I’d like to test IPSec HW offloading using ip xfrm and strongSwan at BlueField-3 ARM, but it failed to set IP transform state and policy. Below is the base configuration of DPU.
- OvS setting
$ sudo ovs-vsctl show
97f6e5b4-02e4-407c-bdef-2051e6dda17e
Bridge ovsbr1
Port ovsbr1
Interface ovsbr1
type: internal
Port pf0hpf
Interface pf0hpf
Port p0
Interface p0
Port en3f0pf0sf0
Interface en3f0pf0sf0
Bridge ovsbr2
Port ovsbr2
Interface ovsbr2
type: internal
Port pf1hpf
Interface pf1hpf
Port en3f1pf1sf0
Interface en3f1pf1sf0
Port p1
Interface p1
ovs_version: "2.9.2-0010-25.02-based-3.3.3"
- firmware version
$ sudo mlxfwmanager
Querying Mellanox devices firmware ...
Device #1:
Device Type: BlueField3
Part Number: 900-9D3B6-00CV-A_Ax
Description: NVIDIA BlueField-3 B3220 P-Series FHHL DPU; 200GbE (default mode) / NDR200 IB; Dual-port QSFP112; PCIe Gen5.0 x16 with x16 PCIe extension option; 16 Arm cores; 32GB on-board DDR; integrated BMC; Crypto Enabled
PSID: MT_0000000884
PCI Device Name: /dev/mst/mt41692_pciconf0
Base MAC: a088c2461848
Versions: Current Available
FW 32.43.2566 N/A
PXE 3.7.0500 N/A
UEFI 14.37.0013 N/A
UEFI Virtio blk 22.4.0014 N/A
UEFI Virtio net 21.4.0013 N/A
Status: No matching image found
- ip status
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: oob_net0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether a0:88:c2:46:18:6c brd ff:ff:ff:ff:ff:ff
altname enamlnxbf17i0
inet6 fe80::a288:c2ff:fe46:186c/64 scope link
3: tmfifo_net0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 00:1a:ca:ff:ff:01 brd ff:ff:ff:ff:ff:ff
inet 192.168.100.4/30 brd 192.168.100.7 scope global noprefixroute tmfifo_net0
inet6 fe80::21a:caff:feff:ff01/64 scope link
4: p0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq master ovs-system state DOWN group default qlen 1000
link/ether a0:88:c2:46:18:58 brd ff:ff:ff:ff:ff:ff
altname enp3s0f0np0
5: p1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq master ovs-system state DOWN group default qlen 1000
link/ether a0:88:c2:46:18:59 brd ff:ff:ff:ff:ff:ff
altname enp3s0f1np1
6: ovs-system: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether 72:3f:89:d8:45:ba brd ff:ff:ff:ff:ff:ff
7: ovsbr1: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
8: ovsbr2: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
9: pf0hpf: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq master ovs-system state UP group default qlen 1000
link/ether 96:e5:09:05:18:7b brd ff:ff:ff:ff:ff:ff
altname enp3s0f0nc1pf0
10: pf1hpf: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq master ovs-system state UP group default qlen 1000
link/ether 0a:22:d2:76:3d:b7 brd ff:ff:ff:ff:ff:ff
altname enp3s0f1nc1pf1
inet6 fe80::822:d2ff:fe76:3db7/64 scope link
11: en3f0pf0sf0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq master ovs-system state UP group default qlen 1000
link/ether 82:81:95:fb:5d:2d brd ff:ff:ff:ff:ff:ff
altname enp3s0f0npf0sf0
12: enp3s0f0s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether 02:df:11:2b:a2:5f brd ff:ff:ff:ff:ff:ff
inet6 fe80::df:11ff:fe2b:a25f/64 scope link
13: en3f1pf1sf0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq master ovs-system state UP group default qlen 1000
link/ether 3e:8f:ac:46:cf:21 brd ff:ff:ff:ff:ff:ff
altname enp3s0f1npf1sf0
14: enp3s0f1s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether 02:2c:92:69:22:4e brd ff:ff:ff:ff:ff:ff
inet6 fe80::2c:92ff:fe69:224e/64 scope link
And here are questions.
In document, PFs such as
p0andp1are set byip xfrm, but I can’t check the packet coming from PFs. I’d like to know the method to receive the external packet at BlueField-3 ARM likesudo ifconfig p0 <ip addr> up -
I wonder
strongSwanrequires setting two ports,p0for insecure port andp1for secure port to connect IPSec tunnel. -
Does DOCA IPSec target the RDAM as well as TCP/IP?
