I have been attending the course: Introduction to Physics Informed Machine Learning’ and I tried to run the code from it in Google colab.
Code:
!pip install nvidia-modulus nvidia-modulus-sym
import modulus
from modulus.sym.hydra import ModulusConfig, instantiate_arch
from modulus.sym.solver import Solver
from modulus.sym.domain import Domain
from modulus.sym.geometry.primitives_1d import Line1D
from modulus.sym.geometry import Parameterization
from modulus.sym.domain.constraint import (
PointwiseBoundaryConstraint,
PointwiseInteriorConstraint,
from modulus.sym.domain.validator import PointwiseValidator
from modulus.sym.domain.monitor import PointwiseMonitor
from modulus.sym.key import Key
from modulus.sym.node import Node
from modulus.sym.eq.pde import PDE
#check
@modulus.sym.main(config_path=“conf”, config_name=“config”)
def run(cfg: ModulusConfig):
print(to_yaml(cfg))
if name == “main”:
run()
Doubt:
This results in error. On running the codes separately, I noticed the below code caused error.
if __ name __ == “__ main __”:
run()
Error:
WARNING:modulus.sym.hydra.config:TorchScript default is being turned off due to PyTorch version mismatch.
usage: colab_kernel_launcher.py [–help] [–hydra-help] [–version] [–cfg {job,hydra,all}]
[–resolve] [–package PACKAGE] [–run] [–multirun]
[–shell-completion] [–config-path CONFIG_PATH]
[–config-name CONFIG_NAME] [–config-dir CONFIG_DIR]
[–experimental-rerun EXPERIMENTAL_RERUN]
[–info [{all,config,defaults,defaults-tree,plugins,searchpath}]]
[overrides …]
colab_kernel_launcher.py: error: unrecognized arguments: -f
An exception has occurred, use %tb to see the full traceback.
SystemExit: 2
If any of you have any idea, please let me know
