After I installed all modules, I tried to run an example case in modulus sym: ldc. I run python ldc_2d.py and got following error. I did this on my laptop with onboard graphic card. I assume the issue is with “RuntimeError: CUDA error: no CUDA-capable device is detected” and somehow I cannot tell the software to use CPU:
File “ldc_2d.py”, line 136, in run
slv.solve()
File “/home/pasha/.local/lib/python3.8/site-packages/modulus/sym/solver/solver.py”, line 173, in solve
self._train_loop(sigterm_handler)
File “/home/pasha/.local/lib/python3.8/site-packages/modulus/sym/trainer.py”, line 535, in _train_loop
loss, losses = self._cuda_graph_training_step(step)
File “/home/pasha/.local/lib/python3.8/site-packages/modulus/sym/trainer.py”, line 708, in _cuda_graph_training_step
self.warmup_stream = torch.cuda.Stream()
File “/home/pasha/.local/lib/python3.8/site-packages/torch/cuda/streams.py”, line 34, in new
return super(Stream, cls).__new__(cls, priority=priority, **kwargs)
CUDA kernel errors might be asynchronously reported at some other API call, so the stacktrace below might be incorrect.
For debugging consider passing CUDA_LAUNCH_BLOCKING=1.
Device-side assertions were explicitly omitted for this error check; the error probably arose while initializing the DSA handlers.
Set the environment variable HYDRA_FULL_ERROR=1 for a complete stack trace.
Thank you very much for your help,
Pasha
