Hi everyone,
I get a problem on Jetson nano when try to connect Intel-i210 by M2.key slot.It seems the lspci get the IntelI210,but when I insmod the igb.ko ,the kernel get crash. can you help me to find out what’s the problem with it?
The error message:
sudo insmod ./igb.ko
[ 1460.957443] CPU3: SError detected, daif=1c0, spsr=0x40000045, mpidr=80000003, esr=bf000002
[ 1482.019507] CPU3: SError detected, daif=1c0, spsr=0xc5, mpidr=80000003, esr=bf000002
[ 1482.019545] INFO: rcu_preempt detected stalls on CPUs/tasks:
[ 1482.019551] 3-…: (1 GPs behind) idle=0df/140000000000001/0 softirq=16416/16418 fqs=1
[ 1482.019555] (detected by 2, t=5266 jiffies, g=3870, c=3869, q=6)
[ 1482.019579] rcu_preempt kthread starved for 5264 jiffies! g3870 c3869 f0x0 RCU_GP_WAIT_FQS(3) ->state=0x1
[ 1503.110381] CPU3: SError detected, daif=1c0, spsr=0x800000c5, mpidr=80000003, esr=bf000002
[ 1524.172397] CPU3: SError detected, daif=1c0, spsr=0x800000c5, mpidr=80000003, esr=bf000002
[ 1545.234757] CPU3: SError detected, daif=1c0, spsr=0x200000c5, mpidr=80000003, esr=bf000002
[ 1566.296835] NMI watchdog: BUG: soft lockup - CPU#2 stuck for 39s! [dnsmasq:5991]
[ 1566.304568] Kernel panic - not syncing: softlockup: hung tasks
[ 1566.310400] CPU: 2 PID: 5991 Comm: dnsmasq Tainted: G L 4.9.201-wtoe #43
[ 1566.318219] Hardware name: NVIDIA Jetson Nano Developer Kit (DT)
[ 1566.324217] Call trace:
[ 1566.326670] [] dump_backtrace+0x0/0x198
[ 1566.332068] [] show_stack+0x24/0x30
[ 1566.337116] [] dump_stack+0xa0/0xc8
[ 1566.342166] [] panic+0x12c/0x2a8
[ 1566.346955] [] watchdog_unpark_threads+0x0/0x98
[ 1566.353043] [] __hrtimer_run_queues+0xd8/0x360
[ 1566.359042] [] hrtimer_interrupt+0xa8/0x1e0
[ 1566.364785] [] tegra210_timer_isr+0x38/0x48
[ 1566.370526] [] __handle_irq_event_percpu+0x68/0x288
[ 1566.376960] [] handle_irq_event_percpu+0x28/0x60
[ 1566.383133] [] handle_irq_event+0x50/0x80
[ 1566.388702] [] handle_fasteoi_irq+0xd4/0x1c0
[ 1566.394528] [] generic_handle_irq+0x34/0x50
[ 1566.400268] [] __handle_domain_irq+0x68/0xc0
[ 1566.406093] [] gic_handle_irq+0x5c/0xb0
[ 1566.411487] [] el1_irq+0xe8/0x194
[ 1566.416363] [] _raw_spin_unlock_irqrestore+0x34/0x60
[ 1566.422886] [] __wake_up_sync_key+0x64/0x78
[ 1566.428628] [] sock_def_readable+0x48/0x80
[ 1566.434281] [] __sock_queue_rcv_skb+0x124/0x258
[ 1566.440371] [] __udp_queue_rcv_skb+0x60/0x280
[ 1566.446285] [] udp_queue_rcv_skb+0x354/0x540
[ 1566.452113] [] udp_unicast_rcv_skb+0x60/0xb8
[ 1566.457940] [] __udp4_lib_rcv+0x4c4/0xaa8
[ 1566.463507] [] udp_rcv+0x30/0x40
[ 1566.468297] [] ip_local_deliver_finish+0x80/0x280
[ 1566.474557] [] ip_local_deliver+0x54/0xf0
[ 1566.480124] [] ip_rcv_finish+0x1f8/0x380
[ 1566.485605] [] ip_rcv+0x284/0x390
[ 1566.490481] [] __netif_receive_skb_core+0x3b8/0xad8
[ 1566.496916] [] __netif_receive_skb+0x28/0x78
[ 1566.502745] [] process_backlog+0x94/0x140
[ 1566.508314] [] net_rx_action+0xf4/0x358
[ 1566.513707] [] __do_softirq+0x13c/0x3b0
[ 1566.519103] [] do_softirq.part.3+0x68/0x70
[ 1566.524759] [] __local_bh_enable_ip+0xcc/0xf0
[ 1566.530673] [] ip_finish_output2+0x140/0x480
[ 1566.536500] [] ip_finish_output+0x128/0x200
[ 1566.542240] [] ip_output+0xf4/0x180
[ 1566.547288] [] ip_local_out+0x58/0x68
[ 1566.552508] [] ip_send_skb+0x2c/0xb8
[ 1566.557642] [] udp_send_skb+0x16c/0x2a8
[ 1566.563036] [] udp_sendmsg+0x2e4/0x918
[ 1566.568346] [] inet_sendmsg+0xa4/0xd8
[ 1566.573569] [] sock_sendmsg+0x4c/0x68
