We are testing custom board and there are PCIe switch IC(PI7C9X2G608) and Ethernet controller(I210).
The PCIe switch has no issue where the lspci command.
But ethernet controller is problem.
And I found that link
I wonder how I can solve, if there is a VDM issue?
There is no solution from us as this is the issue from Intel. If you are still using jeton nano, then it will hit issue with i210.
system
Closed
5
