Three node Spark clusters (without a switch) are now supported in spark-vllm-docker and sparkrun!
3-Node Mesh Networking on DGX Spark with spark-vllm-docker and sparkrun
by @eugr and @dbsci
Our community vLLM Docker (also known as spark-vllm-docker) and sparkrun (via community Docker builds) now support 3-node mesh configuration!
Background
NVIDIA DGX Spark systems ship with a ConnectX-7 (CX7) network adapter that provides two QSFP ports, each with two
logical partitions — giving four RoCE network interfaces per machine. In a typical 2-node setup, you connect a single
cable between the two Sparks and configure static IPs on a shared subnet. Simple.
But what if you have three DGX Sparks? With two QSFP ports per machine and three machines, you can build a full
mesh
— every node directly connected to every other node with a dedicated cable. No switch required.
           Spark 1
    Port 0       Port 1
    Port 1       Port 0
   Spark 2       Spark 3
    Port 0  ---  Port 1
This mesh topology gives each node up to 200 Gbps link to its two peers, enabling pipeline-parallel
inference workloads that split a model across all three machines.
Why Mesh?
On DGX Spark, each node has one GPU with 128 GB of unified memory. For larger models that don’t fit on a single node,
you need multi-node inference with tensor parallelism (TP) or pipeline parallelism (PP). The mesh topology works well
for 3-node PP because:
  • Does not require a switch — each inter-node link is a dedicated point-to-point cable
  • Flexible bandwidth — each node has 200 Gbps of CX7 bandwidth shared across its two ports; either link can burst up
    to the full 200 Gbps when the other is underutilized
  • Low latency — direct connections with no switch hops
Physical Cabling
You need three QSFP cables. Each cable connects Port 0 on one Spark to Port 1 on another:
Cable From To
1 Spark 1 Port 0 Spark 2 Port 1
2 Spark 2 Port 0 Spark 3 Port 1
3 Spark 3 Port 0 Spark 1 Port 1
It’s important to “cross-connect” between port0-port1, otherwise the mesh may not work properly.
Each port has two logical partitions (visible as two network interfaces), so each cable carries two independent L3
subnets. With 3 cables × 2 subnets each, the mesh uses 6 unique subnets total.
Tip: You can use Sparkrun’s topology detection to automatically configure IP addresses on all interfaces.
IMPORTANT! Mesh setup requires all Sparks to be connected to a common network via it’s Ethernet port, as unlike 2-node systems, it won’t be able to use it’s QSFP ports for NCCL OOB communications.
OOB interface is only required for initialization, discovery and high-level coordination, but the actual workloads will still use fast QSFP connections.
Requirements
  • 3× NVIDIA DGX Spark systems.
  • 3× QSFP56 cables.
  • Sparks connected as described above.
  • All sparks connected to common network via an Ethernet port (wifi may work but not recommended).
  • SSH access from your control machine to all three Sparks.
  • latest version of sparkrun installed on the control machine (or on one of the Sparks) or Community vLLM Docker repo checked out on one of the Sparks.
  • vLLM image built using the latest version of Community vLLM Docker (it won’t work with NGC or any other images due to non-standard NCCL build requirements).
  • sudo access on the Sparks (for initial netplan configuration; subsequent runs don’t need it).
Setup and usage
For new users, it’s recommended to use sparkrun as it takes care of initial network setup and provides more sophisticated orchestration capabilities.
Existing spark-vllm-docker users or those who want more low-level control over vLLM may follow the instructions below:
Quick start with spark-vllm-docker
Before you begin, make sure you follow the Networking Guide to set up wiring and IP addresses.
Check out the repository on the head node.
git clone https://github.com/eugr/spark-vllm-docker.git
cd spark-vllm-docker
Run the included recipe.
./run-recipe.sh --discover # configure cluster
./run-recipe.sh recipes/3x-spark-cluster/qwen3.5-397b-int4-autoround.yaml --setup --no-ray --force-build # you can drop --setup and --force-build on subsequent calls
It will run Intel/Qwen3.5-397B-Int4-Autoround on all 3 nodes in Pipeline Parallel mode.
