Invasive warning while compiling
Hello all,
I’m getting tons of the following warning :
Cannot tell what pointer points to, assuming global memory space
while compiling my OptiX code.
By googling my problem, I found out that I should not worry about it. However, I really get tons of this warning and am thus unable to see other warnings that could have more sense.
Is there any way to prevent nvcc from producing this warning ?
These warnings should not appear if you’re able to compile to a target GPU architecture with SM 2.0 (Fermi) or newer during your development. Try adding -arch=sm_20 to your nvcc options then.
This solved my problem. Thanks for your help.
