Test the sample about "Connect Three DGX Spark in a Ring Topology"
Hi Nvidia team:
I would like to test the “Connect Three DGX Spark in a Ring Topology” example. However, I noticed that in the spark_cluster_setup.py provided on GitHub, the three variables UCX_NET_DEVICES, NCCL_SOCKET_IFNAME, and OMPI_MCA_btl_tcp_if_include are all set to enP7s7.
In contrast, in the NCCL for Two Sparks setup, these variables are set to enp1s0f1np1.
These variables need to be consistent across different nodes; otherwise, the test will fail. For the “Connect Three DGX Spark in a Ring Topology” example, it doesn’t seem feasible to set them to enp1s0f1np1 or enp1s0f0np0.
So, does this mean that in the “Connect Three DGX Spark in a Ring Topology” setup, the three DGX Spark systems must additionally communicate via enP7s7 in order to perform NCCL + QSFP validation?
Could you also help confirm whether there are any misunderstandings in my interpretation and provide suggestions? Thank you.
NCCL for Two Sparks | DGX Spark
These env variables NCCL_SOCKET_IFNAME, UCX_NET_DEVICES, OMPI_MCA_btl_tcp_if_include are used for bootstrapping communication, not for high speed data transfer.
This is correct. In mesh setups, 10G ethernet will be used for OOB (out of bound) communications between the nodes, but IB links will be utilized for a high-speed connection.
The upcoming version of our community docker (GitHub - eugr/spark-vllm-docker: Docker configuration for running VLLM on dual DGX Sparks · GitHub) supports 3-node Mesh for vLLM.
Does that mean it will get over the power of 2 limitation / feature and will be able to handle -tp 3?
No, the limitation is number of attention heads in the model needs to be divisible by number of nodes in TP.
Hi @eugr and @aniculescu :
Thank you for the clarification. I’m now able to test NCCL performance using the ring method successfully. However, I’m wondering if my results are too slow. Could you please help review and provide suggestions? My test environment and results are as follows.
Thank you.
  • Test result:
    Command: NCCL test command: export CUDA_HOME=“/usr/local/cuda” && export MPI_HOME=“/usr/lib/aarch64-linux-gnu/openmpi” && export NCCL_HOME=“$HOME/nccl_spark_cluster/build/” && export LD_LIBRARY_PATH=“$NCCL_HOME/lib:$CUDA_HOME/lib64/:$MPI_HOME/lib:$LD_LIBRARY_PATH” && mpirun -np 3 -H 192.168.0.1:1,192.168.0.2:1,192.168.3.2:1 --mca plm_rsh_agent “ssh -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no” -x LD_LIBRARY_PATH=$LD_LIBRARY_PATH -x UCX_NET_DEVICES=enP7s7 -x NCCL_SOCKET_IFNAME=enP7s7 -x OMPI_MCA_btl_tcp_if_include=enP7s7 -x NCCL_IB_HCA=rocep1s0f0,rocep1s0f1,roceP2p1s0f0,roceP2p1s0f1 -x NCCL_IB_SUBNET_AWARE_ROUTING=1 -x NCCL_IB_MERGE_NICS=0 -x NCCL_NET_PLUGIN=none $HOME/nccl-tests_spark_cluster/build/all_gather_perf -b 16G -e 16G -f 2
test_20260401_1.txt (3.5 KB)
Avg bus bandwidth from NCCL test: 2.85932 GB/s
WARNING: NCCL Test bandwidth is less than expected. Stop any GPU workloads on the nodes and try NCCL test again using the NCCL test command above.
test_20260401_2.txt (3.3 KB)
Avg bus bandwidth from NCCL test: 2.86038 GB/s
Network config:
nmcli_network_setup_node0-2.zip (1.0 KB)
Why is the third host on a different subnet? You should specify IPs that are assigned to enP7s7 (10G ethernet) here.
Can you post the results of ifconfig -a from all three nodes?
You should be getting ~24 GB/s avg. bus bandwidth.
You can also check your configuration against this networking guide.
Hi @eugr :
If I use your ring topology, what should I set for these three IP addresses? Does enP7s7 need to run at 10G speed, or is 1G sufficient? Thanks.
Reference config file:
dgx-spark-playbooks/nvidia/multi-sparks-through-switch/assets/spark_cluster_setup/config/spark_config_ring.json at main · NVIDIA/dgx-spark-playbooks · GitHub
Hi @eugr :
After configuring the IP addresses according to your link, the test results are still the same. I’m wondering if this is because the three enP7s7 ports are not reaching 10G speed—is that why this is happening?
Is it necessary for enP7s7 to be connected to a 10G-capable port and network, or is that not required?