Expected performance (as of 3/31/2026):
model test t/s peak t/s ttfr (ms) est_ppt (ms) e2e_ttft (ms)
Intel/Qwen3.5-397B-A17B-int4-AutoRound pp2048 901.27 ± 75.84 2296.92 ± 196.74 2289.99 ± 196.74 2297.10 ± 196.73
Intel/Qwen3.5-397B-A17B-int4-AutoRound tg32 17.86 ± 0.16 18.33 ± 0.47
Intel/Qwen3.5-397B-A17B-int4-AutoRound ctx_pp @ d8192 1165.46 ± 70.82 7063.95 ± 446.99 7057.01 ± 446.99 7064.08 ± 447.00
Intel/Qwen3.5-397B-A17B-int4-AutoRound ctx_tg @ d8192 17.63 ± 0.04 18.33 ± 0.47
Intel/Qwen3.5-397B-A17B-int4-AutoRound pp2048 @ d8192 372.73 ± 2.33 5501.79 ± 34.19 5494.85 ± 34.19 5501.95 ± 34.22
Intel/Qwen3.5-397B-A17B-int4-AutoRound tg32 @ d8192 17.58 ± 0.02 18.00 ± 0.00
Intel/Qwen3.5-397B-A17B-int4-AutoRound ctx_pp @ d16384 1239.28 ± 48.23 13248.92 ± 529.88 13241.98 ± 529.88 13249.11 ± 529.80
Intel/Qwen3.5-397B-A17B-int4-AutoRound ctx_tg @ d16384 17.44 ± 0.05 18.00 ± 0.00
Intel/Qwen3.5-397B-A17B-int4-AutoRound pp2048 @ d16384 348.75 ± 1.07 5879.40 ± 17.93 5872.47 ± 17.93 5879.53 ± 18.00
Intel/Qwen3.5-397B-A17B-int4-AutoRound tg32 @ d16384 17.46 ± 0.04 18.00 ± 0.00
Intel/Qwen3.5-397B-A17B-int4-AutoRound ctx_pp @ d32768 1161.66 ± 1.61 28215.72 ± 39.00 28208.79 ± 39.00 28215.86 ± 38.97
Intel/Qwen3.5-397B-A17B-int4-AutoRound ctx_tg @ d32768 17.25 ± 0.03 18.00 ± 0.00
Intel/Qwen3.5-397B-A17B-int4-AutoRound pp2048 @ d32768 311.32 ± 1.67 6585.57 ± 35.44 6578.64 ± 35.44 6585.70 ± 35.48
Intel/Qwen3.5-397B-A17B-int4-AutoRound tg32 @ d32768 17.37 ± 0.29 18.33 ± 0.47
llama-benchy (0.3.5)
date: 2026-03-31 18:03:15 | latency mode: api
Setup with sparkrun
Step 1: Create a cluster
sparkrun cluster create mesh \
  --hosts 10.0.0.11,10.0.0.12,10.0.0.13 \
  --default
Replace the IPs with your Sparks’ management network addresses.
Step 2: Run the setup wizard
sparkrun setup wizard --cluster mesh
The wizard walks through everything:
  1. SSH mesh — ensures all nodes can SSH to each other (required for multi-node inference)
  2. CX7 detection — discovers all ConnectX-7 interfaces on each host
  3. Topology detection — uses IPv6 multicast neighbor discovery to map which port connects to which peer, then
    classifies the topology as mesh
  4. Network configuration — assigns static IPs and jumbo frames (MTU 9000) via netplan, with a unique subnet pair per
    cable
  5. Host key distribution — registers the new CX7 IPs in known_hosts so SSH works over the high-speed interfaces
  6. Saves topology — records topology: ring in the cluster definition so sparkrun run automatically applies the
    right NCCL settings
The wizard auto-detects everything. You don’t need to know which cable connects which ports — sparkrun discovers the
physical topology and assigns subnets accordingly.
Step 2 (alternative): Manual CX7 setup
If you prefer to run just the CX7 step:
sparkrun setup cx7 --cluster mesh
This detects interfaces, discovers topology, shows the planned configuration, and asks for confirmation before applying.
What sparkrun configures
On each Spark, sparkrun writes a netplan file (/etc/netplan/40-cx7.yaml) that configures all four CX7 interfaces with:
  • Static IPs on the correct subnets for each cable
  • MTU 9000 (jumbo frames) for maximum throughput
  • No link-local addresses (avoids NCCL routing confusion)
Example for Spark 1 (connected to Spark 2 on port 0, Spark 3 on port 1):
network:
  version: 2
  ethernets:
    enp1s0f0np0:
      dhcp4: no
      dhcp6: no
      link-local: [ ]
      mtu: 9000
      addresses: [ 192.168.177.11/24 ]
    enP2p1s0f0np0:
      dhcp4: no
      dhcp6: no
      link-local: [ ]
      mtu: 9000
      addresses: [ 192.168.178.11/24 ]
    enp1s0f1np1:
      dhcp4: no
      dhcp6: no
      link-local: [ ]
      mtu: 9000
      addresses: [ 192.168.187.11/24 ]
    enP2p1s0f1np1:
      dhcp4: no
      dhcp6: no
      link-local: [ ]
      mtu: 9000
      addresses: [ 192.168.188.11/24 ]
Idempotent and safe
Running sparkrun setup cx7 again on an already-configured mesh is safe — it detects the existing configuration,
validates it against the detected topology, and reports “All hosts already configured” without making changes. Use
--force if you need to reconfigure.
