Failed Unrolling Graph with tabular data
I am trying to create a FNN that would predict 163 target variables based on 21 input variables. The vectors are saved in CSV files which I load as dataframe and then convert to dicts. However, I am facing errors when I try to create the network. We want to do it in modulus as we expect to add physics on top of the data later, but now data-driven model is enough. Right now I use older version of modulus, if that matters.
In the below code if I do network = FullyConnectedArch( input_keys=[Key("t0")], output_keys=[Key("Entw1SiiIVentilKV1t3")]) (just test some of the variables in the files, then I get error:
Nodes in graph:
node: Arch Node: net
evaluate: FullyConnectedArch
inputs: [t0]
derivatives:
outputs: [Entw1SiiIVentilKV1t3]
optimize: True
Error executing job with overrides:
File “/root/Downloads/aufer_design/aufer.py”, line 84, in run
validator = PointwiseValidator(
File “/opt/conda/lib/python3.8/site-packages/modulus-22.9-py3.8.egg/modulus/domain/validator/continuous.py”, line 64, in init
self.model = Graph(
File “/opt/conda/lib/python3.8/site-packages/modulus-22.9-py3.8.egg/modulus/graph.py”, line 94, in init
raise RuntimeError(“Failed Unrolling Graph”)
RuntimeError: Failed Unrolling Graph
If I want to train on whole dataset with the code network = FullyConnectedArch( input_keys=inkeys, output_keys=outkeys), then it fails to initialize optimizer:
10:05:04] - Failed to initialize optimizer:
target: torch.optim.Adam
lr: 0.001
betas:
  • 0.9
  • 0.999
    eps: 1.0e-08
    weight_decay: 0.0
    amsgrad: false
File “/opt/conda/lib/python3.8/site-packages/hydra/_internal/instantiate/_instantiate2.py”, line 62, in _call_target
return target(*args, **kwargs)
File “/opt/conda/lib/python3.8/site-packages/torch/optim/adam.py”, line 90, in init
super(Adam, self).init(params, defaults)
File “/opt/conda/lib/python3.8/site-packages/torch/optim/optimizer.py”, line 49, in init
raise ValueError(“optimizer got an empty parameter list”)
ValueError: optimizer got an empty parameter list
During handling of the above exception, another exception occurred:
File “/opt/conda/lib/python3.8/site-packages/modulus-22.9-py3.8.egg/modulus/hydra/utils.py”, line 224, in instantiate_optim
optimizer = hydra.utils.instantiate(optim_cfg, params=model.parameters())
File “/opt/conda/lib/python3.8/site-packages/hydra/_internal/instantiate/_instantiate2.py”, line 180, in instantiate
return instantiate_node(config, *args, recursive=recursive, convert=convert)
File “/opt/conda/lib/python3.8/site-packages/hydra/_internal/instantiate/_instantiate2.py”, line 249, in instantiate_node
return _call_target(target, *args, **kwargs)
File “/opt/conda/lib/python3.8/site-packages/hydra/_internal/instantiate/_instantiate2.py”, line 64, in _call_target
raise type(e)(
ValueError: Error instantiating ‘torch.optim.adam.Adam’ : optimizer got an empty parameter list
The above exception was the direct cause of the following exception:
File “/root/Downloads/aufer_design/aufer.py”, line 98, in run
slv.solve()
File “/opt/conda/lib/python3.8/site-packages/modulus-22.9-py3.8.egg/modulus/solver/solver.py”, line 159, in solve
self._train_loop(sigterm_handler)
File “/opt/conda/lib/python3.8/site-packages/modulus-22.9-py3.8.egg/modulus/trainer.py”, line 396, in _train_loop
self.optimizer = instantiate_optim(self.cfg, model=self.global_optimizer_model)
File “/opt/conda/lib/python3.8/site-packages/modulus-22.9-py3.8.egg/modulus/hydra/utils.py”, line 228, in instantiate_optim
raise Exception(fail) from e
Exception: Failed to initialize optimizer:
Here is my config file:
defaults :
  - modulus_default
  - arch:
      - fully_connected
  - scheduler: tf_exponential_lr
  - optimizer: adam
  - loss: sum
  - _self_
run_mode: "train"
scheduler:
  decay_rate: 0.95
  decay_steps: 500
training:
  rec_results_freq: 5000
  max_steps : 10000
Here is the code:
import numpy as np
import pandas as pd
import modulus as md
from modulus.key import Key
import matplotlib
import matplotlib.pyplot as plt
from sklearn.model_selection import train_test_split
from modulus.domain.validator import PointwiseValidator
from modulus.utils.io.plotter import ValidatorPlotter, InferencerPlotter
from modulus.domain import Domain
from modulus.solver import Solver
from modulus.models.fully_connected import FullyConnectedArch
@md.main(config_path="conf", config_name="config")
def run(cfg: md.hydra.ModulusConfig) -> None:
    input_vectors = pd.read_csv("/input_data.csv")
    output_vectors = pd.read_csv("/output_data.csv")
    input_vectors.columns = input_vectors.columns.str.replace('[^a-zA-Z0-9]', '', regex=True)
    output_vectors.columns = output_vectors.columns.str.replace('[^a-zA-Z0-9]', '', regex=True)
    input_keys = input_vectors.columns.tolist()
    output_keys = output_vectors.columns.tolist()
    input_vects = input_vectors.to_numpy()
    output_vects = output_vectors.to_numpy()
    input_vectors = input_vectors.to_dict(orient='list')
    output_vectors = output_vectors.to_dict(orient='list')
    inkeys = [Key(x) for x in input_keys]
    outkeys = [Key(x) for x in output_keys]
    nodes = (
        [network.make_node(name="net")]
    domain = Domain()
        nodes=nodes,
        invar=input_vectors,
        true_outvar=output_vectors,
        plotter=ValidatorPlotter(),
    domain.add_validator(validator)
    slv = Solver(cfg, domain)
    slv.solve()
if __name__ == "__main__":
    run()
Can somebody hint me where the problem might come from? I can’t share data as they are confidential.
