I’m encountering an error with the nvjpegdec
element in my GStreamer pipeline.
Pipeline -
`‘v4l2src’ ‘device=/dev/video0’ ‘do-timestamp=true’ ‘!’ ‘identity’ ‘drop-buffer-flags=corrupted’ ‘!’ '‘watchdog’ ‘timeout=300000’ ‘!’ ‘image/jpeg,width=1920,height=1080’ ‘!’ ‘nvjpegdec’ ‘!’ ‘fakesink’
The error messages I’m seeing in the logs are:
0:00:00.437928882 8719 0x7f9890002180 WARN v4l2src gstv4l2src.c:987:gst_v4l2src_query:<v4l2src0> Can't give latency since framerate isn't fixated !
5 0:00:00.437958529 8719 0x7f9890002180 WARN v4l2 gstv4l2object.c:4721:gst_v4l2_object_set_crop:<v4l2src0:src> VIDIOC_S_CROP failed
6 0:00:00.438975962 8719 0x7f9890002180 WARN v4l2 gstv4l2object.c:3429:gst_v4l2_object_reset_compose_region:<v4l2src0:src> Failed to get default compose rectangle with VIDIOC_G_SELEC TION: Invalid argument
7 0:00:00.440001891 8719 0x7f9890002180 WARN v4l2bufferpool gstv4l2bufferpool.c:852:gst_v4l2_buffer_pool_start:<v4l2src0:pool0:src> Uncertain or not enough buffers, enabling copy threshold
8 0:00:00.707693238 8719 0x7f9890002180 ERROR nvdec gstnvdec.c:428:parser_sequence_callback:<nvjpegdec0> unhandled chroma format 2, bitdepth 8
9 0:00:00.707741649 8719 0x7f9890002180 WARN nvdec gstnvdec.c:716:parser_decode_callback: CUDA call failed: CUDA_ERROR_INVALID_HANDLE, invalid resource handle
10 0:00:00.707772529 8719 0x7f9890002180 ERROR nvdec gstnvdec.c:717:parser_decode_callback:<nvjpegdec0> failed to decode picture
11 0:00:00.708033384 8719 0x7f9890002180 WARN basesrc gstbasesrc.c:3175:gst_base_src_loop:<v4l2src0> error: Internal data stream error.
12 0:00:00.708042955 8719 0x7f9890002180 WARN basesrc gstbasesrc.c:3175:gst_base_src_loop:<v4l2src0> error: streaming stopped, reason error (-5)
13 0:00:00.708159316 8719 0x7f9890002180 WARN videodecoder gstvideodecoder.c:1416:gst_video_decoder_sink_event_default:<nvjpegdec0> error: No valid frames decoded before end of stream
14 0:00:00.708169050 8719 0x7f9890002180 WARN videodecoder gstvideodecoder.c:1416:gst_video_decoder_sink_event_default:<nvjpegdec0> error: no valid frames found
I’ve tried adjusting the pipeline configuration, but I’m still unable to resolve this issue. As I’m relatively new to GStreamer, I would greatly appreciate any insights or suggestions on how to address this problem.
Gstreamer Version - 1.24.0
CUDA Version: 12.2
NVIDIA-SMI 535.154.05
GPU - RTX A4000
Thank you in advance for your help!
