i installed cuda9.0 and visual studio 2017
while building a code i ge followin errors
Error C1189 #error: – unsupported Microsoft Visual Studio version! Only the versions 2012, 2013, 2015 and 2017 are supported! matrixMul c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt\host_config.h 133
Error MSB3721 The command ““C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.0\bin\nvcc.exe” -gencode=arch=compute_30,code="sm_30,compute_30" -gencode=arch=compute_35,code="sm_35,compute_35" -gencode=arch=compute_37,code="sm_37,compute_37" -gencode=arch=compute_50,code="sm_50,compute_50" -gencode=arch=compute_52,code="sm_52,compute_52" -gencode=arch=compute_60,code="sm_60,compute_60" -gencode=arch=compute_70,code="sm_70,compute_70" --use-local-env --cl-version 2017 -ccbin “C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\bin\HostX86\x64” -x cu -I./ -I…/…/common/inc -I./ -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.0/include” -I…/…/common/inc -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.0\include" -G --keep-dir x64\Debug -maxrregcount=0 --machine 64 --compile -cudart static -Xcompiler “/wd 4819” -g -DWIN32 -DWIN32 -D_MBCS -D_MBCS -Xcompiler “/EHsc /W3 /nologo /Od /FS /Zi /RTC1 /MTd " -o x64/Debug/matrixMul.cu.obj “C:\ProgramData\NVIDIA Corporation\CUDA Samples\v9.0\0_Simple\matrixMul\matrixMul.cu”” exited with code 2. matrixMul C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\VC\VCTargets\BuildCustomizations\CUDA 9.0.targets 707
Same here with CUDA 9.2.
Base installer + patch 1 were both installed.
Visual Studio Community 2017 Version 15.9.7.
CUDA Toolkit Custom Dir was properly fixed to “C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.2”
Error MSB3721 The command ““C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.2\bin\nvcc.exe” -gencode=arch=compute_30,code="sm_30,compute_30" -gencode=arch=compute_35,code="sm_35,compute_35" -gencode=arch=compute_37,code="sm_37,compute_37" -gencode=arch=compute_50,code="sm_50,compute_50" -gencode=arch=compute_52,code="sm_52,compute_52" -gencode=arch=compute_60,code="sm_60,compute_60" -gencode=arch=compute_61,code="sm_61,compute_61" -gencode=arch=compute_70,code="sm_70,compute_70" --use-local-env -ccbin “C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\bin\HostX86\x64” -x cu -I./ -I…/…/common/inc -I./ -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.2/include” -I…/…/common/inc -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.2\include" -G --keep-dir x64\Debug -maxrregcount=0 --machine 64 --compile -cudart static -Xcompiler “/wd 4819” -g -DWIN32 -DWIN32 -D_MBCS -D_MBCS -Xcompiler “/EHsc /W3 /nologo /Od /Fdx64/Debug/vc141.pdb /FS /Zi /RTC1 /MTd " -o x64/Debug/vectorAdd.cu.obj “C:\ProgramData\NVIDIA Corporation\CUDA Samples\v9.2\0_Simple\vectorAdd\vectorAdd.cu”” exited with code 2. vectorAdd C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\VC\VCTargets\BuildCustomizations\CUDA 9.2.targets 712
Error C1189 #error: – unsupported Microsoft Visual Studio version! Only the versions 2012, 2013, 2015 and 2017 are supported! vectorAdd c:\program files\nvidia gpu computing toolkit\cuda\v9.2\include\crt\host_config.h 133
