I get two machines with each installed a bluefiled SmartNIC from Cloudlab. I changed one SmartNIC’s mode to ECPF mode. The other one is in Sperated host mode. I assigned two ips for the two SmartNIC interfaces on the host, two different ips for the other host. Then on each host ping the other host, ping success. However, when I login the ECPF mode SmarNIC and run sudo ovs-vsctl show, it shows:
1aaab65a-46a8-47a5-89bd-66cb18f8dac4
Bridge ovsbr2
Port p1
Interface p1
Port en3f1pf1sf0
Interface en3f1pf1sf0
error: "could not open network device en3f1pf1sf0 (No such device)"
Port ovsbr2
Interface ovsbr2
type: internal
Port pf1hpf
Interface pf1hpf
error: "could not open network device pf1hpf (No such device)"
Bridge ovsbr1
Port pf0hpf
Interface pf0hpf
error: "could not open network device pf0hpf (No such device)"
Port ovsbr1
Interface ovsbr1
type: internal
Port en3f0pf0sf0
Interface en3f0pf0sf0
error: "could not open network device en3f0pf0sf0 (No such device)"
Port p0
Interface p0
ovs_version: "2.15.1"
It means that the OVS cannot detect the SmartNIC interfaces, right? Why is that and how to solve this problem? Thanks for your help.
Update: It was very strange, I just deleted the flow rule from ovsbr1, and ping from the x86 host to another x86 host and it still sccuess. How that would be if all packets need go throught the OVS and then go to another host, how the OVS still works if I deleted all rules for ovsbr1.
If yes, and issue is still seen, I would like to request opening a support ticket since this might require in-depth debug and possible reproduction. In case you do not have an active contract with us, you may reach out to our contracts team at networking-contracts@nvidia.com . The support ticket can be opened by emailing Networking-support@nvidia.com
Thanks for your reply. I read the documents and confirmed the mode is Embedded mode. The problem is PF(pf0hpf/pf1hpf) and SF(enp3s0f0s0/en3f1pf1sf0) ports cannot show up in BlueField OS. Run ifconfig or lshw to show all interfaces, there were no such interfaces. That’s what OVS complains. I tried several ways to debug this problem, I reinstalled the OS on BlueField 2, reset the NIC with command mlxconfig -d /dev/mst/mt41686_pciconf0 -y reset, but not working, the issue is still there.
I got two machines installed BlueField 2 SmartNIC from Cloudlab, one machine works correctly and can show all interfaces, the other one cannot. By comparing these two machines, I found the not working one does not have parameters ECPF_ESWITCH_MANAGER and ECPF_PAGE_SUPPLIER. When switched to the Embedded mode and run command mlxconfig -d /dev/mst/mt41686_pciconf0 s ECPF_ESWITCH_MANAGER=1 ECPF_PAGE_SUPPLIER=1, it complains The Device doesn't support ECPF_ESWITCH_MANAGER parameter.I guess this relates to the problem.
Please share the following outputs from both, working and non-working machine:
a. #ibv_devinfo -v |egrep ‘board|fw’
b. From the ARM, #cat /etc/mlnx-release
If this requires extensive debug and in the case you submit a support ticket without an active support contract in place, unfortunately, debug would be restricted.
The PSID of card on both hosts is identical which means both are identical and on one machine it supports setting ECPF_ESWITCH_MANAGER=1 but not on other?
I wouldn’t expect the cards being same to behave differently. I would recommend opening a support ticket, however, please note that in case we determine that you do not possess an active contract level, support would be restricted.
I am facing the same problem. I run mst status -v and my output looks like yours. I wonder how you solved this issue. Thank you very much for your time and help!
If mst status -v does not show the interface identifiers as net-X in the list of the PCI devices, it means they don’t even exist. You cannot add them to OvS. In fact, even ifconfig should not show them.
I have been playing around a lot with Bluefield-2 and constantly updating my blogposts about recent findings.
you might have a look at: Medium blogpost series
dear cs.lev:
I have read your posts on bluefield 2 and it is inspiring!
I am having an issue, however, and I need help desperately!!!
My problem is that, after installing the bfb image and the doca host packages, I see no pf0hpf whatsoever. There is no OVS bridge set up automatically, as claimed by the NVIDIA documentation. When I create virtual functions on the host, the representors are not created on the DPU side. This is driving me crazy. My assumption is that a long time ago, I have deleted the ovs bridges. But since then I have reburned the bfb images several times, and it is still not working.
I would really appreciate it if you can help me with this problem.
Hi, are you sure the bfb image was installed properly and it also boots properly? You have to see all those interfaces via ifconfig -a or some equivalent ip a command. You might also try mst start then mst status -v. In the second command’s output, you should also see some interfaces.
If you don’t see those interfaces, you might also check from the host whether your DPU is in EMBEDDED_CPU mode and not in SEPARATED_HOST mode. If in the latter, you should change the mode of operation (find the details in my blog posts).
If those interfaces exist, then it’s just the OvS that did not start.
If OvS is installed, just run systemctl start openvswitch-switch. To enable it and let it automatically run after reboot enable the service as well via systemctl enable openvswitch-switch.
I’m using Ethernet/Infiniband BlueField 2. I’m facing the same issue when I switch the link type from ETH to IB. I couldn’t send traffic from the DPU to the host without these actors.
Whoever solved this problem please give us feedback on how you solved it
If mst status -v can’t see the interface of net, I suggest that you can flash BFB, which corresponds to its recommended firmware, I also encountered the same problem a few days ago, after flashing BFB, mst status can see the device
