https://ms-iot.github.io/ROSOnWindows/GettingStarted/SetupRos2.html
I wrote the following command while installing on this site, and the following error occurred.
c:\opt\ros\humble\x64\share\gazebo\setup.bat
When the c:\opt\ros\humble\x64\share\gazebo\setup.bat command is executed, “The specified path was not found.”
However, no matter how many times I put the tutorials in order, there is no file called gazebo
“pls Can you tell me who has similar experience to me?”