Running Inference on the Mesh
Once the mesh is configured, sparkrun automatically applies the right NCCL environment variables when launching
inference on the cluster:
sparkrun run <recipe> --cluster mesh
# -- or --
(We don’t need to specify the cluster name because we already set it as our default cluster in the first step.)
Because the cluster definition has topology: ring, sparkrun injects the following NCCL environment variables:
  • NCCL_NET_PLUGIN=none
  • NCCL_IB_SUBNET_AWARE_ROUTING=1
  • NCCL_IB_MERGE_NICS=0
Sparkrun doesn’t require other changes to any other NCCL environment variables because the existing autodetection
functionality handles the rest.
These changes ensure that we’re properly setup for using the mesh with the latest patched versions of NCCL that are
included as part of @eugr’s latest builds.
Pipeline parallel recipes
Here is a sparkrun version to run the recipe sample from the new spark-vllm-docker release:
sparkrun run @experimental/qwen3.5-397b-a17b-int4-autoround-3x-vllm
And here is the recipe file:
# qwen3.5-397b-a17b-int4-autoround-3x-vllm.yaml
recipe_version: "2"
model: Intel/Qwen3.5-397B-A17B-int4-AutoRound
runtime: vllm
# this recipe is specific to 3-node mesh, so we set min/max nodes to 3
min_nodes: 3
max_nodes: 3
# using the Spark Arena eugr nightly container will signal sparkrun to use @eugr's latest release
container: ghcr.io/spark-arena/dgx-vllm-eugr-nightly-tf5:latest
metadata:
  description: Recipe for Qwen3.5-397B-INT4-Autoround to run on 3-node mesh in pipeline-parallel mode
# sparkrun knows to use "--tf5" flag when using the 'dgx-vllm-eugr-nightly-tf5' container, but we add it for completeness
build_args:
  - --tf5
# Mod required to fix ROPE syntax error
mods:
  - mods/fix-qwen3.5-autoround
  - mods/fix-qwen3.5-chat-template
# Ideally all command arguments should be specified in the defaults section
defaults:
  port: 8000
  host: 0.0.0.0
  pipeline_parallel: 3
  tensor_parallel: 1
  gpu_memory_utilization: 0.7
  max_model_len: 262144
  max_num_batched_tokens: 16384
  max_num_seqs: 10
  kv_cache_dtype: fp8
  tool_call_parser: qwen3_coder
  reasoning_parser: qwen3
# Environment variables
env:
  PYTORCH_CUDA_ALLOC_CONF: "expandable_segments:True"
  VLLM_MARLIN_USE_ATOMIC_ADD: 1
# The vLLM serve command template
command: |
  vllm serve {model} \
    --max-model-len {max_model_len} \
    --max-num-seqs {max_num_seqs} \
    --kv-cache-dtype {kv_cache_dtype} \
    --gpu-memory-utilization {gpu_memory_utilization} \
    --port {port} \
    --host {host} \
    --enable-prefix-caching \
    --enable-auto-tool-choice \
    --tool-call-parser {tool_call_parser} \
    --reasoning-parser {reasoning_parser} \
    --max-num-batched-tokens {max_num_batched_tokens} \
    --trust-remote-code \
    --chat-template unsloth.jinja \
    --load-format fastsafetensors \
    -tp {tensor_parallel} \
    -pp {pipeline_parallel}
More mesh pipeline-parallel recipe examples are coming soon to the official sparkrun registries.
Troubleshooting
“ring topology requires 2 physical ports (4 interfaces)” — Your Sparks only have one active CX7 port (2 interfaces).
Mesh requires both ports connected. Check that all three cables are plugged in and that both ports show as active (
ip link).
“ring topology requires exactly 3 hosts” — Mesh/ring is specifically for 3-node configurations. For 2 nodes, use the
default switch/direct topology. For 4+ nodes, use a switch.
Topology detected as “switch” instead of “ring” — This means some interfaces can see more than one peer, indicating
a switch is in the path. Verify your cables are direct point-to-point connections (not going through a switch).
“passwordless sudo not available” — Initial netplan configuration requires sudo. The wizard will prompt for a
password. After the first setup, re-runs don’t need sudo (idempotency check works without it).
