IP-Sec offload tunnel mode
we have crypto enabled Bluefield 2 and Bluefield 3 and are trying to get an offloaded ip sec tunnel working. We got transport mode working following this guide: IPsec Packet Offload | MLNX_OFED Software . We are however getting the following error when trying to switch to tunnel mode:
/opt/mellanox/iproute2/sbin/ip xfrm state add src 10.100.10.135/16 dst 10.100.10.164/16 proto esp spi 0xc35aa26e reqid 0xc35aa26e mode tunnel aead 'rfc4106(gcm(aes))' 0x6cb228189b4c6e82e66e46920a2cde39187de4ba 128 offload packet dev p0 dir in sel src $10.1.0.0/16 dst $10.2.0.0/16 flag esn replay-window 64
Error: mlx5_core: Packet offload tunnel mode is disabled due to encap settings.
Hardware:
lspci -v -v -v |grep Mellanox
00:00.0 PCI bridge: Mellanox Technologies MT42822 BlueField-2 SoC Crypto enabled (rev 01) (prog-if 00 [Normal decode])
01:00.0 PCI bridge: Mellanox Technologies MT42822 Family [BlueField-2 SoC PCIe Bridge] (rev 01) (prog-if 00 [Normal decode])
02:00.0 PCI bridge: Mellanox Technologies MT42822 Family [BlueField-2 SoC PCIe Bridge] (rev 01) (prog-if 00 [Normal decode])
03:00.0 Ethernet controller: Mellanox Technologies MT42822 BlueField-2 integrated ConnectX-6 Dx network controller (rev 01)
	Subsystem: Mellanox Technologies MT42822 BlueField-2 integrated ConnectX-6 Dx network controller
03:00.1 Ethernet controller: Mellanox Technologies MT42822 BlueField-2 integrated ConnectX-6 Dx network controller (rev 01)
Is tunnel mode possible on the bluefield and does anybody have an idea to solve this error?
IPSec Tunnel Mode should be supported even with kernel. Can you please share your full configuration? Also, Which DOCA/FW Version is being used on the BF?
cat /etc/mlnx-release
flint -d 03:00.0 q full
Thanks for the quick reply. Here is the output:
root@bf2:~# cat /etc/mlnx-release
bf-bundle-3.3.0-202_26.01_ubuntu-24.04_64k_prod
root@bf2:~# flint -d 03:00.0 q full
Image type:            FS4
FW Version:            24.48.1000
FW Release Date:       11.2.2026
Part Number:           MBF2M516C-CECO_Ax
Description:           BlueField-2 E-Series DPU 100GbE Dual-Port QSFP56; integrated BMC; PCIe Gen4 x16; Secure Boot Enabled; Crypto Enabled; 16GB on-board DDR; 1GbE OOB management; Tall Bracket; FHHL
Product Version:       24.48.1000
Rom Info:              type=UEFI Virtio net version=21.4.13 cpu=AMD64,AARCH64
                       type=UEFI Virtio blk version=22.4.14 cpu=AMD64,AARCH64
                       type=UEFI version=14.41.14 cpu=AMD64,AARCH64
                       type=PXE version=3.9.101 cpu=AMD64
Description:           UID                GuidsNumber
Base GUID:             e8ebd30300e53318        16
Base MAC:              e8ebd3e53318            16
Image VSD:             N/A
Device VSD:            N/A
PSID:                  MT_0000000733
Security Attributes:   secure-fw
Default Update Method: fw_ctrl
Life cycle:            GA SECURED
Secure Boot Capable:   Enabled
EFUSE Security Ver:    0
Image Security Ver:    0
Security Ver Program:  Manually ; Disabled
Do you need any other information?
Apologies for the delayed reply. The output looks good (Capabilities, FW Version, etc). Please disable encap mode as below and give it a try:
/opt/mellanox/iproute2/sbin/devlink dev eswitch set pci/0000:03:00.0 mode legacy
/opt/mellanox/iproute2/sbin/devlink dev eswitch set pci/0000:03:00.1 mode legacy
echo none > /sys/class/net/p0/compat/devlink/encap
echo none > /sys/class/net/p1/compat/devlink/encap
/opt/mellanox/iproute2/sbin/devlink dev eswitch set pci/0000:03:00.0 mode switchdev
/opt/mellanox/iproute2/sbin/devlink dev eswitch set pci/0000:03:00.1 mode switchdev
Thanks for your reply, and sorry for my late answer. We tried your advice:
legacy
legacy
switchdev
switchdev
devlink dev eswitch show pci/0000:03:00.0
pci/0000:03:00.0: mode switchdev inline-mode none encap-mode none
devlink dev eswitch show pci/0000:03:00.1
pci/0000:03:00.1: mode switchdev inline-mode none encap-mode none
However, we are still encountering the same error message:
root@bf2:\~# sudo /opt/mellanox/iproute2/sbin/ip xfrm state add
  src 10.100.10.164 dst 10.100.10.135
  proto esp spi 0xb29ed314 reqid 0xb29ed314 mode tunnel
  aead 'rfc4106(gcm(aes))' 0x20f01f80a26f633d85617465686c32552c92c42f 128
  flag esn replay-window 0
  offload packet dev p0 dir out