[ 1566.578791] [] SyS_sendto+0xa0/0x130
[ 1566.583924] [] el0_svc_naked+0x34/0x38
[ 1566.589233] SMP: stopping secondary CPUs
[ 1567.759164] SMP: failed to stop secondary CPUs 1-3
[ 1567.763955] Kernel Offset: disabled
[ 1567.767444] Memory Limit: none
[ 1567.790521] Rebooting in 5 seconds…
There are some information will help:
dmesg |grep pci
[ 1.678656] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[ 1.679067] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[ 1.679433] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[ 1.679796] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[ 1.680131] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[ 1.680454] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[ 1.680786] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[ 1.693929] PCIE: tegra_pcie_probe(4755)
[ 1.693976] PCIE: tegra_pcie_read_plat_data(3243)
[ 1.695795] PCIE: tegra_pcie_parse_dt(3345)
[ 1.696098] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[ 1.697403] PCIE: tegra_pcie_config_clkreq(827)
[ 1.697435] PCIE: tegra_pcie_config_clkreq(827)
[ 1.697487] PCIE: tegra_pcie_probe_complete(4635)
[ 1.697503] PCIE: tegra_pcie_init(2805)
[ 1.697518] PCIE: tegra_pcie_get_resources(1940)
[ 1.697533] PCIE: tegra_pcie_get_clocks(1303)
[ 1.697701] PCIE: tegra_pcie_enable_regulators(1553)
[ 1.697720] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[ 1.697934] PCIE: tegra_pcie_power_on(1824)
[ 1.697958] PCIE: tegra_pcie_restore_device(1765)
[ 1.698003] PCIE: tegra_pcie_module_power_on(1717)
[ 1.698019] PCIE: tegra_pcie_enable_regulators(1553)
[ 1.698196] PCIE: tegra_pcie_map_resources(1598)
[ 1.698311] PCIE: tegra_pcie_enable_pads(1442)
[ 1.698341] PCIE: tegra_pcie_enable_controller(1485)
[ 1.698356] PCIE: tegra_pcie_enable_wrap(1464)
[ 1.698470] PCIE: tegra_pcie_enable_msi(3042)
[ 1.698489] PCIE: tegra_pcie_check_ports(2496)
[ 1.698510] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[ 1.698526] PCIE: tegra_pcie_port_enable(2024)
[ 1.698541] PCIE: tegra_pcie_port_reset(1995)
[ 1.700585] PCIE: tegra_pcie_enable_rp_features(2365)
[ 1.700631] PCIE: tegra_pcie_enable_aer(1044)
[ 1.700648] PCIE: tegra_pcie_apply_sw_war(2207)
[ 1.701016] PCIE: tegra_pcie_prsnt_map_override(1102)
[ 1.701038] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[ 1.701053] PCIE: tegra_pcie_port_enable(2024)
[ 1.701068] PCIE: tegra_pcie_port_reset(1995)
[ 1.704535] PCIE: tegra_pcie_enable_rp_features(2365)
[ 1.704579] PCIE: tegra_pcie_enable_aer(1044)
[ 1.704597] PCIE: tegra_pcie_apply_sw_war(2207)
[ 1.704801] PCIE: tegra_pcie_prsnt_map_override(1102)
[ 1.735095] PCIE: tegra_pcie_link_speed(2778)
[ 1.741218] PCIE: tegra_pcie_scale_voltage(2653)
[ 1.741475] PCIE: tegra_pcie_conf_gpios(2550)
[ 1.741552] PCIE: tegra_pcie_enable_msi(3042)
[ 1.742582] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[ 1.742596] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 1.742605] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 1.742617] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 1.742627] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.742687] pci 0000:00:01.0: [10de:0fae] type 01 class 0x060400
[ 1.742816] pci 0000:00:01.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.743645] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[ 1.743766] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.744764] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.744799] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.745285] PCIE: tegra_pcie_add_bus(780)
