Hi there,
I am debugging a code and need to print out the block index used in the kernel. Here is my code
#include <cuda.h>
#include <iostream>
#include "cuPrintf.cu"
using namespace std;
// Macro to catch CUDA errors in kernel launches
#define CHECK_LAUNCH_ERROR() \
do { \
/* Check synchronous errors, i.e. pre-launch */ \
cudaError_t err = cudaGetLastError(); \
if (cudaSuccess != err) { \
fprintf (stderr, "Cuda error in file '%s' in line %i : %s.\n",\
__FILE__, __LINE__, cudaGetErrorString(err) ); \
exit(EXIT_FAILURE); \
/* Check asynchronous errors, i.e. kernel failed (ULF) */ \
err = cudaThreadSynchronize(); \
__FILE__, __LINE__, cudaGetErrorString( err) ); \
} while (0)
int InitGPUSet()
char GPU[100] = "GPU: ";
cudaDeviceProp tCard;
int num = 0;
if (cudaSuccess == cudaGetDeviceCount(&num))
for (int i = 0; i < num; ++ i)
cudaSetDevice(i);
cudaGetDeviceProperties(&tCard, i);
puts(strcat(GPU, tCard.name));
else return 0;
return 1;
bool cuPrintInit()
cudaError_t err = cudaPrintfInit();
if(0 != strcmp("no error", cudaGetErrorString(err))) return false;
return true;
__global__ void test(void)
printf("blockIdx.x=%d blockIdx.y=%d\n", blockIdx.x, blockIdx.y);
int main(void)
if(!InitGPUSet()) puts("device is not ready!");
else if(!cuPrintInit()) puts("device is not ready!");
else
CHECK_LAUNCH_ERROR();
test<<<dim3(600, 600) , dim3(2, 2)>>>();
cudaPrintfDisplay(stdout, true);
cudaPrintfEnd();
It seems that there is a limit of output buffer. Above code doesn’t show all outputs but just some line with blockIdx.y close to the last few values. So what’s the correct way to print out all possible value for blockIdx.x and blockIdx.y in a kernel? Thanks.
