Internal-error: create_module: Assertion 'context' failed in cuda-gdb 13.2 when debugging a program with Unified Memory
Describe the bug
When attempting to debug a simple CUDA program using Unified Memory (cudaMallocManaged) with cuda-gdb, the debugger crashes with an internal error: internal-error: create_module: Assertion 'context' failed. immediately after starting the run command with a breakpoint set.
Environment
  • OS: Debian GNU/Linux 13.4 (5.10.16.3-microsoft-standard-WSL2)
  • CUDA Toolkit Version: 13.2
  • cuda-gdb Version: NVIDIA (R) cuda-gdb 13.2 (Based on GNU gdb 16.3)
  • GPU Model: NVIDIA GeForce RTX 3060 Laptop GPU
Steps to Reproduce
  1. Save the following code as kernel.cu.
  2. Save the Makefile
  3. Compile the code with make: make -j
  4. Start the debugger:
    cuda-gdb main
  5. Set a breakpoint at line 47 (or on the kernel launch):
    (cuda-gdb) break 47
  6. Run the program:
    (cuda-gdb) run
NVCC = /usr/local/cuda/bin/nvcc
NVCC_FLAGS = -g -G -Xcompiler -Wall
main: kernel.cu
	$(NVCC) $(NVCC_FLAGS) $^ -o $@
clean:
	rm -f *.o *.exe
kernel.cu
#include <stdio.h>
#define N 64
#define TPB 32
float scale(int i, int n)
  return ((float)i)/(n - 1);
__device__
float distance(float x1, float x2)
  return sqrt((x2 - x1)*(x2 - x1));
__global__
void distanceKernel(float *d_out, float *d_in, float ref)
  const int i = blockIdx.x*blockDim.x + threadIdx.x;
  const float x = d_in[i];
  d_out[i] = distance(x, ref);
  printf("i = %2d: dist from %f to %f is %f.\n", i, ref, x, d_out[i]);
int main()
  const float ref = 0.5f;
  float *in = 0;
  float *out = 0;
  // Allocate managed memory for input and output arrays
  cudaMallocManaged(&in, N*sizeof(float));
  cudaMallocManaged(&out, N*sizeof(float));
  for (int i = 0; i < N; ++i)
    in[i] = scale(i, N);
  distanceKernel<<<N/TPB, TPB>>>(out, in, ref);
  cudaDeviceSynchronize();
  cudaFree(in);
  cudaFree(out);
  return 0;
Expected Behavior
Debugger should properly load the CUDA module, hit the breakpoint without crashing, and allow inspecting variables/execution context.
