Hi, this question has to do with the workflow related to the use of the Python scripts located in th directory /aodt sim/examples (executed through the provided chapi_bindings.so library) that extract simulation data from the database.
Despite this method allows the data to be processed faster, the result of this pipeline is a .dat file. Could you please clarify how this resulting .dat file could be interpreted, or how to convert the data into meaningful metrics?
Thank you!