[ 1.745300] PCIE: tegra_pcie_bus_alloc(592)
[ 1.745439] pci 0000:01:00.0: [8086:1533] type 00 class 0x020000
[ 1.745479] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x000fffff]
[ 1.745520] pci 0000:01:00.0: reg 0x1c: [mem 0x00000000-0x00003fff]
[ 1.745562] pci 0000:01:00.0: reg 0x30: [mem 0x00000000-0x000fffff pref]
[ 1.745738] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[ 2.254928] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 2.255634] PCIE: tegra_pcie_add_bus(780)
[ 2.255658] PCIE: tegra_pcie_bus_alloc(592)
[ 2.255740] pci 0000:02:00.0: [10ec:8168] type 00 class 0x020000
[ 2.255774] pci 0000:02:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 2.255810] pci 0000:02:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 2.255834] pci 0000:02:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 2.256023] pci 0000:02:00.0: supports D1 D2
[ 2.256029] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.267253] pci_bus 0000:02: busn_res: [bus 02-ff] end is updated to 02
[ 2.267359] pci 0000:00:01.0: BAR 14: assigned [mem 0x13000000-0x132fffff]
[ 2.267389] pci 0000:00:02.0: BAR 14: assigned [mem 0x13300000-0x133fffff]
[ 2.267405] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 2.267453] pci 0000:01:00.0: BAR 0: assigned [mem 0x13000000-0x130fffff]
[ 2.267477] pci 0000:01:00.0: BAR 6: assigned [mem 0x13100000-0x131fffff pref]
[ 2.267492] pci 0000:01:00.0: BAR 3: assigned [mem 0x13200000-0x13203fff]
[ 2.267520] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 2.267537] pci 0000:00:01.0: bridge window [mem 0x13000000-0x132fffff]
[ 2.267580] pci 0000:02:00.0: BAR 4: assigned [mem 0x13300000-0x13303fff 64bit]
[ 2.267611] pci 0000:02:00.0: BAR 2: assigned [mem 0x13304000-0x13304fff 64bit]
[ 2.267640] pci 0000:02:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 2.267666] pci 0000:00:02.0: PCI bridge to [bus 02]
[ 2.267680] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 2.267694] pci 0000:00:02.0: bridge window [mem 0x13300000-0x133fffff]
[ 2.267713] PCIE: tegra_pcie_configure_aspm(920)
[ 2.267784] PCIE: tegra_pcie_config_clkreq(827)
[ 2.267817] PCIE: tegra_pcie_enable_ltr_support(879)
[ 2.267894] PCIE: tegra_pcie_enable_features(2790)
[ 2.267905] PCIE: tegra_pcie_apply_sw_war(2207)
[ 2.267917] PCIE: tegra_pcie_apply_sw_war(2207)
[ 2.268948] pcieport 0000:00:01.0: Signaling PME through PCIe PME interrupt
[ 2.268973] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 2.268991] pcie_pme 0000:00:01.0:pcie001: service driver pcie_pme loaded
[ 2.269505] aer 0000:00:01.0:pcie002: service driver aer loaded
[ 2.270180] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 2.270204] pci 0000:02:00.0: Signaling PME through PCIe PME interrupt
[ 2.270220] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[ 2.270774] aer 0000:00:02.0:pcie002: service driver aer loaded
[ 5.468154] ehci-pci: EHCI PCI platform driver
[ 5.478966] ohci-pci: OHCI PCI platform driver -
lspci
00:01.0 PCI bridge: NVIDIA Corporation Device 0fae (rev a1)
00:02.0 PCI bridge: NVIDIA Corporation Device 0faf (rev a1)
01:00.0 Ethernet controller: Intel Corporation I210 Gigabit Network Connection (rev 03)
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15) -
lspci -vvv
00:01.0 PCI bridge: NVIDIA Corporation Device 0fae (rev a1) (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 84
