i am using modulus for a problem similar to the “conjugate heat transfer” example.
First i started by setting the equations with time=False like in the example. Everything worked fine. For my problem i need to insert the time variable so i decided to switch to time=True. This resulted in the following error:
[10:19:24] - JIT using the NVFuser TorchScript backend
[10:19:24] - JitManager: {'_enabled': True, '_arch_mode': <JitArchMode.ONLY_ACTIVATION: 1>, '_use_nvfuser': True, '_autograd_nodes': False}
[10:19:24] - GraphManager: {'_func_arch': False, '_debug': False, '_func_arch_allow_partial_hessian': True}
could not unroll graph!
This is probably because you are asking to compute a value that is not an output of any node
invar: [x, y, z, normal_x, normal_y, normal_z, area]
requested var: [u, v, w]
computable var: [x, y, z, normal_x, normal_y, normal_z, area, continuity]
Nodes in graph:
node: Sympy Node: continuity
evaluate: SympyToTorch
inputs: []
derivatives: [u__x, v__y, w__z]
outputs: [continuity]
optimize: False
node: Sympy Node: momentum_x
inputs: [sdf, u, v, w]
derivatives: [p__x, sdf__x, sdf__y, sdf__z, u__t, u__x, u__x__x, u__x__y, u__x__z, u__y, u__y__y, u__y__z, u__z, u__z__z, v__x, v__x__x, v__x__z, v__y, v__y__x, v__y__y, v__y__z, v__z, v__z__z, w__x, w__x__x, w__x__z, w__y, w__y__x, w__y__y, w__y__z, w__z, w__z__z]
outputs: [momentum_x]
optimize: False
node: Sympy Node: momentum_y
derivatives: [p__y, sdf__x, sdf__y, sdf__z, u__x, u__x__x, u__x__y, u__x__z, u__y, u__y__y, u__y__z, u__z, u__z__z, v__t, v__x, v__x__x, v__x__z, v__y, v__y__x, v__y__y, v__y__z, v__z, v__z__z, w__x, w__x__x, w__x__z, w__y, w__y__x, w__y__y, w__y__z, w__z, w__z__z]
outputs: [momentum_y]
optimize: False
node: Sympy Node: momentum_z
derivatives: [p__z, sdf__x, sdf__y, sdf__z, u__x, u__x__x, u__x__y, u__x__z, u__y, u__y__y, u__y__z, u__z, u__z__z, v__x, v__x__x, v__x__z, v__y, v__y__x, v__y__y, v__y__z, v__z, v__z__z, w__t, w__x, w__x__x, w__x__z, w__y, w__y__x, w__y__y, w__y__z, w__z, w__z__z]
outputs: [momentum_z]
optimize: False
node: Sympy Node: nu
inputs: [sdf]
derivatives: [u__x, u__y, u__z, v__x, v__y, v__z, w__x, w__y, w__z]
outputs: [nu]
optimize: False
node: Sympy Node: normal_dot_vel
inputs: [normal_x, normal_y, normal_z, u, v, w]
derivatives: []
outputs: [normal_dot_vel]
optimize: False
node: Arch Node: flow_network
evaluate: FullyConnectedArch
inputs: [x, y, z, t]
derivatives: []
outputs: [u, v, w, p]
optimize: True
Error executing job with overrides: []
File "fullyConnected_5_256_time_inferencer_flow.py", line 70, in run
inferencer_1 = PointwiseInferencer(
File "/modulus/modulus/domain/inferencer/pointwise.py", line 66, in __init__
self.model = Graph(
File "/modulus/modulus/graph.py", line 94, in __init__
raise RuntimeError("Failed Unrolling Graph")
RuntimeError: Failed Unrolling Graph
Set the environment variable HYDRA_FULL_ERROR=1 for a complete stack trace.
