hello, I am trying to simulate a problem where we have to predict a damage in a solid mechanical model, but in doing so I am facing an problem with conditions on the same.
I need to solve the equation: self.equation["f"] = Max(|p| - r1, 0) + r2*f = 0, so I defined the same in modulus and in constraint section with outvar={"f":0}but I am facing the following error:
- I defined the function as it is (self.equation[“f”]) as mentioned above
[16:39:55] - JIT using the NVFuser TorchScript backend
[16:39:55] - JitManager: {'_enabled': True, '_arch_mode': <JitArchMode.ONLY_ACTIVATION: 1>, '_use_nvfuser': True, '_autograd_nodes': False}
[16:39:55] - GraphManager: {'_func_arch': False, '_debug': False, '_func_arch_allow_partial_hessian': True}
[16:40:06] - Installed PyTorch version 2.0.1+cu117 is not TorchScript supported in Modulus. Version 1.14.0a0+410ce96 is officially supported.
[16:40:06] - attempting to restore from: outputs/damage_model
[16:40:06] - Success loading optimizer: outputs/damage_model/optim_checkpoint.0.pth
[16:40:06] - Success loading model: outputs/damage_model/virtual_work_model.0.pth
[16:40:12] - [step: 1000] saved checkpoint to outputs/damage_model
[16:40:12] - [step: 1000] loss: 7.462e-02
[16:40:15] - Attempting cuda graph building, this may take a bit...
Error executing job with overrides: []
File "/home/neo11/anaconda3/envs/test_env/lib/python3.8/site-packages/modulus/sym/trainer.py", line 742, in _cuda_graph_training_step
self.loss_static, self.losses_static = self.compute_gradients(
File "/home/neo11/anaconda3/envs/test_env/lib/python3.8/site-packages/modulus/sym/trainer.py", line 68, in adam_compute_gradients
losses_minibatch = self.compute_losses(step)
File "/home/neo11/anaconda3/envs/test_env/lib/python3.8/site-packages/modulus/sym/solver/solver.py", line 66, in compute_losses
return self.domain.compute_losses(step)
File "/home/neo11/anaconda3/envs/test_env/lib/python3.8/site-packages/modulus/sym/domain/domain.py", line 147, in compute_losses
constraint.forward()
File "/home/neo11/anaconda3/envs/test_env/lib/python3.8/site-packages/modulus/sym/domain/constraint/continuous.py", line 130, in forward
self._output_vars = self.model(self._input_vars)
File "/home/neo11/anaconda3/envs/test_env/lib/python3.8/site-packages/torch/nn/modules/module.py", line 1501, in _call_impl
return forward_call(*args, **kwargs)
File "/home/neo11/anaconda3/envs/test_env/lib/python3.8/site-packages/modulus/sym/graph.py", line 234, in forward
outvar.update(e(outvar))
File "/home/neo11/anaconda3/envs/test_env/lib/python3.8/site-packages/modulus/sym/utils/sympy/torch_printer.py", line 288, in forward
output = self.torch_expr(args)
File "<lambdifygenerated-13>", line 3, in _lambdifygenerated
return (-10000.0*d__t + Max(0, Max(-10*d__x__x - 10*d__y__y - 0.5*sigma_xx*u__x - 0.5*sigma_xy*v__x - 0.5*sigma_yy*v__y, 10*d__x__x + 10*d__y__y + 0.5*sigma_xx*u__x + 0.5*sigma_xy*v__x + 0.5*sigma_yy*v__y) - 10000.0) - 10000.0)
File "/home/neo11/anaconda3/envs/test_env/lib/python3.8/site-packages/modulus/sym/utils/sympy/torch_printer.py", line 154, in _max_torch
value = (torch.zeros(tensor_shape) + value).to(device)
RuntimeError: CUDA error: operation not permitted when stream is capturing
CUDA kernel errors might be asynchronously reported at some other API call, so the stacktrace below might be incorrect.
For debugging consider passing CUDA_LAUNCH_BLOCKING=1.
Compile with `TORCH_USE_CUDA_DSA` to enable device-side assertions.