Hi @MarekRuzicka
The error:
Means you’re requesting some variable to be computed that cant. What are the names of the variables in output_vectors. Based on the script you provided it should be {'Entw1SiiIVentilKV1t3': np.array(N,1)}. Similarly input_vectors should be something like {'t0': np.array(N,1)}.
Theres some other posts about this error that could help:
I now define data as:
input_vectors = {col: np.reshape(input_vectors[col].to_numpy(), (-1,1)) for col in input_vectors.columns}
which produces dict as {str:np.ndarray, str:np.ndarray, ... } and similarly for output vectors. I tried with Key(col) also but it made no difference. I am still getting the same error with failed unrolling the graph.
if I try to do
        input_keys=[Key("t0")], output_keys=outkeys
This ends up with the “Failed initiaze optimizer”, while if I change also input_keys=inkeys, then I get “Failed unrolling graph” again. This could indicate that there is some mess with inputs, but they are all of same shape, with unique names… So right now I have no idea where is the problem.
Here is example how data look like:
[[315]
[315]
[315]
[525]
[500]
[485]]
I have also noticed that I was using input key for output_keys definition which is now fixed but didn’t help at all.
So I have edited the code and unexpectedly changing FullyConnectedArch to md.hydra.instantiate_arch() solved the problem with failed unrolling graph after reshaping the input/output. I have no idea why the first didn’t work for me. I have found out that I have forgotten to provide initial condition so the network knew nothing about where to start, thats why the error with optimizer. Here is the updated, working code:
import numpy as np
import pandas as pd
from modulus.models.modified_fourier_net import ModifiedFourierNetArch
import matplotlib
from modulus.domain.constraint import (
    PointwiseBoundaryConstraint,
    PointwiseInteriorConstraint,
    PointwiseConstraint,
from sklearn.preprocessing import MinMaxScaler
    input_vectors = pd.read_csv("/root/Downloads/aufer_design/input_data.csv")
    output_vectors = pd.read_csv("/root/Downloads/aufer_design/output_data.csv")
    scaler = MinMaxScaler()
    input_vectors_scaled = scaler.fit_transform(input_vectors.to_numpy())
    input_vectors = pd.DataFrame(input_vectors_scaled, columns = input_vectors.columns)
    output_vectors_scaled = scaler.fit_transform(output_vectors.to_numpy())
    output_vectors = pd.DataFrame(output_vectors_scaled, columns = output_vectors.columns)
    output_vectors = {col: np.reshape(output_vectors[col].to_numpy(), (-1,1)) for col in output_vectors.columns}
    print("Creating model...")
    cfg.arch.fully_connected.layer_size = 128
    network = md.hydra.instantiate_arch(
        input_keys=inkeys,
        output_keys=outkeys,
        cfg=cfg.arch.fully_connected,
    print("Done.")
    nodes = (
        [network.make_node(name="net"), ]
    print("Created nodes.")
    domain = Domain()
    #  batch size must be greater than 1!
    bs = 16
    index = 0 # choose the first index of the data
    invar = {key: np.reshape(input_vectors[key][index:bs], (bs,1)) for key in input_keys} # get the input variables at the index
    outvar = {key: np.reshape(output_vectors[key][index:bs], (bs,1)) for key in output_keys} # get the output variables at the index
    initial_condition = PointwiseConstraint.from_numpy(
        nodes,
        invar,
        outvar,
        batch_size=bs,
    domain.add_constraint(initial_condition, "IC")
    print("added validator")
    # make solver
    # start solver
    slv.solve()
    run()
