Help us respond more quickly by giving basic info about the issue. Fill in the appropriate details in the sections below. Make sure to upload screenshots and logs.
Which Workbench location had the issue?
(local)
What is the Operating System for your local Workbench?
(Windows )
What is the Workbench Desktop App version?
(0.25.30 or 0.28.29 —Not sure where do I check?)
Was the issue with the Desktop App or the CLI?
( Desktop App)
Summary of the Issue
*(Hello everyone,
Trying to run Mistral 7B Instruct.
My gpu’s are Nvidia 3060 12GB & a 3080TI 12GB. 96GB Ram. 5950X CPU
When I try Load the model it works fine. But when I launch the server I get the error above.
I tried like 20 times and it worked once. I kept restarting the environment and it eventually worked only once. But when I tried again im getting the same error. I managed to get it working a few times after trying to launch it multiple times. I think there is a bug. I launched the server it worked. I then stopped the server and launched it again and it never worked. I made no changes.
Any help please!!
What are the error messages?
( internal Server error)
What are the steps to reproduce
(start server after I click load model)
Upload screenshots or logs
{“level”:“warn”,“container-registry”:“ghcr.io”,“time”:“2024-03-22T18:29:44+02:00”,“message”:“BaseEnvironmentLatestTag is unknown for images not in NGC registry”}
{“level”:“warn”,“topic”:“/home/workbench/nvidia-workbench/nvidia-workbench-example-hybrid-rag”,“channel”:“0xc0008221e0”,“time”:“2024-03-22T18:29:51+02:00”,“message”:“Failed to send to subscriber. Channel full”}
{“level”:“warn”,“topic”:“/home/workbench/nvidia-workbench/nvidia-workbench-example-hybrid-rag”,“channel”:“0xc001304600”,“time”:“2024-03-22T18:29:51+02:00”,“message”:“Failed to send to subscriber. Channel full”}
{“level”:“warn”,“topic”:“/home/workbench/nvidia-workbench/nvidia-workbench-example-hybrid-rag”,“channel”:“0xc0012baf00”,“time”:“2024-03-22T18:29:51+02:00”,“message”:“Failed to send to subscriber. Channel full”}
{“level”:“warn”,“topic”:“/home/workbench/nvidia-workbench/nvidia-workbench-example-hybrid-rag”,“channel”:“0xc000b64b40”,“time”:“2024-03-22T18:29:51+02:00”,“message”:“Failed to send to subscriber. Channel full”}
{“level”:“warn”,“topic”:“/home/workbench/nvidia-workbench/nvidia-workbench-example-hybrid-rag”,“channel”:“0xc000a929c0”,“time”:“2024-03-22T18:29:51+02:00”,“message”:“Failed to send to subscriber. Channel full”}
{“level”:“warn”,“topic”:“/home/workbench/nvidia-workbench/nvidia-workbench-example-hybrid-rag”,“channel”:“0xc001189320”,“time”:“2024-03-22T18:29:51+02:00”,“message”:“Failed to send to subscriber. Channel full”}
{“level”:“warn”,“topic”:“/home/workbench/nvidia-workbench/nvidia-workbench-example-hybrid-rag”,“channel”:“0xc000a938c0”,“time”:“2024-03-22T18:29:51+02:00”,“message”:“Failed to send to subscriber. Channel full”}
{“level”:“warn”,“topic”:“/home/workbench/nvidia-workbench/nvidia-workbench-example-hybrid-rag”,“channel”:“0xc0005a75c0”,“time”:“2024-03-22T18:29:51+02:00”,“message”:“Failed to send to subscriber. Channel full”}
{“level”:“warn”,“topic”:“/home/workbench/nvidia-workbench/nvidia-workbench-example-hybrid-rag”,“channel”:“0xc000a923c0”,“time”:“2024-03-22T18:29:51+02:00”,“message”:“Failed to send to subscriber. Channel full”}
{“level”:“info”,“time”:“2024-03-22T18:29:51+02:00”,“message”:“Processing git status output”}
{“level”:“info”,“time”:“2024-03-22T18:29:51+02:00”,“message”:“Processing git diff output”}
{“level”:“warn”,“container-registry”:“ghcr.io”,“time”:“2024-03-22T18:29:52+02:00”,“message”:“BaseEnvironmentLatestTag is unknown for images not in NGC registry”}
{“level”:“info”,“time”:“2024/03/22 - 18:29:54”,“status”:200,“latency”:“10.786567563s”,“client-ip”:“127.0.0.1”,“method”:“POST”,“path”:“/v1/query”,“time”:“2024-03-22T18:29:54+02:00”,“message”:“GIN-Request”}
{“level”:“info”,“time”:“2024/03/22 - 18:33:38”,“status”:200,“latency”:“12.03µs”,“client-ip”:“127.0.0.1”,“method”:“OPTIONS”,“path”:“/v1/query”,“time”:“2024-03-22T18:33:38+02:00”,“message”:“GIN-Request”}
{“level”:“info”,“time”:“2024-03-22T18:33:38+02:00”,“message”:“Processing git status output”}
{“level”:“info”,“time”:“2024-03-22T18:33:38+02:00”,“message”:“Processing git diff output”}
{“level”:“info”,“time”:“2024/03/22 - 18:33:38”,“status”:200,“latency”:“13.305451ms”,“client-ip”:“127.0.0.1”,“method”:“POST”,“path”:“/v1/query”,“time”:“2024-03-22T18:33:38+02:00”,“message”:“GIN-Request”}
{“level”:“info”,“time”:“2024/03/22 - 18:33:38”,“status”:200,“latency”:“48.637507ms”,“client-ip”:“127.0.0.1”,“method”:“POST”,“path”:“/v1/query”,“time”:“2024-03-22T18:33:38+02:00”,“message”:“GIN-Request”}
Submission Type
Bug or Error
Feature Request
Documentation Issue
Question
Other
Workbench Version
Desktop App v0.44.8
CLI v0.21.3
Other
Host Machine operating system and location
Local Windows 11
Local Windows 10
Local macOS
Local Ubuntu 22.04
Remote Ubuntu 22.04
Other
