Is there an example of a node.js engine for ASR/TTS?
Hardware - GPU (A100/A30/T4/V100)
Hardware - CPU
Operating System
Riva Version
TLT Version (if relevant)
I’m trying to connect Riva with the IBM voice gateway, this requires a Duplex NodeJS Stream. I would like to know if there is a similar implementation on which I can use as a guideline on how to implement for the integration with IBM.
Hi @nharo
Thanks for your interest in Riva
I will check with the team and let you know
HI @nharo
I have some updates from the team
We can indeed leverage Riva Sample for reference
https://docs.nvidia.com/deeplearning/riva/user-guide/docs/samples/sample-apps/riva-contact/README.html
Please find this blogpost (little old and outdated, but helps)
