Is it possible to interface Adafruit I2S MEMS Microphone Breakout - SPH0645LM4H with Nvidia Jetson AGX Orin. If it is possible then where can I get the drivers to interface. It is good to recommend some microphone array which is compatible with Nvidia Jetson AGX Orin using I2S interface.
Thank you.
Jetson supports I2S interfaces and any MIC array that supports I2S interface can be used in theoretically.
We don’t have any recommended MIC parts.
Ok. Thank you
What are briefly the steps needed for getting audio from the aforementioned microphone device in AGX Orin? I am reading the guide here but I am too confused for the steps I need to perform to make it work. Thanks in advance!
