Unable to add SF on host side with bluefield-2 in ECPF mode
Hi
Is it possible to add SF on host side with bluefield-2 DPU in ECPF mode?
I have following bluefield-2 smartnic:
vvmiheev@rnd2:~$ lspci | grep 4b:
4b:00.0 Ethernet controller: Mellanox Technologies MT42822 BlueField-2 integrated ConnectX-6 Dx network controller (rev 01)
4b:00.1 Ethernet controller: Mellanox Technologies MT42822 BlueField-2 integrated ConnectX-6 Dx network controller (rev 01)
4b:00.2 Non-Volatile memory controller: Mellanox Technologies NVMe SNAP Controller
4b:00.3 DMA controller: Mellanox Technologies MT42822 BlueField-2 SoC Management Interface (rev 01)
When I try to switch PF on host side to switchdev mode I get error: kernel answers: Operation not supported
vvmiheev@rnd2:~$ sudo devlink dev eswitch set pci/0000:4b:00.0 mode switchdev
If I try to add SF on host side without switching to switchdev mode I also get error:
vvmiheev@rnd2:~$ sudo devlink port add pci/0000:4b:00.0 flavour pcisf pfnum 0 sfnum 88
Error: mlx5_core: Port add is only supported in eswitch switchdev mode or SF ports are disabled.
I can add SF on arm side with both representor port and main port on arm side.
I also tried to add SF with main port on host side and representor port on arm side issuing commands on arm and specifying controller number 1
vvmiheev@SC-WS-00753:~$ sudo devlink port add pci/0000:03:00.0 flavour pcisf pfnum 0 sfnum 32 controller 1
kernel answers: No space left on device
How to create SF with main port on host side and representor port on arm side?
Configuration:
vvmiheev@rnd2:~$ cat /etc/lsb-release
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=22.04
DISTRIB_CODENAME=jammy
DISTRIB_DESCRIPTION=“Ubuntu 22.04.3 LTS”
vvmiheev@rnd2:~$ ethtool -i ens2f0np0
driver: mlx5_core
version: 23.10-1.1.9
firmware-version: 24.38.1002 (MT_0000000723)
expansion-rom-version:
bus-info: 0000:4b:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: no
supports-register-dump: no
supports-priv-flags: yes
vvmiheev@rnd2:~$ sudo mlxconfig -d /dev/mst/mt41686_pciconf0 query
Device #1:
Device type: BlueField2
Description: BlueField-2 P-Series DPU 25GbE Dual-Port SFP56; integrated BMC; PCIe Gen4 x8; Secure Boot Enabled; Crypto Disabled; 16GB on-board DDR; 1GbE OOB management; FHHL
Device: /dev/mst/mt41686_pciconf0
Configurations: Next Boot
MEMIC_BAR_SIZE 0
MEMIC_SIZE_LIMIT _256KB(1)
