Every 5 times or so, a Compute Shader that is always executed makes my program to crash. The error message is: “Unhandled exception at 0x0000000063648789 (nvoglv64.dll): Fatal program exit requested.” I can’t find the reason why it crashes as I check if the indices are out of the boundary. This is the code:
#version 430 core
layout(local_size_x = 8, local_size_y = 8, local_size_z = 8) in;
struct triangle
uint i0;
uint i1;
uint i2;
layout(std430, binding = 2) buffer trianglesIndicesList
triangle meshTriangles[];
layout(std430, binding = 3) buffer edgeIndicesMap
uint edgesIndices[];
uniform uvec3 indicesDims;
void main()
if (gl_GlobalInvocationID.x >= indicesDims.x ||
gl_GlobalInvocationID.y >= indicesDims.y ||
gl_GlobalInvocationID.z >= indicesDims.z)
return;
uint triangleIndex = gl_GlobalInvocationID.x + gl_GlobalInvocationID.y * indicesDims.x + gl_GlobalInvocationID.z * indicesDims.x * indicesDims.y;
if (triangleIndex >= meshTriangles.length())
return;
uint nChanges = 0;
bool changed[3] = bool[3](false, false, false);
triangle t = meshTriangles[triangleIndex];
for (uint i = 0; i < edgesIndices.length(); ++i)
uint eIndex = edgesIndices[i];
if (t.i0 == eIndex && !changed[0])
t.i0 = i;
++nChanges;
changed[0] = true;
else if (t.i1 == eIndex && !changed[1])
t.i1 = i;
++nChanges;
changed[1] = true;
else if (t.i2 == eIndex && !changed[2])
t.i2 = i;
++nChanges;
changed[2] = true;
if (nChanges == 3)
break;
meshTriangles[triangleIndex] = t;
I am using Windows 10 x64 and I have a NVIDIA GeForce GTX 760 with drive version 26.21.14.3086.
Does anyone see what I am doing wrong? Thank you very much!
