like that?
gst-launch-1.0 nvarguscamerasrc ! 'video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1' ! nvtee ! nvvidconv ! 'video/x-raw, format=(string)I420, framerate=(fraction)30/1' ! tee ! v4l2sink device=/dev/video2
gst-launch-1.0 -ev nvarguscamerasrc ! 'video/x-raw(memory:NVMM),width=640, height=480, framerate=30/1, format=NV12' ! nvvidconv flip-method=0 ! videoconvert ! v4l2sink device=/dev/video2
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
/GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)640, height=(int)480, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)640, height=(int)480, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)640, height=(int)480, format=(string)NV12, framerate=(fraction)30/1
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 2592 x 1944 FR = 29.999999 fps; Analog Gain range min 1.000000, max 16.000000; Exposure Range min 34000, max 550385000;
GST_ARGUS: 2592 x 1458 FR = 29.999999 fps; Analog Gain range min 1.000000, max 16.000000; Exposure Range min 34000, max 550385000;
GST_ARGUS: 1280 x 720 FR = 120.000005 fps; Analog Gain range min 1.000000, max 16.000000; Exposure Range min 22000, max 358733000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 2
Output Stream W = 1280 H = 720
seconds to Run = 0
Frame Rate = 120.000005
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
ERROR: from element /GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0: Internal data stream error.
Additional debug info:
gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0:
streaming stopped, reason not-negotiated (-4)
EOS on shutdown enabled -- waiting for EOS after Error
Waiting for EOS...
Please find the linked threads 1 and 2. Thanks