HOST_CHAINING_MODE DISABLED(0)
HOST_CHAINING_CACHE_DISABLE False(0)
HOST_CHAINING_DESCRIPTORS Array[0..7]
HOST_CHAINING_TOTAL_BUFFER_SIZE Array[0..7]
INTERNAL_CPU_MODEL EMBEDDED_CPU(1)
INTERNAL_CPU_PAGE_SUPPLIER ECPF(0)
INTERNAL_CPU_ESWITCH_MANAGER ECPF(0)
INTERNAL_CPU_IB_VPORT0 ECPF(0)
INTERNAL_CPU_OFFLOAD_ENGINE ENABLED(0)
FLEX_PARSER_PROFILE_ENABLE 0
PROG_PARSE_GRAPH False(0)
FLEX_IPV4_OVER_VXLAN_PORT 0
ROCE_NEXT_PROTOCOL 254
ESWITCH_HAIRPIN_DESCRIPTORS Array[0..7]
ESWITCH_HAIRPIN_TOT_BUFFER_SIZE Array[0..7]
PF_BAR2_SIZE 3
DPU_RESET_NOTIFICATION_ENABLED ENABLED(1)
INTERNAL_CPU_RSHIM ENABLED(0)
PF_NUM_OF_VF_VALID False(0)
NON_PREFETCHABLE_PF_BAR False(0)
VF_VPD_ENABLE False(0)
PF_NUM_PF_MSIX_VALID True(1)
PER_PF_NUM_SF True(1)
STRICT_VF_MSIX_NUM False(0)
VF_NODNIC_ENABLE False(0)
NUM_PF_MSIX_VALID False(0)
NUM_OF_VFS 8
NUM_OF_PF 2
PF_BAR2_ENABLE False(0)
HIDE_PORT2_PF False(0)
SRIOV_EN True(1)
PF_LOG_BAR_SIZE 5
VF_LOG_BAR_SIZE 0
NUM_PF_MSIX 63
NUM_VF_MSIX 11
INT_LOG_MAX_PAYLOAD_SIZE AUTOMATIC(0)
PCIE_CREDIT_TOKEN_TIMEOUT 0
RT_PPS_ENABLED_ON_POWERUP False(0)
LAG_RESOURCE_ALLOCATION DEVICE_DEFAULT(0)
PHY_COUNT_LINK_UP_DELAY DELAY_NONE(0)
ACCURATE_TX_SCHEDULER False(0)
PARTIAL_RESET_EN False(0)
RESET_WITH_HOST_ON_ERRORS False(0)
NVME_EMULATION_ENABLE True(1)
NVME_EMULATION_NUM_VF 0
NVME_EMULATION_NUM_PF 1
NVME_EMULATION_VENDOR_ID 5555
NVME_EMULATION_DEVICE_ID 24577
NVME_EMULATION_CLASS_CODE 67586
NVME_EMULATION_REVISION_ID 0
NVME_EMULATION_SUBSYSTEM_VENDOR_ID 0
NVME_EMULATION_SUBSYSTEM_ID 0
NVME_EMULATION_NUM_MSIX 0
NVME_EMULATION_MAX_QUEUE_DEPTH 0
PCI_SWITCH_EMULATION_NUM_PORT 0
VIRTIO_EMULATION_HOTPLUG_TRANS False(0)
PCI_SWITCH_EMULATION_ENABLE False(0)
VIRTIO_NET_EMULATION_VF_PCI_LAYOUT VIRTIO_1_X(0)
VIRTIO_NET_EMULATION_PF_PCI_LAYOUT VIRTIO_1_X(0)
VIRTIO_NET_EMULATION_ENABLE False(0)
VIRTIO_NET_EMULATION_NUM_VF 0
VIRTIO_NET_EMULATION_NUM_PF 0
VIRTIO_NET_EMU_SUBSYSTEM_VENDOR_ID 6900
VIRTIO_NET_EMULATION_SUBSYSTEM_ID 4161
VIRTIO_NET_EMULATION_NUM_MSIX 2
VIRTIO_BLK_EMULATION_VF_PCI_LAYOUT VIRTIO_1_X(0)
VIRTIO_BLK_EMULATION_PF_PCI_LAYOUT VIRTIO_1_X(0)
VIRTIO_BLK_EMULATION_ENABLE False(0)
VIRTIO_BLK_EMULATION_NUM_VF 0
VIRTIO_BLK_EMULATION_NUM_PF 0
VIRTIO_BLK_EMU_SUBSYSTEM_VENDOR_ID 6900
VIRTIO_BLK_EMULATION_SUBSYSTEM_ID 4162
VIRTIO_BLK_EMULATION_NUM_MSIX 2
PCI_DOWNSTREAM_PORT_OWNER Array[0..15]
CQE_COMPRESSION BALANCED(0)
IP_OVER_VXLAN_EN False(0)
