Good afternoon, I have deepstream installed on my Jetson Xavier NX, I have been using the API to detect vehicles and account with “nvdsanalytics”. Now I want to calculate the speed of each detected object in real time, so I want to add an attribute or list to the tracked object, there is nvdstracker which is in charge of tracking but I can’t find the specific file to make the modification. Please help me with information regarding what part of the source code is located “nvdstracker”, my intention is to modify the code and add the attribute or list for the “speed” variable to the tracked object.
But when doing this, does not delete the information that I obtained from the classifiers, such as the information of the type or the brand of the vehicle?
i want to add to each tracked object the time when it was detected. I am using /opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-app/deepstream_app.cpp
Application can add user meta into the meta data of gstbuffer. Application and plugin can get the user meta later.
