I am having some seg fault with a fortran code when compiled with pgf90 (I tried with pgi12.10). I find out, that the problem comes from a place where we use assumed shaped array and explicit array at different level of subroutine calls. Here is a reproducible small example (all array are contiguous):
program test_optional
implicit none
integer :: nargs, n
real :: X_1d(2),M_1d(2), M_2d(2,2)
character*10 arg
nargs = command_argument_count()
if( nargs == 1 ) then
call getarg( 1, arg )
read(arg,"(I8)") n
else
print*, 'usage ./test n'
STOP
endif
X_1d(:)=real(n)
M_1d(:)=real(n)
M_2d(:,:)=real(n)
if (n>1) then
call my_print_1d(X_1d,M=M_1d)
call my_print_2d(X_1d,M=M_2d)
else
call my_print_1d(X_1d)
call my_print_2d(X_1d)
end if
contains
subroutine my_print_1d(X,M)
real, intent(in) :: X(:)
REAL , INTENT(IN), OPTIONAL :: M(:)
INTEGER :: id
id=SIZE(X,1)
call my_print(X,id,1,M=M)
end subroutine my_print_1d
subroutine my_print_2d(X,M)
REAL, INTENT(IN) :: X(:)
REAL, INTENT(IN), OPTIONAL :: M(:,:)
INTEGER :: id
id=SIZE(X,1)
call my_print(X,id,id,M=M)
end subroutine my_print_2d
subroutine my_print(X,id1,id2,M)
real, intent(in) :: X(id1)
integer, intent(in) :: id1
integer, intent(in) :: id2
REAL , intent(IN), OPTIONAL :: M(id1,id2)
INTEGER :: i,j
if(present(M)) then
do j=1,id2
do i=1,id1
print*, 'M,i,j',i,j,M(i,j)
end do
end do
end if
print*, 'X', X(:)
end program test_optional
The segfault only appears when the optional are not passed:
> pgf90 -o test_optional test_optional.f90
> ./test_optional 0
Segmentation fault
> ./test_optional 2
M,i,j 1 1 2.000000
M,i,j 2 1 2.000000
X 2.000000 2.000000
M,i,j 1 1 2.000000
M,i,j 2 1 2.000000
M,i,j 1 2 2.000000
M,i,j 2 2 2.000000
X 2.000000 2.000000
Is what I am doing illegal ? I’ve tried with gfortran, and there it is not an issue. Do you have any suggestion on how I should proceed (basically I would like to use the same routine my_print for array M of different dimensions)
Thanks,
Xavier