MKEY_BY_NAME False(0)
PRIO_TAG_REQUIRED_EN False(0)
UCTX_EN True(1)
REAL_TIME_CLOCK_ENABLE False(0)
RDMA_SELECTIVE_REPEAT_EN False(0)
PCI_ATOMIC_MODE PCI_ATOMIC_DISABLED_EXT_ATOMIC_ENABLED(0)
TUNNEL_ECN_COPY_DISABLE False(0)
LRO_LOG_TIMEOUT0 6
LRO_LOG_TIMEOUT1 7
LRO_LOG_TIMEOUT2 8
LRO_LOG_TIMEOUT3 13
LOG_TX_PSN_WINDOW 7
VF_MIGRATION_MODE DEVICE_DEFAULT(0)
LOG_MAX_OUTSTANDING_WQE 7
ROCE_ADAPTIVE_ROUTING_EN False(0)
TUNNEL_IP_PROTO_ENTROPY_DISABLE False(0)
USER_PROGRAMMABLE_CC False(0)
PCC_INT_NP_RTT_DSCP 26
PCC_INT_NP_RTT_DSCP_EN False(0)
PCC_INT_NP_RTT_DATA_MODE RTT_V0(64)
PCC_INT_EN False(0)
PCC_INT_SYSTEM_RTT 0
STEERING_CACHE_REFRESH 0
MULTI_PCI_RESOURCE_SHARING DEVICE_DEFAULT(0)
ICM_CACHE_MODE DEVICE_DEFAULT(0)
HAIRPIN_DATA_BUFFER_LOCK False(0)
TLS_OPTIMIZE False(0)
TX_SCHEDULER_BURST 0
ZERO_TOUCH_TUNING_ENABLE False(0)
ROCE_CC_LEGACY_DCQCN False(0)
LOG_MAX_QUEUE 17
UPT_EMULATION_ENABLE False(0)
LARGE_MTU_TWEAK_64 False(0)
AES_XTS_TWEAK_INC_64 False(0)
CRYPTO_POLICY UNRESTRICTED(1)
RDE_DISABLE False(0)
PLDM_FW_UPDATE_DISABLE False(0)
RBT_DISABLE False(0)
PCIE_SMBUS_DISABLE False(0)
PCIE_IN_BAND_VDM_DISABLE False(0)
LOG_DCR_HASH_TABLE_SIZE 11
MAX_PACKET_LIFETIME 0
DCR_LIFO_SIZE 16384
ROCE_CC_PRIO_MASK_P1 255
ROCE_CC_PRIO_MASK_P2 255
CLAMP_TGT_RATE_AFTER_TIME_INC_P1 True(1)
CLAMP_TGT_RATE_P1 False(0)
RPG_TIME_RESET_P1 300
RPG_BYTE_RESET_P1 32767
RPG_THRESHOLD_P1 1
RPG_MAX_RATE_P1 0
RPG_AI_RATE_P1 5
RPG_HAI_RATE_P1 50
RPG_GD_P1 11
RPG_MIN_DEC_FAC_P1 50
RPG_MIN_RATE_P1 1
RATE_TO_SET_ON_FIRST_CNP_P1 0
DCE_TCP_G_P1 1019
DCE_TCP_RTT_P1 1
RATE_REDUCE_MONITOR_PERIOD_P1 4
INITIAL_ALPHA_VALUE_P1 1023
MIN_TIME_BETWEEN_CNPS_P1 4
CNP_802P_PRIO_P1 6
CNP_DSCP_P1 48
CLAMP_TGT_RATE_AFTER_TIME_INC_P2 True(1)
CLAMP_TGT_RATE_P2 False(0)
RPG_TIME_RESET_P2 300
RPG_BYTE_RESET_P2 32767
RPG_THRESHOLD_P2 1
RPG_MAX_RATE_P2 0
RPG_AI_RATE_P2 5
RPG_HAI_RATE_P2 50
RPG_GD_P2 11
RPG_MIN_DEC_FAC_P2 50
RPG_MIN_RATE_P2 1
RATE_TO_SET_ON_FIRST_CNP_P2 0
DCE_TCP_G_P2 1019
DCE_TCP_RTT_P2 1
RATE_REDUCE_MONITOR_PERIOD_P2 4
INITIAL_ALPHA_VALUE_P2 1023
MIN_TIME_BETWEEN_CNPS_P2 4
CNP_802P_PRIO_P2 6
CNP_DSCP_P2 48
LLDP_NB_DCBX_P1 False(0)
LLDP_NB_RX_MODE_P1 OFF(0)
LLDP_NB_TX_MODE_P1 OFF(0)
LLDP_NB_DCBX_P2 False(0)
LLDP_NB_RX_MODE_P2 OFF(0)
LLDP_NB_TX_MODE_P2 OFF(0)
ROCE_RTT_RESP_DSCP_P1 0
ROCE_RTT_RESP_DSCP_MODE_P1 DEVICE_DEFAULT(0)
ROCE_RTT_RESP_DSCP_P2 0
