I try to decode the rtsp stream from a IP camera by ffmpeg and the CUVID SDK .
Is this applicable on Jetson TX2?
The SDK(Video_codec_sdk) seems to have restriction to the GPU.
Can FFmpeg achieve this goal alone (not to use the SDK) ?
Video codec SDK is not supported on TX2.
You can use gstreamer:
https://devtalk.nvidia.com/default/topic/1014789/jetson-tx1/-the-cpu-usage-cannot-down-use-cuda-decode-/post/5188538/#5188538
https://developer.nvidia.com/embedded/dlc/l4t-accelerated-gstreamer-guide-28-2-ga
Thanks you DaneLLL ,
I have recieved your suggestion and I met some problem about the GStreamer.
OPENCV version 3.4.1-dev
Camera daemon stopped function…
OPENCV ERROR : Unspecified error (GStreamer:unable to start pipeline) cvCaptrueFromCAM_GStreamer, file /home/opencv/modules/videoio/src/cap_gstreamer.cpp,line 890.
Please clearly describe your issues in detail
python tegra_cam.py --uri rtsp://admin:scu508123@192.168.128.103
Called with args:
Namespace(image_height=1080, image_width=1920, rtsp_latency=200, rtsp_uri=‘rtsp://admin:scu508123@192.168.128.103’, use_rtsp=False, use_usb=False, video_dev=1)
OpenCV version: 3.4.1-dev
Socket read error. Camera Daemon stopped functioning…
gst_nvcamera_open() failed ret=0
OpenCV(3.4.1-dev) Error: Unspecified error (GStreamer: unable to start pipeline
) in cvCaptureFromCAM_GStreamer, file /home/nvidia/opencv/modules/videoio/src/cap_gstreamer.cpp, line 890
VIDEOIO(cvCreateCapture_GStreamer (CV_CAP_GSTREAMER_FILE, filename)): raised OpenCV exception:
OpenCV(3.4.1-dev) /home/nvidia/opencv/modules/videoio/src/cap_gstreamer.cpp:890: error: (-2) GStreamer: unable to start pipeline
in function cvCaptureFromCAM_GStreamer
Failed to open camera!
The script is for onboard camera input, not rtsp input. Please check links in comment #2
Thx a lot ,
https://blog.csdn.net/zong596568821xp/article/details/80306987
this is the link where the script from and different from links above.
I am not sure about the reason why this error occurs.
If you are using the ‘tegra_cam.py’ script I wrote (https://jkjung-avt.github.io/tx2-camera-with-python/), you’ll need to add a ‘–rtsp’ to the command.
python tegra_cam.py --rtsp --uri rtsp://admin:scu508123@192.168.128.103
hello,today I start the TX2 to try your solution and it cannot boot ,strangely.
tx2 cannot find firmware direct firmware load for tegra18x_xusb_firmware failed with error 2
falling back to user helper.
HELLO, jkjung13,
I have tried your suggestion and it did not work for the error above.
$ sudo apt-get install gstreamer1.0-plugins-bad-faad \
gstreamer1.0-plugins-bad-videoparsers
$ gst-launch-1.0 rtspsrc location=rtsp://admin:scu508123@192.168.128.103 ! \
rtph264depay ! h264parse ! omxh264dec ! nveglglessink
Thanks a lot for answering my questions.
And I have figure out the cause of above error.
Two more question :
1.How to save the decoded rtsp stream into a video file ?
2.The present FPS is about 35 f/s and how to decode multi-camera stream at the same time ? For example , can TX2 decode four rtsp streams at the same time ?
Best wishes.
You could check out my “Tegra Camera Recorder” blog post: https://jkjung-avt.github.io/tx2-camera-recorder/
Reference my tegra_cam.py code and try to initiate multiple cv2.VideoCapture()'s.
