GPU
• DeepStream Version
6.0.1
no jetpack
• TensorRT Version
8.0
1080ti
Is it possible to opensource tracker source code developers to add custom data in tracker struct?
Is it possible to open tracker source code developers to add custom data, such as now only nvdstracker.h, there is no corresponding nvdstracker .cpp file?
in nvdstracker.h
typedef struct _NvMOTTrackedObj
/** Holds the class ID of the object to be tracked. /
uint16_t classId;
/* Holds a unique ID for the object, assigned by the tracker. /
uint64_t trackingId;
/* Holds the bounding box. /
NvMOTRect bbox;
/* Holds the tracking confidence of the object. /
float confidence;
/* Holds the track length in frames. /
uint32_t age;
/* Holds a pointer to the associated input object, if there is one. */
NvMOTObjToTrack *associatedObjectIn;
uint8_t reserved[128];
} NvMOT,
I want to add a counter such as 'gint unmove_times ’ to also determine whether an object is stationary or not 。 When traversing trackers, the value of this counter is updated by determining whether the position of the object has changed,
