Issue with acc_memcpy_device
I need to create a copy of an array on the device. The following code stops with an error
      program Bug
      use openacc
      implicit none
      Integer N, i, Asize
      Parameter(N=4096)
      Parameter(Asize=N*8)
      Real*8 A(N)
      Real*8 Anew(N)
      do i=1,N
       A(i) = 17
      enddo
 666  format(I)
      write(*, 666) sizeof(A)
!$acc data copyin(A) create(Anew)
c     call acc_memcpy_device(Anew, A, sizeof(A))
      CALL acc_memcpy_device(acc_deviceptr(Anew), acc_deviceptr(A),
     & Asize)
!$acc kernels
      do i=2,N-1
       Anew(i) = Anew(i) - 0.5 * (A(i-1) - 2*A(i) + A(i+1))
      enddo
!$acc end kernels
!$acc end data
      end program
$ pgfortran --version
pgfortran 18.10-1 64-bit target on x86-64 Linux -tp haswell
PGI Compilers and Tools
Copyright (c) 2018, NVIDIA CORPORATION.  All rights reserved.
$pgfortran -acc -ta=tesla,cc50 Bug.F
$PGI_ACC_DEBUG=1 ./a.out
       32768
ACC: detected 1 CUDA devices
cuda_initdev thread:0 data.default_device_num:0 pdata.cuda.default_device_num:0
ACC: device[1] is NVIDIA CUDA device 0 compute capability 5.0
ACC: initialized 1 CUDA devices
ACC: device[2] is PGI native
pinitialize (threadid=1)
cuda_init_device thread:1 data.default_device_num:1 pdata.cuda.default_device_num:1
cuda_init_device(threadid=1, device 0) dindex=1, api_context=(nil)
cuda_init_device(threadid=1, device 0) dindex=1, setting api_context=(nil)
cuda_init_device(threadid=1, device 0) dindex=1, new api_context=0x1f39380
argument memory for queue 16 device:0x701b40000 host:0x203860000
curr_devid for threadid=1 is 1
pgi_uacc_dataenterstart( file=/home/alexander/Bachelorarbeit/Bug.F, function=bug, line=1:1, line=17, devid=0,threadid=1 )
cuda_init_device(threadid=1, device 0) dindex=1, api_context=0x1f39380
pgi_uacc_dataon(hostptr=0x60bce0,stride=1,size=4096,eltsize=8,lineno=17,name=a,flags=0x700=present+create+copyin,async=-1,threadid=1)
cuda_shared( 0x60bce0 ) is not-managed
pgi_uacc_alloc(size=32768,devid=1,threadid=1)
allocate device memory 0x701c40000(32768B,threadid=1)
pgi_uacc_alloc(size=32768,devid=1,threadid=1) returns 0x701c40000
map    dev:0x701c40000 host:0x60bce0 dindex:1 size:32768 offset:0  (line:17 name:a) thread:1
alloc done with devptr at 0x701c40000 (threadid=1)
pgi_uacc_dataupx(devptr=0x701c40000,hostptr=0x60bce0,stride=1,size=4096,eltsize=8,lineno=17,name=a,async=-1,threadid=1)
pgi_uacc_cuda_dataup1(devdst=0x701c40000,hostsrc=0x60bce0,offset=0,stride=1,size=4096,eltsize=8,lineno=17,name=a,threadid=1)
pgi_uacc_dataon(hostptr=0x603ce0,stride=1,size=4096,eltsize=8,lineno=17,name=anew,flags=0x300=present+create,async=-1,threadid=1)
cuda_shared( 0x603ce0 ) is not-managed
allocate device memory 0x701c48000(32768B,threadid=1)
pgi_uacc_alloc(size=32768,devid=1,threadid=1) returns 0x701c48000
map    dev:0x701c48000 host:0x603ce0 dindex:1 size:32768 offset:0  (line:17 name:anew) thread:1
alloc done with devptr at 0x701c48000 (threadid=1)
pgi_uacc_dataenterdone(devid=1,threadid=1)
pgi_uacc_cuda_wait(lineno=-99,async=-1,dindex=1,threadid=1)
pgi_uacc_cuda_wait(sync on stream=0x228c9d0,threadid=1)
pgi_uacc_cuda_wait done (threadid=1)
cuda_shared( 0x603ce0 ) is not-managed (cached)
cuda_shared( 0x60bce0 ) is not-managed (cached)
pgi_uacc_cuda_memcpy(devdst=0x701c48000,devsrc=0x701c40000,bytes=6306356,async=-1,dindex=1)
call to cuMemcpyDtoDAsync returned error 1: Invalid value
The pointers are correct but the size is too large.
-Alex
Hi Alex,
It looks like we missed adding an interface for “acc_memcpy_device” in the OpenACC module when it was added to the OpenACC 2.5 standard. Since it’s a C/C++ routine, an interface is needed in order for it to be called from Fortran.
I added a problem report (TPR#26706) requesting that the interface be added to the OpenACC module.
In the meantime, you can add the following interface to your code to get it to work properly.
% cat test.F
      program Bug
#ifdef _OPENACC
      use openacc
#endif
      implicit none
      Integer N, i, Asize
      Parameter(N=4096)
      Real*8 A(N)
      Real*8 Anew(N)
#ifdef _OPENACC
      interface
        subroutine acc_memcpy_device( dest, src, bytes )
     &     bind(c,name='acc_memcpy_device_')
           import c_ptr, c_devptr
           type(c_devptr) :: dest
           type(c_devptr) :: src
!dir$ ignore_tkr (k) bytes
           integer(kind=int_ptr_kind()), value :: bytes
        end subroutine
      end interface
#endif
      do i=1,N
       A(i) = 17
      enddo
 666  format(I)
#ifdef _OPENACC
     & Asize)
#else
      Anew=A
#endif
!$acc kernels
      do i=2,N-1
      enddo
!$acc end kernels
!$acc update host (Anew)
!$acc end data
      print *, Anew(1), Anew(N)
      end program
% pgfortran -ta=tesla test.F; a.out
       32768
    17.00000000000000         17.00000000000000
Hope this helps,
Mat
Hi Mat,
adding the interface fixed my problem. Thanks for the quick reply.
Alex
The TPR should resolve the issue with 19.7 and above.