ROCE_RTT_RESP_DSCP_MODE_P2 DEVICE_DEFAULT(0)
DCBX_IEEE_P1 True(1)
DCBX_CEE_P1 True(1)
DCBX_WILLING_P1 True(1)
DCBX_IEEE_P2 True(1)
DCBX_CEE_P2 True(1)
DCBX_WILLING_P2 True(1)
KEEP_ETH_LINK_UP_P1 True(1)
KEEP_IB_LINK_UP_P1 False(0)
KEEP_LINK_UP_ON_BOOT_P1 False(0)
KEEP_LINK_UP_ON_STANDBY_P1 False(0)
DO_NOT_CLEAR_PORT_STATS_P1 False(0)
AUTO_POWER_SAVE_LINK_DOWN_P1 False(0)
KEEP_ETH_LINK_UP_P2 True(1)
KEEP_IB_LINK_UP_P2 False(0)
KEEP_LINK_UP_ON_BOOT_P2 False(0)
KEEP_LINK_UP_ON_STANDBY_P2 False(0)
DO_NOT_CLEAR_PORT_STATS_P2 False(0)
AUTO_POWER_SAVE_LINK_DOWN_P2 False(0)
NUM_OF_VL_P1 _4_VLs(3)
NUM_OF_TC_P1 _8_TCs(0)
NUM_OF_PFC_P1 8
VL15_BUFFER_SIZE_P1 0
QOS_TRUST_STATE_P1 TRUST_PCP(1)
NUM_OF_VL_P2 _4_VLs(3)
NUM_OF_TC_P2 _8_TCs(0)
NUM_OF_PFC_P2 8
VL15_BUFFER_SIZE_P2 0
QOS_TRUST_STATE_P2 TRUST_PCP(1)
DUP_MAC_ACTION_P1 LAST_CFG(0)
MPFS_MC_LOOPBACK_DISABLE_P1 False(0)
MPFS_UC_LOOPBACK_DISABLE_P1 False(0)
UNKNOWN_UPLINK_MAC_FLOOD_P1 False(0)
SRIOV_IB_ROUTING_MODE_P1 LID(1)
DUP_MAC_ACTION_P2 LAST_CFG(0)
MPFS_MC_LOOPBACK_DISABLE_P2 False(0)
MPFS_UC_LOOPBACK_DISABLE_P2 False(0)
UNKNOWN_UPLINK_MAC_FLOOD_P2 False(0)
SRIOV_IB_ROUTING_MODE_P2 LID(1)
PHY_AUTO_NEG_P1 DEVICE_DEFAULT(0)
PHY_RATE_MASK_OVERRIDE_P1 False(0)
PHY_FEC_OVERRIDE_P1 DEVICE_DEFAULT(0)
PHY_AUTO_NEG_P2 DEVICE_DEFAULT(0)
PHY_RATE_MASK_OVERRIDE_P2 False(0)
PHY_FEC_OVERRIDE_P2 DEVICE_DEFAULT(0)
PF_TOTAL_SF 32
PF_SF_BAR_SIZE 10
PF_NUM_PF_MSIX 128
SILENT_MODE False(0)
ROCE_CONTROL ROCE_ENABLE(2)
PCI_WR_ORDERING per_mkey(0)
MULTI_PORT_VHCA_EN False(0)
PORT_OWNER True(1)
ALLOW_RD_COUNTERS True(1)
RENEG_ON_CHANGE True(1)
TRACER_ENABLE True(1)
IP_VER IPv4(0)
BOOT_UNDI_NETWORK_WAIT 0
UEFI_HII_EN True(1)
BOOT_DBG_LOG False(0)
UEFI_LOGS DISABLED(0)
BOOT_VLAN 1
LEGACY_BOOT_PROTOCOL PXE(1)
BOOT_INTERRUPT_DIS False(0)
BOOT_LACP_DIS True(1)
BOOT_VLAN_EN False(0)
BOOT_PKEY 0
P2P_ORDERING_MODE DEVICE_DEFAULT(0)
EXP_ROM_VIRTIO_NET_PXE_ENABLE True(1)
EXP_ROM_VIRTIO_NET_UEFI_ARM_ENABLE True(1)
EXP_ROM_VIRTIO_NET_UEFI_x86_ENABLE True(1)
EXP_ROM_VIRTIO_BLK_UEFI_ARM_ENABLE True(1)
EXP_ROM_VIRTIO_BLK_UEFI_x86_ENABLE True(1)
EXP_ROM_NVME_UEFI_x86_ENABLE True(1)
ATS_ENABLED False(0)
DYNAMIC_VF_MSIX_TABLE False(0)
EXP_ROM_UEFI_ARM_ENABLE True(1)
EXP_ROM_UEFI_x86_ENABLE True(1)
EXP_ROM_PXE_ENABLE True(1)
ADVANCED_PCI_SETTINGS False(0)
SAFE_MODE_THRESHOLD 10
SAFE_MODE_ENABLE True(1)
SF only support on ARM eswitch side so far.