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 0000f000-00000fff
Memory behind bridge: 13000000-132fffff
Prefetchable memory behind bridge: 00000000fff00000-00000000000fffff
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
Capabilities: [40] Subsystem: NVIDIA Corporation Device 0000
Capabilities: [48] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [50] MSI: Enable- Count=1/2 Maskable- 64bit+
Address: 0000000000000000 Data: 0000
Capabilities: [60] HyperTransport: MSI Mapping Enable- Fixed-
Mapping Address Base: 00000000fee00000
Capabilities: [80] Express (v2) Root Port (Slot+), MSI 00
DevCap: MaxPayload 128 bytes, PhantFunc 0
ExtTag+ RBE+
DevCtl: Report errors: Correctable+ Non-Fatal+ Fatal+ Unsupported+
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
MaxPayload 128 bytes, MaxReadReq 512 bytes
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
LnkCap: Port #0, Speed 5GT/s, Width x4, ASPM L0s L1, Exit Latency L0s <512ns, L1 <4us
ClockPM- Surprise- LLActRep+ BwNot+ ASPMOptComp-
LnkCtl: ASPM L1 Enabled; RCB 64 bytes Disabled- CommClk+
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive+ BWMgmt- ABWMgmt-
SltCap: AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug- Surprise-
Slot #0, PowerLimit 0.000W; Interlock- NoCompl-
SltCtl: Enable: AttnBtn- PwrFlt- MRL- PresDet- CmdCplt- HPIrq- LinkChg-
Control: AttnInd Off, PwrInd On, Power- Interlock-
SltSta: Status: AttnBtn- PowerFlt- MRL- CmdCplt- PresDet+ Interlock-
Changed: MRL- PresDet+ LinkState+
RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna+ CRSVisible-
RootCap: CRSVisible-
RootSta: PME ReqID 0000, PMEStatus- PMEPending-
DevCap2: Completion Timeout: Range AB, TimeoutDis+, LTR+, OBFF Not Supported ARIFwd-
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR+, OBFF Disabled ARIFwd-
LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete-, EqualizationPhase1-
EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
Capabilities: [100 v1] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES- TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
AERCap: First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn-
Capabilities: [140 v1] L1 PM Substates
L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
PortCommonModeRestoreTime=30us PortTPowerOnTime=70us
L1SubCtl1: PCI-PM_L1.2- PCI-PM_L1.1- ASPM_L1.2- ASPM_L1.1-
T_CommonMode=30us LTR1.2_Threshold=0ns
L1SubCtl2: T_PwrOn=70us
Kernel driver in use: pcieport
00:02.0 PCI bridge: NVIDIA Corporation Device 0faf (rev a1) (prog-if 00 [Normal decode])
Latency: 0
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 00001000-00001fff
Memory behind bridge: 13300000-133fffff
ExtTag+ RBE+
LnkCap: Port #1, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <512ns, L1 <4us
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk+
T_CommonMode=150us LTR1.2_Threshold=294912ns
L1SubCtl2: T_PwrOn=150us
Subsystem: Intel Corporation Ethernet Server Adapter I210-T1
Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Region 0: Memory at 13000000 (32-bit, non-prefetchable) [disabled] [size=1M]
Region 3: Memory at 13200000 (32-bit, non-prefetchable) [disabled] [size=16K]
[virtual] Expansion ROM at 13100000 [disabled] [size=1M]
Capabilities: [40] Power Management version 3
Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=1 PME-
Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
