Issue while Feeding Pytorch TRT 2D-U-net model into Deepstream 6
We have trained our Pytorch Unet model and converted that into TRT using the torch2trt but while feeding that into the Deepstream- 6 we are facing the errors logged below
vm:~$ deepstream-segmentation-app -t infer /home/elio_admin/Downloads/deepstream_tao_apps/configs/unet_tao/pgie_unet_tao_config.txt *************.h264
Now playing: /***********3969791.h264,
ERROR: [TRT]: 1: [stdArchiveReader.cpp::StdArchiveReader::29] Error Code 1: Serialization (Serialization assertion magicTagRead == magicTag failed.Magic tag does not match)
ERROR: [TRT]: 4: [runtime.cpp::deserializeCudaEngine::76] Error Code 4: Internal Error (Engine deserialization failed.)
ERROR: ../nvdsinfer/nvdsinfer_model_builder.cpp:1528 Deserialize engine failed from file: /home/elio_admin/Downloads/deepstream_tao_apps/models/unet/CD_CD_ICG_100_swiched.trt
0:00:00.501323373  5912 0x5598ad991520 WARN                 nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1889> [UID = 1]: deserialize engine from file :/home/elio_admin/Downloads/deepstream_tao_apps/models/unet/CD_CD_ICG_100_swiched.trt failed
0:00:00.501387106  5912 0x5598ad991520 WARN                 nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1996> [UID = 1]: deserialize backend context from engine from file :/home/elio_admin/Downloads/deepstream_tao_apps/models/unet/CD_CD_ICG_100_swiched.trt failed, try rebuild
0:00:00.501400602  5912 0x5598ad991520 INFO                 nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1914> [UID = 1]: Trying to create engine from model files
ERROR: ../nvdsinfer/nvdsinfer_model_builder.cpp:861 failed to build network since there is no model file matched.
ERROR: ../nvdsinfer/nvdsinfer_model_builder.cpp:799 failed to build network.
0:00:00.501915044  5912 0x5598ad991520 ERROR                nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1934> [UID = 1]: build engine file failed
0:00:00.501935112  5912 0x5598ad991520 ERROR                nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2020> [UID = 1]: build backend context failed
0:00:00.501945933  5912 0x5598ad991520 ERROR                nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1257> [UID = 1]: generate backend failed, check config file settings
0:00:00.501976872  5912 0x5598ad991520 WARN                 nvinfer gstnvinfer.cpp:841:gst_nvinfer_start:<primary-nvinference-engine> error: Failed to create NvDsInferContext instance
0:00:00.501984748  5912 0x5598ad991520 WARN                 nvinfer gstnvinfer.cpp:841:gst_nvinfer_start:<primary-nvinference-engine> error: Config file path: /home/elio_admin/Downloads/deepstream_tao_apps/configs/unet_tao/pgie_unet_tao_config.txt, NvDsInfer Error: NVDSINFER_CONFIG_FAILED
Running...
ERROR from element primary-nvinference-engine: Failed to create NvDsInferContext instance
Error details: gstnvinfer.cpp(841): gst_nvinfer_start (): /GstPipeline:dstest-image-decode-pipeline/GstNvInfer:primary-nvinference-engine:
Returned, stopping playback
Deleting pipeline
We have converted our model into trt on same machine as deepstream execution server, having same TensorRT version using the snippet below
    import torch2trt
    x = torch.ones((1, 3, 320, 480)).cuda().half()
    model = SegModel(n_classes=3)
    checkpoint = args.model_file
    a = torch.load(checkpoint)
    model.load_state_dict(a['state_dict'], strict=False)
    model1 = model.cuda().eval().half()
    model_w = model1.half()
    #args.tensorrt_file: 'alexnet_trt.pth'
    model_trt = torch2trt.torch2trt(model_w, [torch.tensor(x, dtype=torch.half, device='cuda:0')], fp16_mode=True)
    torch.save(model_trt.state_dict(), args.tensorrt_file)
Any help and suggestion would be appreciated
Thanks in Advance !!!
** Hardware Platform : NVIDIA RTX A6000
** DeepStream Version:
deepstream-app version 6.0.1, DeepStreamSDK 6.0.1, CUDA Driver Version: 11.6, CUDA Runtime Version: 11.4, TensorRT Version: 8.4, cuDNN Version: 8.4, libNVWarp360 Version: 2.0.1d3
** NVIDIA GPU Driver Version : Driver Version: 510.60.02
Make sure the trt version is the same between generating trt engine and running deepstream-segmentation-app.
Moved to TAO forum.
@Morganh I indeed came across a similar kind of suggestion on one of posts therefore made sure where we are converting the model and using deepstream have the same trt version.
Need to make sure even minor version.
For example, in a machine where runs deepstream-segmentation-app.
$ dpkg -l |grep cuda
ii tensorrt 8.0.1.6-1+cuda11.3 amd64 Meta package of TensorRT
Need to use the same 8.0.1.6 to generate trt engine.
I tried getting same version for both now it seems like i am getting new error
(pytorch) nkumar@u117282:~/deepstream_trt$ deepstream-segmentation-app -t infer deepstream_tao_apps/configs/unet_tao/pgie_unet_tao_config.txt deepstream_tao_apps/***********67.11704647123835-81.03094573969791.h264
(deepstream-segmentation-app:4023651): GStreamer-WARNING **: 10:20:01.186: External plugin loader failed. This most likely means that the plugin loader helper binary was not found or could not be run. You might need to set the GST_PLUGIN_SCANNER environment variable if your setup is unusual. This should normally not be required though.
(deepstream-segmentation-app:4023651): GStreamer-WARNING **: 10:20:01.186: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libtritonserver.so: cannot open shared object file: No such file or directory
(deepstream-segmentation-app:4023651): GStreamer-WARNING **: 10:20:01.187: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_nvblender.so': libgstbadvideo-1.0.so.0: cannot open shared object file: No such file or directory
(deepstream-segmentation-app:4023651): GStreamer-WARNING **: 10:20:01.187: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so': librivermax.so.0: cannot open shared object file: No such file or directory
One element could not be created. Exiting.
Failed to create source bin. Exiting.
My configuration file looks like :
[property]
labelfile-path=unet_labels.txt
model-engine-file=../../models/unet/**_**_ICG_100_2switched.trt_ew
#CD_CD_ICG_100_swiched.trt
#CA_CD_ICGGrayscale.trt
#engine-create-func-name=NvDsInferYoloCudaEngineGet
#tlt-encoded-model=../../models/unet/CA_CD.etlt
net-scale-factor=0.00784313725490196
offsets=127.5;127.5;127.5
infer-dims=3;512;512
#tlt-model-key=CA_CD_ICG
network-type=2
num-detected-classes=3
model-color-format=1
segmentation-threshold=0.0
output-blob-names=softmax_1
segmentation-output-order=1
gie-unique-id=1
Please create a new topic in Deepstream forum for this error. This is not related to TAO. So, please create a deepstream forum topic for better help. Thanks.
