Is it possible to combine __pipeline_memcpy_async with __ldcs/__ldg/__ldca?
For example, I have a code like this:
#if __CUDA_ARCH__ >= 800
                __pipeline_wait_prior(0);
                xf = s_xAsync[thread];
                yf = s_yAsync[thread];
                mass = s_mAsync[thread];
                const int nextItem = index + numTotalThreads;
                if (nextItem < numChunks) {
                    __pipeline_memcpy_async(&s_xAsync[thread], &x[nextItem], sizeof(float4));
                    __pipeline_memcpy_async(&s_yAsync[thread], &y[nextItem], sizeof(float4));
                    __pipeline_memcpy_async(&s_mAsync[thread], &m[nextItem], sizeof(float4));
                    __pipeline_commit();
#else
                xf = __ldcs(&x[index]);
                yf = __ldcs(&y[index]);
                mass = __ldcs(&m[index]);
#endif
without __ldcs for normal access, the __pipeline_memcpy_async version is faster than normal access. When I add __ldcs to normal access, they are getting closer in performance.
Can __pipeline_memcpy_async somehow apply __ldg or __ldcs to the global loads for different use-cases like when data doesn’t fit L2 cache or when its in managed memory maybe peer-to-peer access, for even more performance?
You could look at the PTX code to see which instructions are called. I would guess some cp.async variants
It supports cache hint parameters. You can use inline assembly blocks to create your own intrinsics.
Then
cp.async.ca ...
would use all cache levels while
cp.async.cg ...
would pass through only L2 cache. But there’s no hint about streaming (or anything like zero hit-ratio expected).
Does “streaming” (zero hit ratio) usage require explicitly defining host-side launch-config with cache hit ratio given by user, always? For example, like this:
cudaStreamAttrValue stream_attribute;
stream_attribute.accessPolicyWindow.hitRatio  = 0.0;
cudaStreamSetAttribute(stream, cudaStreamAttributeAccessPolicyWindow, &stream_attribute);
Does the cache policy “no_allocate" portion of the instruction not apply?
