Hi, i have an issue when i want to stream from ip camera
this is what i’ve been doing:
import face_recognition
import cv2
import numpy as np
import os
import glob
video_capture = cv2.VideoCapture("rtspsrc location=rtsp://admin:cognixy123@192.168.1.25:554/vlc ! decodebin ! videoconvert ! xvimagesink", cv2.CAP_GSTREAMER)
#i skip the load image process
while True:
# Grab a single frame of video
ret, frame = video_capture.read()
# cv2.imwrite('./saved/frame%d.jpg' % count,frame)
# count+=1
# Resize frame of video to 1/4 size for faster face recognition processing
small_frame = cv2.resize(frame, (0, 0), fx=0.25, fy=0.25)
# Convert the image from BGR color (which OpenCV uses) to RGB color (which face_recognition uses)
rgb_small_frame = small_frame[:, :, ::-1]
when i run the script, i have the following message
File "face_rec.py", line 60, in <module>
cv2.error: OpenCV(4.1.1) /io/opencv/modules/imgproc/src/resize.cpp:3720: error: (-215:Assertion failed) !ssize.empty() in function 'resize'
when i use usb camera, there’s no problem at all with my script. i’m using hikvision DS-2CD1023G0-I
does anyone have the solution for this problem? any answer would be appreciated it. thanks!
