A user on the matlab newsgroup comp.soft-sys.matlab reported internal file errors on multiple runs of a shared library. I have isolated the code and reproduced the problem outside of matlab. The example code is below.
[chulbert@fourier test]$ uname -a
Linux fourier.isl-inc.com 2.6.15-prep #1 SMP Tue Mar 21 11:20:33 EST 2006
x86_64 x86_64 x86_64 GNU/Linux
[chulbert@fourier test]$ pgf90 -V
pgf90 7.0-1 64-bit target on x86-64 Linux
Copyright 1989-2000, The Portland Group, Inc. All Rights Reserved.
Copyright 2000-2006, STMicroelectronics, Inc. All Rights Reserved.
[chulbert@fourier test]$ pgcc -V
pgcc 7.0-1 64-bit target on x86-64 Linux
[chulbert@fourier test]$ cat test.f90
SUBROUTINE mexfunction
character(len=80) :: debugout
I’m still looking into this and need to talk with a few of our engineers before I can get at exactly what the issue is here. I have my suspicions but need to confirm.
A work around is to add “-Bstatic_pgi” to each of the test.f90 links. This will bring in static copies of the PGF90 runtime libraries into each shared library.
Is there a work around for v6.1-6? As demonstrated below, the -Bstatic_pgi option does not exist in that version and the -Bstatic option does not work in this case.
%pgf90 -shared -otest_mex.mexa64 test.f90 -fpic -Bstatic
test.f90:
/usr/bin/ld: /usr/lib64/libc.a(ctype.o): relocation R_X86_64_32 against `__pthread_internal_tsd_address’ can not be used when making a shared object; recompile with -fPIC
/usr/lib64/libc.a: could not read symbols: Bad value
I’ve been able to work on this a bit more and found a better solution. Add “RTLD_GLOBAL” to the dlopen options. This way the PGF90 runtime information can be shared between the two modules.
I tested this with 6.1, 6.2 and the up coming 7.0 compilers, both in 32 and 64-bits.
“-Bstatic_pgi” was added with 6.2. Prior to this, you would need to use the “-v” switch to have the driver print the ld command, edit this command to put “-Bstatic” before and “-Bdynamic” after the PGI libraries. A cumbersome process and hence the addition of the flag.
The RTLD_GLOBAL option will not work in his case because what he really has are those Matlab MEX functions. Matlab is the when loading the shared library, so the user or developer cannot change the way shared libraries are opened. Perhaps the best thing is to upgrade to the 6.2 compilers if he doesn’t already have a subscription. Otherwise I suppose he would want to edit the link line himself.
Thanks. As pointed out, the RTLD_GLOBAL option does not work in my case. By editing the link line as suggested I’ve gotten it to work for my Matlab application.
I’ll be looking at how we build our shared object to see if we can do anything to have RTLD_GLOBAL the default. For now, however, using the static PGI runtime is the only way I know to get this to work properly.
