This is the entire output when run lsusb -t
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci-tegra/3p, 5000M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 5000M
|__ Port 3: Dev 3, If 0, Class=Hub, Driver=hub/4p, 5000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci-tegra/4p, 480M
|__ Port 2: Dev 2, If 0, Class=Hub, Driver=hub/5p, 480M
|__ Port 1: Dev 38, If 0, Class=Vendor Specific Class, Driver=, 12M
|__ Port 2: Dev 39, If 0, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 2: Dev 39, If 1, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 3: Dev 5, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 1: Dev 19, If 0, Class=Human Interface Device, Driver=usbfs, 12M
|__ Port 1: Dev 19, If 1, Class=Human Interface Device, Driver=usbfs, 12M
|__ Port 1: Dev 19, If 2, Class=Human Interface Device, Driver=usbfs, 12M
|__ Port 4: Dev 40, If 0, Class=Communications, Driver=cdc_acm, 12M
|__ Port 4: Dev 40, If 1, Class=CDC Data, Driver=cdc_acm, 12M
|__ Port 4: Dev 36, If 0, Class=Vendor Specific Class, Driver=, 480M
|__ Port 5: Dev 7, If 0, Class=, Driver=, 480M
