Description
An internal error happens while loading an ONNX model.
I exported a model as an ONNX file, but TensorRT doesn’t support one of the layers. I’m making a plugin and implemented enough of the interfaces that the network parses successfully.
However, it encounters an internal error during buildSerializedNetwork.
As far as I can tell, this is not due to the plugin. None of the plugin’s NYI methods are being called between the time the parser finishes and the time the error occurs. Also, the optimization step that fails is dealing with tensors whose dimensions are very different than the ones for the plugin’s layers.
Here is the tail of the logs where the failure occurs:
V:--------------- Timing Runner: Cast_437 (Cast)
V:Cast has no valid tactics for this config, skipping
V:--------------- Timing Runner: Cast_437 (Reformat)
V:Tactic: 0x00000000000003e8 Time: 0.0688853
V:Tactic: 0x00000000000003ea Time: 0.0320223
V:Tactic: 0x0000000000000000 Time: 0.0188113
V:Fastest Tactic: 0x0000000000000000 Time: 0.0188113
V:>>>>>>>>>>>>>>> Chose Runner Type: Reformat Tactic: 0x0000000000000000
V:*************** Autotuning format combination: Float(32768,4096:32,64,1) -> Float(1:4,4096,64,1) ***************
V:Tactic: 0x00000000000003e8 Time: 0.254352
V:Tactic: 0x00000000000003ea Time: 0.0640907
V:Tactic: 0x0000000000000000 Time: 0.324917
V:Fastest Tactic: 0x00000000000003ea Time: 0.0640907
V:>>>>>>>>>>>>>>> Chose Runner Type: Reformat Tactic: 0x00000000000003ea
V:*************** Autotuning format combination: Float(1:4,4096,64,1) -> Float(1048576,4096,64,1) ***************
V:Deleting timing cache: 613 entries, served 16507 hits since creation.
E:2: [engineTacticSupplyHelpers.cpp::makeEngineTensor::55] Error Code 2: Internal Error (Assertion isMultiple(tensor.start[vectorDim], spv) failed. )
E:2: [builder.cpp::buildSerializedNetwork::636] Error Code 2: Internal Error (Assertion engine != nullptr failed. )
Environment
TensorRT Version: 8.4.1
GPU Type: Titan RTX
Nvidia Driver Version: WSL: 516.59 Native: 515.48
CUDA Version: 11.7
CUDNN Version: 8
Operating System + Version: Ubuntu 20.04
Python Version (if applicable): N/A
TensorFlow Version (if applicable): N/A
PyTorch Version (if applicable): ONNX model was exported with PyTorch 1.12
Baremetal or Container (if container which image + tag): Bare metal (both WSL and native)
Relevant Files
Example project including the broken model: trt_failure.zip
Steps To Reproduce
- Run the following:
$ unzip trt_failure.zip
$ cd trt_failure/
$ ./build.sh
$ ./hello_trt_plugin
- Observe failure above
- Copy some other onnx file to
./model.onnx(e.g. mnist.onnx) - Observe Success message