Hello jkjung13,
Thanks for your reply and I meet some problem about the decoding of rtsp stream on TX2.
def open_cam_onboard(width, height):
# On versions of L4T prior to 28.1, add 'flip-method=2' into gst_str
gst_str = ('nvcamerasrc ! '
'video/x-raw(memory:NVMM), '
'width=(int)2592, height=(int)1458, '
'format=(string)I420, framerate=(fraction)30/1 ! '
'nvvidconv ! '
'video/x-raw, width=(int){}, height=(int){}, '
'format=(string)BGRx ! '
'videoconvert ! appsink').format(width, height)
return cv2.VideoCapture(gst_str, cv2.CAP_GSTREAMER)
Hi jkjung13,
Thanks for sharing your tegra-cam.py code. I am working on a project to perform object detection tasks from some video source. I tried an IP camera first and your code works perfectly. After that I got video from a HDMI camera, and I connect the HDMI camera with an decode board(with ip add: 192.168.1.168) which will transfer the video stream from HDMI to H.264, and send the H.264 video through LAN to my JTX2. When I try to display video by:
cv2.VideoCapture("rtsp://admin:admin@192.168.1.168")
it works, but with unexpected high latency. Around 8 to 10 seconds. So I’m planning to decode the video by using gstreamer to get a lower latency, and I tried the tegra-cam.py code to work on the H.264 stream from the decode board. Then I got the following error:
OpenCV Error: Unspecified error (GStreamer: unable to start pipeline) in cvCaptureFromCAM_GStreamer, file /home/nvidia/src/opencv-3.4.0.modules/videoio/src/cap_gstreamer.cpp, line 890
/home/nvidia/src/opencv-3.4.0/modules/videoio/src/cap_gstreamer.cpp:890: error: (-2) GStreamer: unable to start pipeline in function cvCaptureFromCAM_GStreamer)
Do you have any ideas why this is happening? Any thoughts helps, thank you!
I’m guessing the RTSP stream generated by your HDMI encoder board requires a different demux or decoder.
Try the following from a terminal. Does it fail with a similar error message?
gst-launch-1.0 rtspsrc latency=200 location=rtsp://admin:admin@192.168.1.168 ! rtph264depay ! h264parse ! omxh264dec ! nveglglessink
Then try the gstreamer commands listed here: https://devtalk.nvidia.com/default/topic/1049103/jetson-tx2/gstreamer-decode-live-video-stream-with-latency/post/5324384/#5324384
Once you’ve found a working gstreamer pipeline, copy it to the gstreamer string in the ‘open_cam_rtsp’ function (https://gist.github.com/jkjung-avt/86b60a7723b97da19f7bfa3cb7d2690e#file-tegra-cam-py-L51). That should solve the problem.
Hello jkjung13,
Thanks for your reply! I tried the other pipelines listed in https://devtalk.nvidia.com/default/topic/1049103/jetson-tx2/gstreamer-decode-live-video-stream-with-latency/post/5324384/#5324384
and I found the last one finally works.
gst-launch-1.0 -v rtspsrc location=rtsp://192.168.1.111:80/live/0/mjpeg.sdp latency=0 ! application/x-rtp,media=video ! decodebin ! videoconvert ! xvimagesink
When I turn the overclock mode on, the video is being displayed well. And after that I changed my code to:
cap = cv2.VideoCapture("rtspsrc location=rtsp://admin:admin@192.168.1.168 latency=0 ! application/x-rtp,media=video ! decodebin ! videoconvert ! xvimagesink", cv2.CAP_GSTREAMER)
And the error becomes:
OpenCV Error: Unspecified error (GStreamer: cannot find appsink in manual pipeline) in cvCaptureFromCAM_GStreamer, file /home/nvidia/src/opencv-3.4.0.modules/videoio/src/cap_gstreamer.cpp, line 805
My question is: I used xvimagesink in my code and why appsink is still indicated as the problem?
EDIT: I find out that I have to add format=(string)BGRx into my code to make sure OpenCV can properly display them, and after change xvimagesink to appsink, the code just magically worked! Appreciated for your great help!
