i want to multiplied two results of CUFFT_R2C pointwise, is there a ready-made function in CUDA? Can give me some help, thanks
thrust::transform can be used to do pointwise multiplication of 2 complex arrays. Do google searches on thrust::complex and thrust::transform and you will find relevant examples.
Perhaps something like this:
#include <cufft.h>
#include <thrust/transform.h>
#include <thrust/device_ptr.h>
#include <thrust/complex.h>
int main(){
const int N = 256;
cufftComplex *d1, *d2, *r;
cudaMalloc(&d1, N*sizeof(cufftComplex));
cudaMalloc(&d2, N*sizeof(cufftComplex));
// fill those device buffers with complex cufft output data
cudaMalloc(&r, N*sizeof(cufftComplex));
thrust::device_ptr<thrust::complex<float> > td1 = thrust::device_pointer_cast((thrust::complex<float> *)d1);
thrust::device_ptr<thrust::complex<float> > td2 = thrust::device_pointer_cast((thrust::complex<float> *)d2);
thrust::device_ptr<thrust::complex<float> > tr = thrust::device_pointer_cast((thrust::complex<float> *)r);
thrust::transform(td1, td1+N, td2, tr, thrust::multiplies<thrust::complex<float> >() );
thanks