Below is my code:
nu = 1.9531 * pow(10, -5)
rho = 3.233386
geo = MyGeometry()
ze = ZeroEquation(nu=nu, dim=3, time=True, max_distance=geo.channel_radius)
ns = NavierStokes(nu=ze.equations["nu"], rho=rho, dim=3, time=True)
navier_stokes_nodes = ns.make_nodes() + ze.make_nodes()
normal_dot_vel = NormalDotVec()
input_keys = [Key("x"), Key("y"), Key("z"), Key("t")]
flow_net = FullyConnectedArch(input_keys=input_keys, output_keys=[Key("u"), Key("v"), Key("w"), Key("p")], nr_layers=5, layer_siz>
flow_nodes = (navier_stokes_nodes + normal_dot_vel.make_nodes() + [flow_net.make_node(name="flow_network")])
inlet_vel = 3.54
flow_domain = Domain()
x = Symbol("x")
y = Symbol("y")
z = Symbol("z")
t = Symbol("t")
invar=geo.longitudinal_section_plane_x0.sample_boundary(50000),
output_names=["u", "v", "w"],
nodes=flow_nodes,
flow_domain.add_inferencer(inferencer_1, "longitudinal_section_1")
# Inlet
constraint_inlet = PointwiseBoundaryConstraint(
nodes=flow_nodes,
geometry=geo.square_inlet,
outvar={"u": 0, "v": 0, "w": inlet_vel},
batch_size=cfg.batch_size.Inlet,
lambda_weighting={
"u": 1.0,
"v": 1.0,
"w": 1.0,
}, # weight zero on edges
criteria = pow(x, 2) + pow(y, 2) <= pow(geo.channel_radius, 2),
batch_per_epoch=5000,
flow_domain.add_constraint(constraint_inlet, "inlet")
After this, like in “Conjugate heat transfer” example, i define other constraints for the full geometry. Then i call the solve() function:
# make solver
flow_slv = Solver(cfg, flow_domain)
# start flow solver
flow_slv.solve()
flow_slv.eval()
Even if i change the line input_keys = [Key("x"), Key("y"), Key("z"), Key("t")] in input_keys = [Key("x"), Key("y"), Key("z")] the inferencers and the constraints run but the solver have the following error:
[10:31:06] - attempting to restore from: outputs/fullyConnected_5_256_time_inferencer_flow
[10:31:06] - optimizer checkpoint not found
[10:31:06] - model flow_network.0.pth not found
File "fullyConnected_5_256_time_inferencer_flow.py", line 237, in run
flow_slv.solve()
File "/modulus/modulus/solver/solver.py", line 159, in solve
self._train_loop(sigterm_handler)
File "/modulus/modulus/trainer.py", line 521, in _train_loop
loss, losses = self._cuda_graph_training_step(step)
File "/modulus/modulus/trainer.py", line 702, in _cuda_graph_training_step
self.loss_static, self.losses_static = self.compute_gradients(
File "/modulus/modulus/trainer.py", line 54, in adam_compute_gradients
losses_minibatch = self.compute_losses(step)
File "/modulus/modulus/solver/solver.py", line 52, in compute_losses
return self.domain.compute_losses(step)
File "/modulus/modulus/domain/domain.py", line 133, in compute_losses
constraint.forward()
File "/modulus/modulus/domain/constraint/continuous.py", line 116, in forward
self._output_vars = self.model(self._input_vars)
File "/opt/conda/lib/python3.8/site-packages/torch/nn/modules/module.py", line 1186, in _call_impl
return forward_call(*input, **kwargs)
File "/modulus/modulus/graph.py", line 220, in forward
outvar.update(e(outvar))
File "/modulus/modulus/eq/derivatives.py", line 84, in forward
grad_var = self.prepare_input(input_var, grad_sizes.keys())
File "/modulus/modulus/eq/derivatives.py", line 72, in prepare_input
return [input_variables[x] for x in mask]
File "/modulus/modulus/eq/derivatives.py", line 72, in <listcomp>
KeyError: 't'
Since there are no examples in the guide with time=True i don’t understand where i went wrong.
I appreciate any suggestions.
