I have this example and it runs perfectly fine in Jupyter labs:
(the LED turns on and stays on or turns off and stays off using this code)
import serial
with serial.Serial('/dev/ttyACM0', 9600, timeout=10) as ser:
while True:
led_on = input('Do you want the LED on? ')[0]
if led_on in 'yY':
ser.write(bytes('YES\n','utf-8'))
if led_on in 'Nn':
ser.write(bytes('NO\n','utf-8'))
And I tried to modify it so that I can use ipywidgtes (buttons specifically) and the same code does not do the same thing
(the builtin LED blinks but it does not stay on)
import serial
import ipywidgets
import ipywidgets as widgets
from IPython.display import display
button = widgets.Button(description="Click Me!")
button1 = widgets.Button(description="Click Me!1")
output = widgets.Output()
display(button, button1, output)
def on_button_clicked(b):
print("on")
def on_button_clicked1(b):
print("off")
button.on_click(on_button_clicked)
button1.on_click(on_button_clicked1)
Question: Any idea why the widgets dont pass through serial data the same way as the example at the top?
324Hz
win21H2
he/him