During handling of the above exception, another exception occurred:
File "damage_model.py", line 242, in run
slv.solve()
File "/home/neo11/anaconda3/envs/test_env/lib/python3.8/site-packages/modulus/sym/solver/solver.py", line 173, in solve
self._train_loop(sigterm_handler)
File "/home/neo11/anaconda3/envs/test_env/lib/python3.8/site-packages/modulus/sym/trainer.py", line 535, in _train_loop
loss, losses = self._cuda_graph_training_step(step)
File "/home/neo11/anaconda3/envs/test_env/lib/python3.8/site-packages/torch/cuda/graphs.py", line 173, in __exit__
self.cuda_graph.capture_end()
File "/home/neo11/anaconda3/envs/test_env/lib/python3.8/site-packages/torch/cuda/graphs.py", line 79, in capture_end
super().capture_end()
RuntimeError: CUDA error: operation failed due to a previous error during capture
But applying the max operator is not helping, so I tried to separately define the 2 cases with criteria constraint.
Equations = Model2D(E = E, nu = nu, lambda_=lambda_, mu = mu, rho = 1, beta = beta, flag = 1, r1 = r1, r2 = r2)
DM1 = PointwiseInteriorConstraint(
nodes=nodes,
geometry=geo,
outvar={"f1":0},
criteria= Equations.equations["p"]<r1 and Equations.equations["p"]> -r1,
batch_size=cfg.batch_size.lr_interior,
bounds={x: bounds_x, y: bounds_y, t: bounds_t},
lambda_weighting = {"f1": 1.0},
parameterization={t: bounds_t, x: bounds_x, y: bounds_y},
batch_per_epoch=500,
domain.add_constraint(DM1, "damage_model_1")
DM2 = PointwiseInteriorConstraint(
nodes=nodes,
geometry=geo,
outvar={"f2":0},
criteria= Equations.equations["p"]>=r1 and Equations.equations["p"]=<-r1,
lambda_weighting = {"f2": 1.0},
domain.add_constraint(DM2, "damage_model_2")
But this pops out the following error:
ret = run_job(
[09:11:40] - JIT using the NVFuser TorchScript backend
[09:11:40] - JitManager: {'_enabled': True, '_arch_mode': <JitArchMode.ONLY_ACTIVATION: 1>, '_use_nvfuser': True, '_autograd_nodes': False}
[09:11:40] - GraphManager: {'_func_arch': False, '_debug': False, '_func_arch_allow_partial_hessian': True}
File "damage_model.py", line 220, in run
File "/home/neo11/anaconda3/envs/test_env/lib/python3.8/site-packages/modulus/sym/domain/constraint/continuous.py", line 444, in __init__
invar = geometry.sample_interior(
File "/home/neo11/anaconda3/envs/test_env/lib/python3.8/site-packages/modulus/sym/geometry/geometry.py", line 614, in sample_interior
criteria_index, criteria(local_invar, local_params)
File "/home/neo11/anaconda3/envs/test_env/lib/python3.8/site-packages/modulus/sym/geometry/helper.py", line 89, in criteria
return fn_criteria(**inputs)
File "/home/neo11/anaconda3/envs/test_env/lib/python3.8/site-packages/modulus/sym/utils/sympy/numpy_printer.py", line 158, in grouped_lambda
output.append(lambdify_f_i(**invar))
File "/home/neo11/anaconda3/envs/test_env/lib/python3.8/site-packages/modulus/sym/utils/sympy/numpy_printer.py", line 142, in lambdify_f_i
v = sp_lambdify_f_i(**x)
File "<lambdifygenerated-15>", line 8, in _lambdifygenerated
less(-0.5*sigma_xx(x, y, t)*Derivative(u(x, y, t), x) - 0.5*sigma_xy(x, y, t)*Derivative(v(x, y, t), x) - 0.5*sigma_yy(x, y, t)*Derivative(v(x, y, t), y) - 10*Derivative(d(x, y, t), (x, 2)) - 10*Derivative(d(x, y, t), (y, 2)), 10000.0))
NameError: name 'sigma_xx' is not defined
Set the environment variable HYDRA_FULL_ERROR=1 for a complete stack trace.
So I decided to tweak the script for PointwiseInteriorConstraint as follows:
def __init__(
c2: Union[Dict[str], Callable, None] = None, # intro to new custom-constraint
But even this didn’t helped and now the error is:
ret = run_job(
[08:29:57] - JIT using the NVFuser TorchScript backend
[08:29:57] - JitManager: {'_enabled': True, '_arch_mode': <JitArchMode.ONLY_ACTIVATION: 1>, '_use_nvfuser': True, '_autograd_nodes': False}
[08:29:57] - GraphManager: {'_func_arch': False, '_debug': False, '_func_arch_allow_partial_hessian': True}
TypeError: __init__() got an unexpected keyword argument 'c2'
Now I am out of ideas how I can make it work please help me with the same.
Thank you
Sincerely,
Nihal
