We are designing a distributed-training experiment and currently have access to 32 NVIDIA A100 40 GB GPUs.
For both Jetstream2 and Google Cloud, the 1× A100 40 GB per node configurations are the lowest-cost options available to us, so this is the configuration we are considering for the main experiment.
Jetstream2 |
Google Cloud |
| Nodes |
32 |
32 |
| GPU per node |
1× A100 40 GB |
1× A100 40 GB |
| Total GPUs |
32 |
32 |
| VM type |
g3.xl |
a2-highgpu-1g |
| CPU per VM |
32 vCPUs |
12 vCPUs |
| RAM per VM |
120 GB |
85 GB |
| Network |
Physical GPU hosts have 2×100 GbE; actual VM throughput will be measured |
Up to 24 Gbps per VM |
Our goal is to create a realistic distributed-training baseline using the resources we can afford and access at this scale.
The main concern is that using one GPU per node forces GPU-to-GPU collective communication onto the inter-node network. Many larger training systems instead use multiple GPUs per node connected with NVLink/NVSwitch.
Given these constraints, would 32 nodes with 1× A100 40 GB each still be considered a reasonable distributed-training experiment?
In particular, we would appreciate advice on:
- Whether this represents a realistic and meaningful distributed-training configuration.
- Whether 1 GPU per node would overemphasize networking enough to make the experiment misleading.
- What measurements or controls we should include to properly characterize the system, such as NCCL collective bandwidth, all-reduce time, network latency/throughput, scaling efficiency, and compute-vs-communication time.
- Any changes we could make without significantly increasing hardware cost that would make the experiment more representative.
We understand this is not an ideal high-end training cluster. We are mainly trying to determine whether it is a defensible representation of distributed training given the hardware available to us, and how to account for its limitations.
Yes, 32 nodes with 1× A100 per node is a defensible distributed-training testbed, but with important caveats.
Why it’s reasonable:
- 32 A100s (1.28 PB/s peak compute) is a substantial cluster for many research workloads
- 1 GPU per node is the standard configuration in cloud and academic settings due to cost
- This setup realistically represents the communication-bound regime that many practitioners encounter
- Your platforms (Jetstream2 with 2×100 GbE, GCP with 24 Gbps) offer measurable inter-node bandwidth
The key limitation:
Yes, 1 GPU per node forces all collective communication (all-reduce, all-gather) onto the inter-node network. This differs from high-end clusters with 8× GPUs per node connected by NVLink, where intra-node communication is ~600 GB/s and only the final reduction crosses the network. Your setup will be more network-bound.
Is it misleading?
Not if you characterize it properly. This configuration is actually representative of a large class of real distributed-training deployments (cloud, academic, smaller industry labs). The key is to measure and report:
- NCCL collective bandwidth: Run
nccl-tests all-reduce benchmark to measure actual achieved bandwidth per operation
- All-reduce time: Profile your training loop’s collective operations (use
torch.profiler or NCCL tracing)
- Compute-to-communication ratio: Measure the fraction of time spent in collectives vs. forward/backward passes
- Scaling efficiency: Report throughput (samples/sec) at 1, 4, 8, 16, 32 nodes to quantify communication overhead
- Network saturation: Monitor actual network utilization during training (use
iperf3 or cloud monitoring)
Low-cost improvements (without major hardware changes):
- Use gradient accumulation to amortize collective communication cost
- Overlap communication with computation (PyTorch DDP with
find_unused_parameters=False)
- Consider ring all-reduce or other topology-aware collectives if your framework supports it
- Profile with NCCL tracing to identify bottleneck operations
- If possible, use Jetstream2 over GCP (2×100 GbE vs. 24 Gbps is an 8× difference in network capacity)
Bottom line:
This is a valid distributed-training experiment. It’s not a high-end cluster, but it’s realistic and defensible if you measure and report the communication characteristics. The results will be representative of the communication-bound regime, which is valuable for understanding scaling behavior in that regime.
