Description
Is any version of the TensorRT support TensorListStack plugin?
I’m trying to convert onnx model to trt.
The model was downloaded from tensorflow model zoo:
pre-trained mobilenetv2 downloaded from tensorflow model zoo models/tf2_detection_zoo.md at master · tensorflow/models · GitHub
During the conversion I got the error:
No importer registered for op: TensorListStack. Attempting to import as plugin.
[12/08/2021-12:04:53] [TRT] [I] Searching for plugin: TensorListStack, plugin_version: 1, plugin_namespace:
ERROR:EngineBuilder:Failed to load ONNX file: (...)/onnx.onnx
ERROR:EngineBuilder:In node 9 (importFallbackPluginImporter): UNSUPPORTED_NODE: Assertion failed: creator && "Plugin not found, are the plugin name, version, and namespace correct?"
So I have found the github issue fixing the problem:
https://github.com/onnx/tensorflow-onnx/pull/1448/commits
So to support the plugin, I have updated the tf2onnx to 1.9.3 (Initially TensorRT was using some older version of tf2onnx).
Unfortunately after that I got a new error:
ERROR: [TRT]: [graph.cpp::computeInputExecutionUses::519] Error Code 9: Internal Error ((Unnamed Layer* 747) [Recurrence]: IRecurrenceLayer cannot be used to compute a shape tensor)
More info:
ERROR: [TRT]: ModelImporter.cpp:720: While parsing node number 430 [Loop -> "StatefulPartitionedCall/Postprocessor/BatchMultiClassNonMaxSuppression/map/while_loop:0"]:
ERROR: [TRT]: ModelImporter.cpp:721: --- Begin node ---
ERROR: [TRT]: ModelImporter.cpp:722: input: "StatefulPartitionedCall/Postprocessor/BatchMultiClassNonMaxSuppression/map/while_cast:0"
input: "__inference_Postprocessor_BatchMultiClassNonMaxSuppression_map_while_cond_11290_27730_Postprocessor/BatchMultiClassNonMaxSuppression/map/while/LogicalAnd:0"
input: "StatefulPartitionedCall/map/Const:0"
input: "StatefulPartitionedCall/Postprocessor/BatchMultiClassNonMaxSuppression/strided_slice__1922:0"
output: "StatefulPartitionedCall/Postprocessor/BatchMultiClassNonMaxSuppression/map/while_loop:0"
output: "StatefulPartitionedCall/Postprocessor/BatchMultiClassNonMaxSuppression/map/while_loop:1"
output: "StatefulPartitionedCall/Postprocessor/BatchMultiClassNonMaxSuppression/map/while_loop:2"
output: "detection_multiclass_scores"
output: "StatefulPartitionedCall/Postprocessor/BatchMultiClassNonMaxSuppression/map/while_loop:4"
output: "StatefulPartitionedCall/Postprocessor/BatchMultiClassNonMaxSuppression/map/while_loop:5"
output: "StatefulPartitionedCall/Postprocessor/BatchMultiClassNonMaxSuppression/map/while_loop:6"
output: "detection_scores"
output: "detection_boxes"
name: "StatefulPartitionedCall/Postprocessor/BatchMultiClassNonMaxSuppression/map/while_loop"
op_type: "Loop"
attribute {
g {
node {
input: "postprocessor_batchmulticlassnonmaxsuppression_map_while_postprocessor_batchmulticlassnonmaxsuppression_map_strided_slice_1_0:0"
output: "cond___Postprocessor/BatchMultiClassNonMaxSuppression/map/while/Less__63:0"
op_type: "Cast"
attribute {
i: 1
type: INT
domain: ""
node {
output: "cond___Postprocessor/BatchMultiClassNonMaxSuppression/map/while/Less_1__61:0"
op_type: "Cast"
attribute {
i: 1
type: INT
domain: ""
node {
input: "postprocessor_batchmulticlassnonmaxsuppression_map_while_postprocessor_batchmulticlassnonmaxsuppression_map_while_loop_counter:0"
output: "cond___Postprocessor/BatchMultiClassNonMaxSuppression/map/while/Less_1__60:0"
op_type: "Cast"
attribute {
i: 1
type: INT
domain: ""
node {
input: "cond___Postprocessor/BatchMultiClassNonMaxSuppression/map/while/Less_1__60:0"
input: "cond___Postprocessor/BatchMultiClassNonMaxSuppression/map/while/Less_1__61:0"
output: "cond___Postprocessor/BatchMultiClassNonMaxSuppression/map/while/Less_1:0"
op_type: "Less"
domain: ""
node {
input: "postprocessor_batchmulticlassnonmaxsuppression_map_while_placeholder:0"
input: "Postprocessor/BatchMultiClassNonMaxSuppression/map/while/add/y:0"
output: "Postprocessor/BatchMultiClassNonMaxSuppression/map/while/Identity_2:0"
op_type: "Add"
node {
input: "Postprocessor/BatchMultiClassNonMaxSuppression/map/while/Identity_2:0"
output: "cond___Postprocessor/BatchMultiClassNonMaxSuppression/map/while/Less__62:0"
op_type: "Cast"
attribute {
i: 1
type: INT
domain: ""
node {
input: "cond___Postprocessor/BatchMultiClassNonMaxSuppression/map/while/Less__62:0"
input: "cond___Postprocessor/BatchMultiClassNonMaxSuppression/map/while/Less__63:0"
output: "cond___Postprocessor/BatchMultiClassNonMaxSuppression/map/while/Less:0"
ERROR: [TRT]: ModelImporter.cpp:723: --- End node ---
ERROR: [TRT]: ModelImporter.cpp:726: ERROR: ModelImporter.cpp:179 In function parseGraph:
[6] Invalid Node - Postprocessor/BatchMultiClassNonMaxSuppression/map/while/Slice_2
Docker container: Custom dGPU (Docker Containers — DeepStream 6.1.1 Release documentation)
TensorRT Version: 8.2.1.8
tf2onnx Version: 1.9.3
