Hi There,
I encountered an issue related to the DOCA ETH RXQ while using the doca_flow_pipe_add_entry
function. The DOCA version is 2.9.1 LTS
Issue Description
According to the Working with DOCA Flow to route incoming packets to a DOCA ETH RXQ, the following steps should be performed:
- Create and start DOCA Flow on the appropriate port.
- Create pipes to route packets.
- Obtain the queue ID inside DOCA ETH RXQ using:
doca_eth_rxq_get_flow_queue_id()
- Add an entry to a pipe that routes packets into the RX queue, using the obtained queue ID.
I successfully created a doca_eth_rxq
, and the printed queue_id
was 64536. However, when I used this queue ID as the pipe_queue
parameter in the doca_flow_pipe_add_entry()
function:
doca_error_t doca_flow_pipe_add_entry(
uint16_t pipe_queue,
struct doca_flow_pipe *pipe,
const struct doca_flow_match *match,
const struct doca_flow_actions *actions,
const struct doca_flow_monitor *monitor,
const struct doca_flow_fwd *fwd,
uint32_t flags,
void *usr_ctx,
struct doca_flow_pipe_entry **entry
I encountered the following error messages:
[03:31:41:938130][2201062][DOCA][ERR][hws_mempool.c:272][hws_mempool_alloc] Failed to allocate memory, data/cache is NULL in pool 0x17abad200
[03:31:41:938148][2201062][DOCA][ERR][dpdk_pipe_legacy.c:214][dpdk_pipe_entry_alloc] alloc new pipe entry from memory pool fail, pipe:ROOT_PIPE, queue:64536
[03:31:41:938164][2201062][DOCA][ERR][dpdk_pipe_legacy.c:439][add_entry] failed to create entry - entry pool depleted on pipe ROOT_PIPE
[03:31:41:938178][2201062][DOCA][ERR][engine_pipe.c:1260][engine_pipe_entry_add] failed adding entry - driver entry creation failed
[03:31:41:938193][2201062][DOCA][ERR][doca_flow.c:1049][doca_flow_pipe_add_entry] pipe entry add failed, rc = -12
I attempted to increase the number of queues using:
doca_flow_cfg_set_pipe_queues()
However, the system limits the maximum number of queues to 16, which corresponds to the number of CPU cores.
