Isaac Sim 4.0 release version name in launcher
I was trying to find Isaac Sim 4.0 to download the latest release and could not find it. Then while looking at the "About: section for release 2023.1.1, it says 4.0.0 under version. Can someone please check the naming under the “release”. See the attached image.
Click on the drop down under 2023.1.1, there should be a button that says “All release builds”, and then you should see 4.0.0 listed under there.
Thanks Cail. Found it. It’s strange its buried in there.
Thanks @cail . Yes, that is the recommended method to install 4.0.0.
Apologies for this confusion. This happened because the 4.0.0 version number is smaller than 2023.1.1.