Thank you for sharing the guide on setting up a three-node cluster. I’ve run some benchmarks, and the results show that the throughput (t/s) of the three-node cluster is actually slower than the two-node setup. I’m curious—besides the increased VRAM capacity for larger models, what are the other key advantages of scaling to three nodes?
Qwen3.5-397B-A17B-int4-AutoRound pp2048 912.55 ± 218.84 2374.87 ± 685.70 2181.62 ± 685.70 2374.92 ± 685.69
Qwen3.5-397B-A17B-int4-AutoRound tg32 12.01 ± 3.30 15.00 ± 0.00
Qwen3.5-397B-A17B-int4-AutoRound pp2048 @ d4096 1135.00 ± 7.87 5064.57 ± 123.02 4871.32 ± 123.02 5064.62 ± 123.01
Qwen3.5-397B-A17B-int4-AutoRound tg32 @ d4096 14.25 ± 0.04 15.00 ± 0.00
Qwen3.5-397B-A17B-int4-AutoRound pp2048 @ d8192 1241.54 ± 1.06 7604.19 ± 59.46 7410.94 ± 59.46 7604.24 ± 59.46
Qwen3.5-397B-A17B-int4-AutoRound tg32 @ d8192 14.38 ± 0.23 15.33 ± 0.47
Qwen3.5-397B-A17B-int4-AutoRound pp2048 @ d16384 1150.24 ± 117.33 14954.89 ± 1614.78 14761.64 ± 1614.78 14954.97 ± 1614.77
Qwen3.5-397B-A17B-int4-AutoRound tg32 @ d16384 14.14 ± 0.05 15.00 ± 0.00
Qwen3.5-397B-A17B-int4-AutoRound pp2048 @ d32768 1069.89 ± 120.33 30180.09 ± 3537.91 29986.84 ± 3537.91 30180.14 ± 3537.90
Qwen3.5-397B-A17B-int4-AutoRound tg32 @ d32768 12.43 ± 2.40 14.67 ± 0.47
date: 2026-04-05 08:02:29 | latency mode: generation
Pretty much only this, at least at this moment.
And if the model fits on one spark, you can use three in data-parallel to increase number of concurrent requests it can handle. Other than that, 3 nodes in pipeline-parallel will be slower than even a single Spark due to added overhead.
Is a 3 node cluster noticeably slower than a 2 node cluster? I was looking into upgrading my cluster from 2 to 3 but I’m hesitant if it also makes it substantially slower (not to mention the increased complexity that comes along with it). Running into headroom issues with my 2 node cluster that I believe a 3 node cluster will fix.
You can still run dual node workflows on 3 nodes at the same speed as a 2 node cluster, but if you use all three nodes, then the speed will be roughly equivalent to a single node as tensor-parallel is only supported on 2,4,8,2**n nodes.
I thought TP requires the number of nodes to be even ?
Yes, and for all models I know that should be a power of 2 (2, 4, 8, etc).
Yeah this great IF your ConnectX-7s come online, seems to be an ongoing issue with them. This is exactly the model I was hoping to run with my 3 Asus GX10s but alas the PCI bus issues with the GX10s are making it hard, but either way I have 3 nodes I can work with until I can move to this model :)
I think where this would really be useful is if we could dedicate the third spark to KV caching only. This would be great for long contexts and/or multiple simultaneous users. I’m not sure if it’s possible or how it would be set up, but in my two-spark setup I’m limited to a single user pretty much for long-context coding work with Qwen3.5 397B because of the few GB remaining after loading the model.
I was thinking of sharding an MoE over 2 of the nodes and KV Cache on the 3rd node, not sure if it will work but will test once they figure out why my ConnectX-7s won’t come online
It should be possible with LMCache: vllm serve - vLLM
Haven’t tried that, and not sure how that would affect performance, but worth trying. Two nodes could work as a cluster with tp=2, and one node would serve kv cache only.
What’s the reason tensor parallelism is only supported in powers of 2? Is that just an implementation detail in vllm/sglang or are there more fundamental reasons for it? I just bought a third spark, was hoping to use tp=3.
Basically, the number of attention heads in the model needs to be divisible by TP value. Since models usually have something like 64, 128 attention heads, power of two is a good rule of thumb here.
Now, uneven tensor splits may be possible, but I haven’t seen any implementations for it yet.
So, with 3 Sparks, you are pretty much limited to pipeline or data parallelism, or you can use two nodes with tp and a third node to host embedding/reranking/small-fast model.