  • Test reference:
    dgx-spark-playbooks/nvidia/multi-sparks-through-switch/assets/spark_cluster_setup at main · NVIDIA/dgx-spark-playbooks · GitHub
  • Test command by (bash spark_cluster_setup.sh -c spark_config_ring.json --run-setup)
    NCCL test command: export CUDA_HOME=“/usr/local/cuda” && export MPI_HOME=“/usr/lib/aarch64-linux-gnu/openmpi” && export NCCL_HOME=“$HOME/nccl_spark_cluster/build/” && export LD_LIBRARY_PATH=“$NCCL_HOME/lib:$CUDA_HOME/lib64/:$MPI_HOME/lib:$LD_LIBRARY_PATH” && mpirun -np 3 -H 192.168.177.11:1,192.168.188.13:1,192.168.178.13:1 --mca plm_rsh_agent “ssh -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no” -x LD_LIBRARY_PATH=$LD_LIBRARY_PATH -x UCX_NET_DEVICES=enP7s7 -x NCCL_SOCKET_IFNAME=enP7s7 -x OMPI_MCA_btl_tcp_if_include=enP7s7 -x NCCL_IB_HCA=rocep1s0f0,rocep1s0f1,roceP2p1s0f0,roceP2p1s0f1 -x NCCL_IB_SUBNET_AWARE_ROUTING=1 -x NCCL_IB_MERGE_NICS=0 -x NCCL_NET_PLUGIN=none $HOME/nccl-tests_spark_cluster/build/all_gather_perf -b 16G -e 16G -f 2
  • Test result
    Avg bus bandwidth from NCCL test: 2.86981 GB/s
    test_20260401_referenceip_1.txt (5.1 KB)
  • ifconfig -a for three devices:
    ifconfig_node0.txt (3.6 KB)
    ifconfig_node1.txt (3.9 KB)
    ifconfig_node2.txt (3.5 KB)
Instead of using CX7 IPs, try to launch it like this:
export CUDA_HOME=“/usr/local/cuda” && \
export MPI_HOME=“/usr/lib/aarch64-linux-gnu/openmpi” && \
export NCCL_HOME=“$HOME/nccl_spark_cluster/build/” && \
export LD_LIBRARY_PATH=“$NCCL_HOME/lib:$CUDA_HOME/lib64/:$MPI_HOME/lib:$LD_LIBRARY_PATH” && \
mpirun -np 3 -H 192.168.1.46:1,192.168.1.246:1,192.168.1.164:1 --mca plm_rsh_agent “ssh -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no” -x LD_LIBRARY_PATH=$LD_LIBRARY_PATH -x UCX_NET_DEVICES=enP7s7 -x NCCL_SOCKET_IFNAME=enP7s7 -x OMPI_MCA_btl_tcp_if_include=enP7s7 -x NCCL_IB_HCA=rocep1s0f0,rocep1s0f1,roceP2p1s0f0,roceP2p1s0f1 -x NCCL_IB_SUBNET_AWARE_ROUTING=1 -x NCCL_IB_MERGE_NICS=0 -x NCCL_NET_PLUGIN=none $HOME/nccl-tests_spark_cluster/build/all_gather_perf -b 16G -e 16G -f 2
The IP addresses you are supposed to provide to mpirun should be OOB interface addresses, in this case assigned to enP7s7.
If that doesn’t work, check the physical wiring against my networking guide to make sure it wired according to IP allocation, and try to use manual steps from the guide instead of the script from the playbook.
The playbook was incorrect before, and while they fixed one issue, there could be other bugs there too.
1G is sufficient, it is used as a control channel and it’s speed/latency is not really important here.
Yes, because that’s how the nodes will be discovered.
Hi @eugr :
May I ask if the data I measured still meets the speed requirements of the three GX10 ring topology? I accidentally deleted a comment above, so I’m reposting the data here.
Thank you.
  • Test Command1:
    –mca plm_rsh_agent “ssh -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no”
    -x LD_LIBRARY_PATH=$LD_LIBRARY_PATH -x NCCL_IB_MERGE_NICS=0 -x NCCL_NET_PLUGIN=none -x NCCL_IB_SUBNET_AWARE_ROUTING=1
    $HOME/nccl-tests/build/all_gather_perf
# nccl-tests version 2.18.2 nccl-headers=22907 nccl-library=22907
# Collective test starting: all_gather_perf
# nThread 1 nGpus 1 minBytes 33554432 maxBytes 33554432 step: 1048576(bytes) warmup iters: 1 iters: 20 agg iters: 1 validation: 1 graph: 0 unalign: 0
# Using devices
#  Rank  0 Group  0 Pid   5353 on  gx10-f0df device  0 [000f:01:00] NVIDIA GB10
#  Rank  1 Group  0 Pid   4685 on  gx10-f21a device  0 [000f:01:00] NVIDIA GB10
#  Rank  2 Group  0 Pid   5482 on  gx10-9680 device  0 [000f:01:00] NVIDIA GB10
#                                                              out-of-place                       in-place
#       size         count      type   redop    root     time   algbw   busbw  #wrong     time   algbw   busbw  #wrong
#        (B)    (elements)                               (us)  (GB/s)  (GB/s)             (us)  (GB/s)  (GB/s)
    33554400       2796200     float    none      -1  1196.48   28.04   18.70       0  1203.57   27.88   18.59       0
# Out of bounds values : 0 OK
# Avg bus bandwidth    : 18.6411
# Collective test concluded: all_gather_perf
  • Test Command 2:
    $HOME/nccl-tests/build/all_gather_perf -b 16G -e 16G -f 3
# nThread 1 nGpus 1 minBytes 17179869184 maxBytes 17179869184 step: 3(factor) warmup iters: 1 iters: 20 agg iters: 1 validation: 1 graph: 0 unalign: 0
# Using devices
#  Rank  0 Group  0 Pid   4998 on  gx10-f21a device  0 [000f:01:00] NVIDIA GB10
#  Rank  1 Group  0 Pid   6343 on  gx10-f0df device  0 [000f:01:00] NVIDIA GB10
#  Rank  2 Group  0 Pid   6344 on  gx10-9680 device  0 [000f:01:00] NVIDIA GB10
 17179869168    1431655764     float    none      -1   551876   31.13   20.75       0   547491   31.38   20.92       0
# Avg bus bandwidth    : 20.8364
It is still lower than it should be, but closer to expected.
Hi @eugr :
Thanks for the confirmation. I will run additional tests to verify whether it can meet the performance/speed you mentioned earlier