Masking: 00000000 Pending: 00000000
Capabilities: [70] MSI-X: Enable- Count=5 Masked-
Vector table: BAR=3 offset=00000000
PBA: BAR=3 offset=00002000
Capabilities: [a0] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 512 bytes, PhantFunc 0, Latency L0s <512ns, L1 <64us
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 0.000W
DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+ FLReset-
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr+ TransPend-
LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <2us, L1 <16us
ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp+
LnkCtl: ASPM L0s L1 Enabled; RCB 64 bytes Disabled- CommClk+
LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, LTR-, OBFF Not Supported
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
LnkCtl2: Target Link Speed: 2.5GT/s, EnterCompliance- SpeedDis-
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
Capabilities: [100 v2] Advanced Error Reporting
UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
Capabilities: [140 v1] Device Serial Number 00-1b-21-ff-ff-e2-89-13
Capabilities: [1a0 v1] Transaction Processing Hints
Device specific mode supported
Steering table in TPH capability structure
Kernel modules: igb
Subsystem: Realtek Semiconductor Co., Ltd. RTL8111/8168 PCI Express Gigabit Ethernet controller
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 407
Region 0: I/O ports at 1000 [size=256]
Region 2: Memory at 13304000 (64-bit, non-prefetchable) [size=4K]
Region 4: Memory at 13300000 (64-bit, non-prefetchable) [size=16K]
Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=375mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [50] MSI: Enable+ Count=1/1 Maskable- 64bit+
Address: 00000000fa80b000 Data: 0000
Capabilities: [70] Express (v2) Endpoint, MSI 01
DevCap: MaxPayload 128 bytes, PhantFunc 0, Latency L0s <512ns, L1 <64us
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset- SlotPowerLimit 0.000W
DevCtl: Report errors: Correctable- Non-Fatal- Fata[ 1397.332909] r8168 0000:02:00.0: invalid short VPD tag 00 at offset 1
l- Unsupported-
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop-
MaxPayload 128 bytes, MaxReadReq 4096 bytes
LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s unlimited, L1 <64us
ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, LTR+, OBFF Via message/WAKE#
Capabilities: [b0] MSI-X: Enable- Count=4 Masked-
Vector table: BAR=4 offset=00000000
PBA: BAR=4 offset=00000800
Capabilities: [d0] Vital Product Data
pcilib: sysfs_read_vpd: read failed: Input/output error
Not readable
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq+ ACSViol-
Capabilities: [140 v1] Virtual Channel
Caps: LPEVC=0 RefClk=100ns PATEntryBits=1
Arb: Fixed- WRR32- WRR64- WRR128-
Ctrl: ArbSelect=Fixed
Status: InProgress-
VC0: Caps: PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
Arb: Fixed- WRR32- WRR64- WRR128- TWRR128- WRR256-
Ctrl: Enable+ ID=0 ArbSelect=Fixed TC/VC=ff
Status: NegoPending- InProgress-
Capabilities: [160 v1] Device Serial Number 00-00-00-00-00-00-00-00
Capabilities: [170 v1] Latency Tolerance Reporting
Max snoop latency: 0ns
Max no snoop latency: 0ns
Capabilities: [178 v1] L1 PM Substates
PortCommonModeRestoreTime=150us PortTPowerOnTime=150us
T_CommonMode=0us LTR1.2_Threshold=294912ns
Kernel driver in use: r8168
Kernel modules: r8168
If anyone known what’s wrong with it, tell me please, thanks for your replies
