Hi all,
I am trying to follow the example of gpunetio_simple_receive using the DOCA library version 2.5.2. The guildline I followed is :DOCA GPUNetIO - NVIDIA Docs
After compiling the simple_receive example on Host A, I sent UDP packets from Host B, but Host A did not receive any incoming UDP packets. Below are the logs and ifconfig outputs from both hosts:
[host A: 192.168.200.32]
$ ifconfig
docker0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet 172.17.0.1 netmask 255.255.0.0 broadcast 172.17.255.255
inet6 fe80::42:81ff:fec2:7e20 prefixlen 64 scopeid 0x20<link>
ether 02:42:81:c2:7e:20 txqueuelen 0 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 5 bytes 526 (526.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
enp4s0f0np0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.200.32 netmask 255.255.255.0 broadcast 192.168.200.255
inet6 fe80::bace:f6ff:fe49:64ea prefixlen 64 scopeid 0x20<link>
ether b8:ce:f6:49:64:ea txqueuelen 1000 (Ethernet)
RX packets 17 bytes 1438 (1.4 KB)
TX packets 102 bytes 7484 (7.4 KB)
enp5s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.26 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 fe80::ca7f:54ff:fe67:d52b prefixlen 64 scopeid 0x20<link>
ether c8:7f:54:67:d5:2b txqueuelen 1000 (Ethernet)
RX packets 106603 bytes 50420938 (50.4 MB)
TX packets 20416 bytes 1498307 (1.4 MB)
device memory 0x85e00000-85efffff
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 180 bytes 21885 (21.8 KB)
TX packets 180 bytes 21885 (21.8 KB)
tmfifo_net0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet6 fe80::21a:caff:feff:ff02 prefixlen 64 scopeid 0x20<link>
ether 00:1a:ca:ff:ff:02 txqueuelen 1000 (Ethernet)
RX packets 239077 bytes 10043710 (10.0 MB)
TX packets 85 bytes 6046 (6.0 KB)
$ sudo LD_LIBRARY_PATH=${LD_LIBRARY_PATH}:/usr/local/cuda-12.5/lib64:/opt/mellanox/gdrcopy/src:/opt/mellanox/dpdk/lib/x86_64-linux-gnu:/opt/mellanox/doca/lib/x86_64-linux-gnu ./build/doca_gpunetio_simple_receive -n 04:00.0 -g 01:00.0
[08:49:46:775224][7122][DOCA][INF][gpunetio_simple_receive_main.c:159][main] Starting the sample
[08:49:48:697835][7122][DOCA][INF][gpunetio_simple_receive_main.c:189][main] Sample configuration:
GPU 01:00.0
NIC 04:00.0
EAL: Detected CPU lcores: 16
EAL: Detected NUMA nodes: 1
EAL: Detected shared linkage of DPDK
EAL: Multi-process socket /var/run/dpdk/rte/mp_socket
EAL: Selected IOVA mode 'PA'
EAL: VFIO support initialized
TELEMETRY: No legacy callbacks, legacy socket not created
EAL: Probe PCI driver: mlx5_pci (15b3:a2d6) device: 0000:04:00.0 (socket -1)
[08:49:48:832543][7122][DOCA][WRN][engine_model.c:72][adapt_queue_depth] adapting queue depth to 128.
[08:49:49:405936][7122][DOCA][WRN][engine_port.c:321][port_driver_process_properties] detected representor used in VNF mode (driver port id 0)
EAL: Probe PCI driver: gpu_cuda (10de:2230) device: 0000:01:00.0 (socket -1)
[08:49:49:443917][7122][DOCA][INF][gpunetio_simple_receive_sample.c:425][create_rxq] Creating Sample Eth Rxq
[08:49:49:444259][7122][DOCA][INF][gpunetio_simple_receive_sample.c:466][create_rxq] Mapping receive queue buffer (0x0x7f5774000000 size 33554432B) with nvidia-peermem mode
[08:49:49:498094][7122][DOCA][INF][gpunetio_simple_receive_sample.c:610][gpunetio_simple_receive] Launching CUDA kernel to receive packets
[08:49:49:505775][7122][DOCA][INF][gpunetio_simple_receive_sample.c:614][gpunetio_simple_receive] Waiting for termination
^C[08:51:00:069538][7122][DOCA][INF][gpunetio_simple_receive_sample.c:45][signal_handler] Signal 2 received, preparing to exit!
