 and fp16 working. However, when I try the int8 section, I am unable to run and it gives me a core dumped issue relating to some cuda engine creation failure. The log is attached below, and the config files i used with deepstream are attached as well. Any thoughts on how I might be able to solve this issue? output.txt (10.2 KB)
yea, i was kinda confused about where to get the calib.table because there didn’t seem to be an explanation in that github tutorial. I will take a look at the sample you linked.
I ran the steps in the nvidia repo, i’m stuck at the pip install -r requirement_export.txt step, there seems to be an issue in installing onnx-runtime. Any idea how to proceed?
I tried running the docker container for nvcr.io/nvidia/deepstream:6.1.1-devel for the “prepare for deepstream inference step” and its giving me “WARNING: The requested image’s platform (linux/amd64) does not match the detected host platform (linux/arm64/v8) and no specific platform was requested
exec /usr/bin/bash: exec format error”
