IntegralBoundaryConstraint leads to constant loss
Hello, I’m currently trying to learn modulus. My experience with neural networks is admittedly rusty and I have no prior experience with CFDs.
The Problem:
If I include the following code for an IntegralBoundaryConstraint, which represents the inlet and outlet of a system containing water flow I notice that my loss value becomes constant, which would obviously make it impossible for it to converge. Anyone have tips on how I should troubleshoot this? This code is modifed from the Aneurysm case.
Note that gpm is currently set to a value of 2 and the coordinate system is in mm (coords are normalized to fit within a unit cube).
    # Integral Continuity 1
    integral_continuity = IntegralBoundaryConstraint(
        nodes=nodes,
        geometry=inlet_mesh,
        outvar={"normal_dot_vel": gpm},
        batch_size=1,
        integral_batch_size=cfg.batch_size.integral_continuity,
        lambda_weighting={"normal_dot_vel": 0.1},
    domain.add_constraint(integral_continuity, "integral_continuity")
    # Integral Continuity 2
        nodes=nodes,
        geometry=outlet_mesh,
        outvar={"normal_dot_vel": -gpm},
        batch_size=1,
Here’s a sample of the training log output
[18:52:55] - [step:      93100] loss:  8.000e-01, time/iteration:  5.398e+01 ms
[18:52:59] - [step:      93200] loss:  8.000e-01, time/iteration:  3.567e+01 ms
[18:53:02] - [step:      93300] loss:  8.000e-01, time/iteration:  3.570e+01 ms
[18:53:06] - [step:      93400] loss:  8.000e-01, time/iteration:  3.567e+01 ms
[18:53:09] - [step:      93500] loss:  8.000e-01, time/iteration:  3.565e+01 ms
[18:53:13] - [step:      93600] loss:  8.000e-01, time/iteration:  3.566e+01 ms
[18:53:17] - [step:      93700] loss:  8.000e-01, time/iteration:  3.560e+01 ms
[18:53:20] - [step:      93800] loss:  8.000e-01, time/iteration:  3.558e+01 ms
[18:53:24] - [step:      93900] loss:  8.000e-01, time/iteration:  3.546e+01 ms
[18:53:27] - [step:      94000] saved checkpoint to outputs/foobar
Update: if I change the lambda_weighting={"normal_dot_vel": 1e-8} parameter to a closer to the same scale as the loss value without the IntegralBoundaryConstraint then I can begin to see changes to the loss value. This leads me to believe one of the following may be true:
  1. Integral constraint weighting should be tuned to match the scale of the the loss function’s output
  2. The model is very bad at maintaining the integral constraint, and so it’s losses completely overpower the rest of the data.
  3. I’ve overthought this whole thing and if I was more patient the loss function would eventually reflect progress.
Log output with adjusted lambda_weighting
[19:56:40] - [step:     192000] loss:  8.052e-08, time/iteration:  3.745e+01 ms
[19:56:44] - [step:     192100] loss:  8.043e-08, time/iteration:  3.620e+01 ms
[19:56:47] - [step:     192200] loss:  8.057e-08, time/iteration:  3.596e+01 ms
[19:56:51] - [step:     192300] loss:  8.174e-08, time/iteration:  3.634e+01 ms
[19:56:55] - [step:     192400] loss:  8.023e-08, time/iteration:  3.686e+01 ms
[19:56:58] - [step:     192500] loss:  8.048e-08, time/iteration:  3.591e+01 ms
[19:57:02] - [step:     192600] loss:  8.020e-08, time/iteration:  3.590e+01 ms
[19:57:06] - [step:     192700] loss:  8.116e-08, time/iteration:  3.662e+01 ms
[19:57:09] - [step:     192800] loss:  8.048e-08, time/iteration:  3.557e+01 ms
[19:57:13] - [step:     192900] loss:  8.064e-08, time/iteration:  3.553e+01 ms