[08:51:00:069547][7122][DOCA][INF][gpunetio_simple_receive_sample.c:620][gpunetio_simple_receive] Exiting from sample
[08:51:00:069966][7122][DOCA][INF][gpunetio_simple_receive_sample.c:362][destroy_rxq] Destroying Rxq
[08:51:00:109067][7122][DOCA][INF][gpunetio_simple_receive_sample.c:631][gpunetio_simple_receive] Sample finished successfully
[08:51:00:109083][7122][DOCA][INF][gpunetio_simple_receive_main.c:204][main] Sample finished successfully
[host B: 192.168.200.33]
$ ifconfig
ether 02:42:39:f6:fa:44 txqueuelen 0 (Ethernet)
TX packets 0 bytes 0 (0.0 B)
enp4s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.199 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 fe80::52eb:f6ff:fe29:22a2 prefixlen 64 scopeid 0x20<link>
ether 50:eb:f6:29:22:a2 txqueuelen 1000 (Ethernet)
RX packets 10107738 bytes 12815873507 (12.8 GB)
RX errors 0 dropped 15 overruns 0 frame 0
TX packets 7292619 bytes 4793595135 (4.7 GB)
device memory 0x85700000-857fffff
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.200.33 netmask 255.255.255.0 broadcast 192.168.200.255
inet6 fe80::ba3f:d2ff:fe03:6a02 prefixlen 64 scopeid 0x20<link>
ether b8:3f:d2:03:6a:02 txqueuelen 1000 (Ethernet)
RX packets 6515 bytes 1613313 (1.6 MB)
TX packets 3862 bytes 385136 (385.1 KB)
RX packets 888 bytes 96632 (96.6 KB)
TX packets 888 bytes 96632 (96.6 KB)
inet 192.168.100.1 netmask 255.255.255.0 broadcast 192.168.100.255
RX packets 69518 bytes 4780373 (4.7 MB)
RX errors 0 dropped 3 overruns 0 frame 0
TX packets 810194 bytes 1213824341 (1.2 GB)
TX errors 0 dropped 118 overruns 0 carrier 0 collisions 0
nping --udp -c 10 -p 2090 192.168.200.32 --data-length 1024 --delay 500ms
Starting Nping 0.7.80 ( https://nmap.org/nping ) at 2025-02-17 08:50 UTC
SENT (0.0012s) UDP packet with 1024 bytes to 192.168.200.32:2090
SENT (0.5013s) UDP packet with 1024 bytes to 192.168.200.32:2090
SENT (1.0013s) UDP packet with 1024 bytes to 192.168.200.32:2090
SENT (1.5018s) UDP packet with 1024 bytes to 192.168.200.32:2090
SENT (2.0018s) UDP packet with 1024 bytes to 192.168.200.32:2090
SENT (2.5023s) UDP packet with 1024 bytes to 192.168.200.32:2090
SENT (3.0023s) UDP packet with 1024 bytes to 192.168.200.32:2090
SENT (3.5028s) UDP packet with 1024 bytes to 192.168.200.32:2090
SENT (4.0028s) UDP packet with 1024 bytes to 192.168.200.32:2090
SENT (4.5033s) UDP packet with 1024 bytes to 192.168.200.32:2090
Issues Encountered:
- Is my network configuration correct for this test?
- There are no error messages on either host, but I do not see any logs indicating received UDP packets on Host A.
- I noticed that the NUMA mode of the DPU on both hosts is -1, which is inconsistent with the logs shown in the guideline, where NUMA nodes are detected as 2 and associated with specific sockets.
Could this discrepancy in NUMA node detection be causing the issue with simple_receive?
[log messge from the documentation]
$ sudo LD_LIBRARY_PATH=${LD_LIBRARY_PATH}:/usr/local/${YOUR_CUDA_VERSION}/lib64:/opt/mellanox/gdrcopy/src:/opt/mellanox/dpdk/lib/x86_64-linux-gnu:/opt/mellanox/doca/lib/x86_64-linux-gnu ./build/doca_gpunetio_simple_receive -n 17:00.1 -g ca:00.0
[11:00:30:397080][2328673][DOCA][INF][gpunetio_simple_receive_main.c:159][main] Starting the sample
[11:00:30:652622][2328673][DOCA][INF][gpunetio_simple_receive_main.c:189][main] Sample configuration:
GPU ca:00.0
NIC 17:00.1
EAL: Detected CPU lcores: 128
**EAL: Detected NUMA nodes: 2**
EAL: Probe PCI driver: mlx5_pci (15b3:a2d6) device: 0000:17:00.1 (**socket 0**)
[11:00:31:036760][2328673][DOCA][WRN][engine_model.c:72][adapt_queue_depth] adapting queue depth to 128.
[11:00:31:928926][2328673][DOCA][WRN][engine_port.c:321][port_driver_process_properties] detected representor used in VNF mode (driver port id 0)
EAL: Probe PCI driver: gpu_cuda (10de:20b5) device: 0000:ca:00.0 (**socket 1**)
[11:00:31:977261][2328673][DOCA][INF][gpunetio_simple_receive_sample.c:425][create_rxq] Creating Sample Eth Rxq
[11:00:31:977841][2328673][DOCA][INF][gpunetio_simple_receive_sample.c:466][create_rxq] Mapping receive queue buffer (0x0x7f86cc000000 size 33554432B) with nvidia-peermem mode
[11:00:32:043182][2328673][DOCA][INF][gpunetio_simple_receive_sample.c:610][gpunetio_simple_receive] Launching CUDA kernel to receive packets
[11:00:32:055193][2328673][DOCA][INF][gpunetio_simple_receive_sample.c:614][gpunetio_simple_receive] Waiting for termination
MST Results from Both Hosts:
[host A]
sudo mst status -v
MST modules:
MST PCI module is not loaded
MST PCI configuration module is not loaded
PCI devices:
DEVICE_TYPE MST PCI RDMA NET NUMA
BlueField2(rev:1) NA 04:00.1 mlx5_1 net-enp4s0f1np1 -1
BlueField2(rev:1) NA 04:00.0 mlx5_0 net-enp4s0f0np0 -1
[host B]
sudo mst status -v
MST modules:
MST PCI configuration module loaded
PCI devices:
BlueField2(rev:1) /dev/mst/mt41686_pciconf0.1 05:00.1 rocep5s0f1 net-eth1 -1
BlueField2(rev:1) /dev/mst/mt41686_pciconf0 05:00.0 rocep5s0f0 net-eth0
I would appreciate any suggestions on troubleshooting this issue. Please let me know if additional information is needed.
Thank you!
Best Regards,
JunXian