Thanks @eugr for the guide — got this running on my 3-node mesh and wanted to share what I found, since I hit a few issues that others might run into. Also this is my first post here, just wanting to share my personal trials and tribulation over the 3-node issue (I have a Microtik switch on backorder coming and will scale out the remaining devices that way).
Issues and Fixes
The default vllm-node container from spark-vllm-docker uses the standard NCCL build — the dgxspark-3node-ring branch is commented out in the Dockerfile. This causes a silent worker crash (SIGTERM, exit code 1) on the first inference request, right after the NCCL P2P communicator is created between pipeline stages. The Gloo metadata transport shows “Connection closed by peer” on the other workers as a symptom.
The fix is to use the TF5 container which has the mesh NCCL patches:
container: Package dgx-vllm-eugr-nightly-tf5 · GitHub
A few other things I tripped over:
  • fastsafetensors loader freezes at 29% on Xet-downloaded models — use instanttensor
  • gpu_memory_utilization: 0.85 causes silent worker death during inference on Grace Hopper — 0.8 is stable
  • PYTORCH_CUDA_ALLOC_CONF: “expandable_segments:True” helps prevent memory fragmentation crashes
  • Speculative config (mtp with num_speculative_tokens: 2) throws NotImplementedError: Pipeline parallelism is not supported on this vLLM version
  • Model files need to be on all 3 nodes — hf-download.sh assumes ~/.cache/huggingface but if your HF cache is elsewhere, use HF_HOME
Working Recipe
mods:
  • mods/fix-qwen3.5-chat-template
    defaults:
    max_model_len: 131072
    max_num_seqs: 32
    env:
    NCCL_TIMEOUT: 3600
command:
vllm serve Intel/Qwen3.5-397B-A17B-int4-AutoRound
–max-model-len {max_model_len}
–max-num-seqs {max_num_seqs}
–kv-cache-dtype fp8
–gpu-memory-utilization {gpu_memory_utilization}
–enable-prefix-caching
–enable-auto-tool-choice
–tool-call-parser qwen3_coder
–reasoning-parser qwen3
–max-num-batched-tokens {max_num_batched_tokens}
–trust-remote-code
–chat-template unsloth.jinja
-tp 1
–block-size 256
–load-format instanttensor
–distributed-executor-backend ray
Launch: HF_HOME=~/.hf-cache ./run-recipe.sh recipes/3x-spark-cluster/qwen3.5-397b-int4-autoround.yaml --ray
Benchmarks
llama-benchy 0.3.5, latency mode: api
test t/s peak t/s ttfr (ms) KV cache %
tg100 (single) 16.4 ± 0.3 — — 0.6%
pp2048 56.7 ± 2.1 — — 17.3%
tg50 @ 32 concurr 169.6 ± 5.3 174.2 — 17.6%
tg200 @ 20 concurr 74.0 ± 3.1 — — 11.0%
Model load: ~59s, 66.63 GiB per node. 2.6M token KV cache pool. 336 total requests, 0 errors.
Full recipe + troubleshooting: spark-vllm-docker/recipes/3x-spark-cluster
Incremental Trials
Took about 10 iterations to get stable. Here’s the progression:
# Config Change Result
1 vllm-node + 0.85 mem Worker crash — NCCL P2P “Connection closed by peer”
2 + NCCL_P2P_DISABLE=1 Same crash — Gloo TCP, not NCCL tensor path
3 + fastsafetensors loader Freeze at 29% — incompatible with Xet cache
4 + --ray backend Same NCCL P2P crash
5 + PYTORCH_CUDA_ALLOC_CONF Same crash — not a memory fragmentation issue
6 TF5 container + fastsafetensors Freeze again — loader issue, not container
7 TF5 + instanttensor + 0.85 mem Worker SIGTERM — memory pressure on Grace Hopper
8 TF5 + 0.7 mem + --ray STABLE — 15 requests, 0 errors
9 + block-size 256 + 16384 tokens STABLE — 80 requests, gen t/s up to 74.0
10 + 0.8 mem + 32 max_seqs + 131K ctx STABLE — 336 requests, 169.6 gen t/s peak
Key takeaway: the root cause was the container, not NCCL flags or memory. The TF5 image has mesh-specific NCCL that the stock vllm-node Dockerfile skips (commented out). Everything else was tuning.
Current builds use NCCL from main because 3-node functionality has been merged about a month ago, so no need to use a special branch anymore.
Make sure you git pull and run ./build-and-copy.sh -c to pull and distribute a new version to all nodes. The recipe has been updated as well and should use a regular container, since Transformers 5 is included by default now.
Thanks! This makes sense
